Topic: ROM-Reader for Super Nintendo / Super Famicom Game Cartridges (Read 223866 times) previous topic - next topic
sanni
Just finished copy&pasting all of skaman's Famicom functions into the NES.ino. It was basically plug&play and the code was really easy to work with, thanks again to skaman.  8)
I haven't tested it yet but the adapter PCBs are already in production at JLCPCB so in 10 days we will know more.   :)
Also on a side note, the Arduino Mega is a real champ, only ~70% flash and ~52% sram are used right now. Probably enough room for even more systems.
And finally, I thought of an alternative to the cartridge adapters: An expansion port.
It's a little PCB that gets soldered to the underside of the Arduino and that duplicates all its ports so you can plug-in expansion modules.
Not sure if I should pursue this idea though since it looks complicated.  :smiley-sweat:
Nextria
That looks really great, amazing work i am loving it !
I also love the new case, i bought a 3D printer just to make this.
Thank you all for the work you put in !
Modman19
Hi Sanni, great product! I've finished building mine, and I'm very satisfied with it.
I do have a problem, though, and I was hoping you could help me figure out what I have done wrong.
The cart reader dumps GBA and N64 games flawlessly. Those work every time. However, none of the other games will dump or even read correctly. GB (Color), Sega, and SNES all fail to correctly identify which cartridge is inserted and all appear to have a similar problem: every other byte read is corrupt. I attempted to dump sonic spinball, for example, and the info screen displays:
CHKS: A3F
SRAM: None
If I attempt to read a GB cart (Super Mario Land 2: 6 Golden Coins), this typically happens:
Name:
Rom Type: MBC1+RAM
Rom Size: 512 KB
Banks: 32
SRAM Size: 8 KB
Checksum: FAAE
The one common factor I saw was these are all of the 5V systems, but I verified that 5V is reliably coming out of VCC for these systems when the switch is flipped to it, so I don't know what else they could all have in common. Do they share a specific pin on the arduino that the other systems don't?
sanni
Issues with every other byte would indicate a short circuit on address A0.
Please test the release version V2.7 just to make sure it's not a software issue as we are currently restructuring and optimizing the code which can introduce new bugs: https://github.com/sanni/cartreader/releases/tag/V2.7
Modman19
I tried the 2.7 firmware, but I'm still having the same problems.
I'll see if I can track down where there might be a short on the PCB. Thanks for the tip of where to start, I'll let you know if I have any success.
Here is a file comparison between my attempt to dump sonic spinball and a good dump:
https://imgur.com/a/uaqZkm1
sanni
Ok that looks more like an error with the D0-D7 Pins.
skaman
It is a error with D6.  Check the pins on the cart connectors and the header pins.  D6 is connected to Arduino PC6 (Pin 31).  Something must be bridged.
Modman19
Thank you skaman! I just checked, and there is no connection between pin 31 and D6 on the PCB im using. I suspect the pcb was manufactured incorrectly. Luckily, there are more that came in the order, and they do have a connection between those pins. So I will construct a second reader.
Edit: I just bridged D6 and Pin 31 manually, and now everything is dumping properly. Thank you both for your help!
sanni
Glad you could fix the issue. Also mad props to skaman for doing the maths on the data pins and figuring out the exact pin.  8)
This is the trace in question, if you find the time could you please check where it's broken, maybe it's just a cold solder joint.
Modman19
imgur.com/a/Fygl3Yj
So, I discovered that there is a very small cut on the board directly on that trace right by where it enters the pins. I've attached photos of where it's located above. I never would have noticed it if I hadn't been following that specific trace. I also am very grateful for Skaman letting me know to investigate that specific trace, because I was going crazy trying to find a short somewhere.
There is a distinct possibility that I caused that cut when I was opening the packaging that the PCBs arrived in. I definitely can't attribute that to production.
Cyber_Akuma
I've been looking into the writes to the Sega CD Backup RAM cart.  Reads worked without a problem but the cart did not respond to writes.
Thank You for this, it is definitely something I had been trying to look into. But sadly, studying pinouts and designs of the SegaCD RAMcarts mostly thought me that I don't really fully understood hot it works. Going to need to try this soon.
Hmmm..... personally, I think this would be a great idea to have a sort of "blank" mini-board for those who only need support for a specific system or two, but it would be a mess for someone who wants all supported systems.
I think it would be best to have both this and the All-In-One version, the AIO for those who want support for all systems, and the blank miniature version for those who would just want one or two systems supported, it sure beats making multiple specific versions that all only support one system.
By the way, really happy to hear about the work being done on NES/Famicom support. I had been looking into the INLretro Dumper-Programmer for NES/Famicom support, not just so I can dump my carts and saves, but also since I wanted to dabble with NESMaker and try to create my own software as well. Would it be possible to use this to write to Mapper 30 carts that NESMaker uses?
skaman
Is there a standardized cart that uses Mapper 30?  If there are multiple manufacturers, then it tends to be difficult to support due to hardware differences between versions.
I used the base read functions from the CoolArduino sketch which has support for Coolboy/Coolgirl carts.  I didn't include the Coolboy/Coolgirl stuff as it would require testing and I'm not interested in supporting bootleg carts.
I did include support for one unlicensed mapper (71) as I happened to have a Codemasters cart to test.
Cyber_Akuma
Well, Mapper 30 is a homebrew mapper designed to make carts that operate on modern flashrom, which is why that is the mapper that NESMaker supports. I cam see why that would be a bit tricky to standardize but I do believe there are some standards to it. All of them rely on it being modern flash memory instead of anything older though.
zapp98
Hi there, I love the work and this is a cool project, I just have some questions :)
I see you have an option to reflash the Gameshark for the N64, I was wondering if it would be possible to do this with the GBA ones. Specifically the Gen 1 versions. Picture attached below.
I have one which I can use to test it for you if you would like. Mine, unfortunately, has crashed from using too many cheats though so I am not sure if you would be able to use my ROM in that case, I'm not even sure how you would fix it, so if you know of a fix in that regard I'd love to give it a go. Otherwise, yeah I'm happy to help test anything if you can recommend or if you want me to test regarding the Gameshark.
Cheers
sanni
Can't see the picture but don't they have a GBA to USB cable and PC software just for that reason?
