Topic: ROM-Reader for Super Nintendo / Super Famicom Game Cartridges (Read 409225 times) previous topic - next topic
wildBcat
Hi!
Sorry for ask this as my fisrt post...
But i Want to know if someone here actually sell Reader/Writer for SFC for use with sanni Software
:D
Thanks
What do you mean by SFC?
wildBcat
I have done a lot of troubleshooting and testing. I am not sure, but I think I have the PIC12f629 set up in the SOIC 8 adapter correctly and plugged into the universal harness correctly. According to my research, the universal pins are set correctly too. I could never figure out how to get the WxPic software to recognize the PicKit3, but the PicKit3 programmer seemed to. I loaded the hex file and wrote to it. It says it was successful, and verification passes. Can someone look at the pictures and see if I have done this correctly?
sanni
is there no way to get the file saved in windows? Could I use putty somehow?
The files are always saved to the SD card. A transfer function to a PC was not written yet.
You can use putty as an alternative to the Arduino Serial Monitor to control the Cart Reader but the files are still saved and read from the SD card.
Sometimes people have leftover parts from their built so you could get lucky. If not just try building it yourself, it's a fun beginner's project. :)
You can leave off any slots that you don't need to make it easier to assemble.
SFC stands for Super Famicom, it's the Japanese name for the Super Nintendo.
Yes that looks perfect. I have linked your pictures in the Wiki so that people can follow your footsteps in the future.  :)
nitrostemp
Hello Sanni,
just completed the build of the latest cartreader, just wondering which components you desolder from the robodyn arduino on the wiki it only shows the offical one.
kofdasad
Maybe you are right :)
But I'm more a Software guy, anyway soldering works for me
Still, my knoledge about eletronics is quite low...
For example I dont know if the 1st post dia schematics is optimal at this day, or there is a new one versión.
The part list:
i check eBay and see some parts, but don't know what I really need
5V/16MHz or 3.3V/8MHz  ATMEGA328P
with or without headers
The Edge Connector
this one? or which one is better? 62-70-72 pin
https://www.ebay.com/itm/1PCS-For-Super-Nintendo-SNES-SFC-62-Pin-Cartridge-Connector-Parts-Slot-Parits/401686880562?hash=item5d86676132:g:XQIAAOSw0VxcPbv9
The 74HC595... this one?
https://www.ebay.com/itm/20PCS-74HC595-SN74HC595N-8-Bit-Shift-Register-DIP-16-IC/181920573050?hash=item2a5b4fa67a:g:GVcAAOSwaB5XlbJ5
the 470 Resistors
https://www.ebay.com/itm/Carbon-Resistor-0-25w-1-4w-470-Ohm-470R-x-100/141950015864?hash=item210ce15978:g:KnYAAOxy2CZTbLXC
Ceramic capacitor...
https://www.ebay.com/itm/100pcs-Ceramic-Disc-Capacitors-50V-100nF-0-1uF-104pF/301924758047?hash=item464c1e321f:g:PgIAAOSwl9BWMZ~i
still i know, I'm missing more parts(really basic)
zero knowledge about it
That's way I ask for one already built like yours *o*
Thanks!
sanni
Unless you want to build MichlK's original reader and ignore the 6 years of development since then your starting point is here: https://github.com/sanni/cartreader/wiki/Needed-Parts  :D
Components should look the same on all versions:
wildBcat
Thank you for confirming! I will work on some detailed instructions on what I did to get it to work, and I might even make a video on it, in case anyone else needs help. It took me hours to figure it out, but I am glad I was able to get it done!
wildBcat
The part list:
The Edge Connector
the 470 Resistors
Thanks!
Here is a list of the needed parts:
If I am successful on making mine, I may use the other four PCBs I have and build some to sell.
nitrostemp
can you confirm the solder points for groud and 5v?
kofdasad
I just watch and read about everything
The way yo do(at video) looks very easy, maybe I can repeat al steps, however still have a lot of questions
Thanks for taking the time(i didn't see the GB/GBC Slot at video)
If you make it soon just tell me, if i try to do the cart reader, will be next month, meanwhile i'll try to learn the basics of soldering
Thanks!
Nextria
What are you looking for kofdasad?
A compleet and ready reader or one you still have to do some soldering on ?
I have a couple of boards somewhere only needs the screen I think.
kofdasad
Hi Nextria!
I need an already complete reader...
Just because my knowledge about electronic(parts and everything else) is almost null, i can soldering and fix basic stuff, bot this one is hard forme, maybe I can do it, but still, a lot of questions
Nextria
I will try check tomorrow where my spare one is. I will let you know.
But we i are in the middle of moving :)
So I have like 70 boxes
wildBcat
Question. Will the cart reader work without the PIC microcontroller? I am away from home and finishing up the cart reader, and realized I forgot to bring that piece with me. I was wondering if I can still set it all up and rip a Sega Rom without it. Any thoughts on that?
