Topic: ROM-Reader for Super Nintendo / Super Famicom Game Cartridges (Read 400878 times) previous topic - next topic
wildBcat
I am trying to flash my Arduino. I can install the CH341 drivers, but there is no ports in the device manager for Windows 10. I have tried showing hidden ports, and even installing legacy hardware. Nothing seems to work. Any ideas on how to get it to work?
xjunox
I got another one of those unsupported gamesharks but got it flashed by using the piggy back method on the sanni cart reader.
sanni
Is the Arduino still untouched or did you already desolder the two components? Because once the components have been desoldered you can only flash it with the Cart Reader shield attached and turned on.
If you did not desolder the two components then you should flash it without the Cart Reader shield attached just to be sure.
androxilogin
That is interesting. I only ran into one of these and it turned out to just be deemed defective because of the slot being dirty.
LHCGreg
This happened to me. For me the solution was to use a different USB cable. Make sure you are using a cable that does both power and data. If the cable only does power, the port won't show up.
darleiv
 :o hey sanni because of the error when trying to write 4 megabyte rom it says it can't read the file from the sd card
sanni
Try renaming the file to something simple like rom.bin
You can also try another SD card or format the SD card with guiformat.exe: http://www.ridgecrop.demon.co.uk/guiformat.exe
Or you can try to enable slow mode, in line 75 of Cart_Reader.ino change "#define sdSpeed SPI_FULL_SPEED" to "#define sdSpeed SPI_HALF_SPEED".
xjunox
There is some gamesharks that have a different set of chips that isnt supported.
androxilogin
I'm aware. I've only ended up with one of them is all I'm saying.
darleiv
these micro sd were not very good. mainly class 10 tips on the burning floor. sanni says ai very complicated to change the oled screen to TFT? how many programming lines need
sanni
Not very hard, maybe 20-50 lines in Cart_Reader.ino, mainly the print functions beginning in line 713 and the questionBox_OLED function.
S_K_U_N_X
Read over the posts here and see only linux usage, not that I have anything against linux but I like not to use linux when I'm completely new to something.  I have the sketch up in the IDE and can run it fine with the debug but is there no way to get the file saved in windows? Could I use putty somehow?
wildBcat
Thank you! I tried it when it was still untouched, but perhaps I had a bad cable, as LHCGreg suggested. I have unsoldered the parts already, so I will wait to try again until after it is assembled.
wildBcat
I finally got my pickit3 and SOIC8 adapter. I am completely lost! I looked at:
https://www.youtube.com/watch?v=hSkmPyhopRk
https://github.com/sanni/cartreader/wiki/Flashing-the-snesCIC
http://forum.arduino.cc/index.php?topic=158974.msg3933613#msg3933613
I am still not sure how to wire it or how to orient anything. Has anyone successfully done this before? Are there any videos on how to do this specific process?
kofdasad
Hi!
Sorry for ask this as my fisrt post...
But i Want to know if someone here actually sell Reader/Writer for SFC for use with sanni Software
:D
Thanks
