Topic: Does #ifdef / #if defined() not work on Arduino IDE? (Read 13816 times) previous topic - next topic
allenhuffman
Can someone tell me if this works for them?
Code: [Select]
  while(!Serial);
  Serial.println("Test...");
#ifdef FOO
byte fileReadln(File myFile, char *buffer, byte count)
#endif
Even though the fileReadln() should not compile in, it errors out looking for "File" as if it is still processing all the function headers. I was trying to #ifdef all my support for SD and Ethernet, but I ran in to this issue.
Is it just mine?
Embedded Software Engineer
UNO | Leonardo | Due | Teensy | Raspberry Pi | BASIC Stamp | OS-9 RTOS
http://www.subethasoftware.com - Established in 1990.
parajew
maybe it happens because the arduino IDE changes your sourcecode to get it agreeable
for AVR-GCC.
After compiling your project you can find a cpp file of that sketch in your temp dir.
Maybe taking a look to it makes it clear.
Some time ago, I had similar issues. This link help me to solve it:
http://www.a-control.de/arduino-fehler/?lang=en
Erdin
No, it is not just you. I think it is an error.
If you do this in the code, it is not a problem.
It has to do with the automatic function prototyping. It seems to processes all function declarations.
retrolefty
I suspect everything gets compiled, it's the linker that won't add the function if it's not referenced in the main code.
Lefty
allenhuffman
Automatic prototypes - I wondered how that worked. I will check these links. Hopefully there is a way to work around this.
And this fails with very bizarre errors... If I move the "byte mac[]" declaration outside of the #ifdef, it works.
Code: [Select]
#if defined(FOO)
#include <Spi.h>
#include <Ethernet.h>
byte mac[] PROGMEM = { 0x2A, 0xA0, 0xD8, 0xFC, 0x8B, 0xEE };
#endif
  while(!Serial);
allenhuffman
Fantastic! The first link helped explain and resolve it. I am just inserting this at the top of my code and now it works fine.
// BOF preprocessor bug prevent - insert me on top of your arduino-code
#if 1
__asm volatile ("nop");
#endif
rjwhite
d'oh!
I wish I had found this before I wrote a mini-cpp to pre-process my own #ifdefs to get around this problem.
The explanation web-page has been disabled, but I found it cached at:
http://webcache.googleusercontent.com/search?q=cache:http://www.a-control.de/arduino-fehler/?lang=en
Scroll down to get to the english version.
