Here's the SPC7110 Read/Write SRAM. First, I made a change to romType in getCartInfo() to classify SDD1 and SPC7110 carts as HiROM. I found it easier to handle the changes to read/write SRAM that way. I should also get around to modify dumpROM() to reflect the romType change but since the existing code works, I'll wait to clean it up later.
void getCartInfo() {
// Check if LoROM or HiROM
romType = dumpByte(0, 65493, false); // 0xFFD5
if ((romType == 0x32)||(romType == 0x3A)) // SDD1/SPC7110
romType = 1; //HiROM
romType = romType & 1; // 0xFFD5
Code was added to readSRAM() to enable the SRAM using register 0x4830. The modifications to readSRAM() are in the Dump HiRom SRAM section:
void readSRAM (char* fileName, char* folder) {
// Dump HiRom SRAM
else if (romType == 1) {
// SPC7110 SRAM
if ((romChips == 245)||(romChips == 249)) {
// Configure SPC7110 SRAM Register
setDataOut();
// Set 0x4830 to 0x80
setSRAMByte(0, 18480, 128, false);
setDataIn();
dumpByte(48, 24576, false); // Preconfigure to fix the corrupt 1st byte
// Sram size
long lastByte = (long(sramSize) * 128) + 24576;
display.println("HiROM SRAM");
display.print("SRAM Size: ");
display.println(lastByte);
display.display();
for (long currByte = 24576; currByte < lastByte; currByte++) { //startAddr = 0x6000
myFile.write(dumpByte(48, currByte, false)); //startBank = 0x30
setDataOut();
// Reset 0x4830 to 0x0
setSRAMByte(0, 18480, 0, false);
setDataIn();
else {
dumpByte(48, 24576, true); // Preconfigure to fix the corrupt 1st byte
// Sram size
display.display();
myFile.write(dumpByte(48, currByte, true)); //startBank = 0x30; CS high
I made similar changes to writeSRAM() also in the HiRom section:
void writeSRAM () {
// HiRom
else if (sramSize != 0 && romType == 1) {
// SPC7110 SRAM
display.print(sramSize / 8);
display.println("Kb HiROM");
display.println("Writing SRAM...");
display.display();
// Write to sram bank
setSRAMByte(48, currByte, myFile.read(), false); //startBank = 0x30
// blink led
if (currByte % 100 != 0)
rgbLed(busy_color);
rgbLed(off_color);
// Print Progess to LCD
progress = currByte * 100 / lastByte;
if ((progress - lastprogress) > 9) {
display.print(".");
display.display();
lastprogress = progress;
// Reset SPC7110 SRAM Register
setDataOut();
setDataIn();
else {
display.display();
setSRAMByte(48, currByte, myFile.read(), true); //startBank = 0x30; CS high
// blink led
rgbLed(busy_color);
rgbLed(off_color);
display.print(".");
display.display();
Coming up next: the FEOEZ RTC reading code. I've only done the read RTC code so far. I'm not sure if the write RTC code is really necessary.
