ROM-Reader for Super Nintendo / Super Famicom Game Cartridges
Okay, here's the SD buffer code to speed up reads and writes. I'll post the complete dump code after I test the ExHiROM carts and a couple other enhanced chip carts.
First off we add the SDBuffer[512] in the define section.
Next, my current calc_checksum() code. Some of it is untested as I don't have all of the different sizes (missing 1.5MB, 2.5MB & "Normal" 3MB). I referred to ROMs from the GoodSets where needed.
//Define Cart Reader Variables
byte SDBuffer[512];
//*************************CALCULATE CHECKSUM**************************************
unsigned int calc_checksum (char* fileName, char* folder) {
  unsigned int calcChecksum = 0;
  unsigned int calcChecksumChunk = 0;
  int calcFilesize = 0;
  unsigned int c = 0;
  unsigned long i = 0;
  unsigned long j = 0;
  if (strcmp(folder, "root") != 0)
    sd.chdir(folder);
  // If file exists
  if (myFile.open(fileName, O_READ)) {
    calcFilesize = myFile.fileSize() * 8 / 1024 / 1024;
    if (calcFilesize == 12 || calcFilesize == 20) {
      // Divide filesize by 8 to get number of 8Mbit chunks
      for (i = 0; i < (calcFilesize / 8); i++ ) {
        // Add all the bits in the 8Mbit chunks
        for (j = 0; j < (1048576 / 512); j++) {
          myFile.read(SDBuffer, 512);
          for (c = 0; c < 512; c++) {
            calcChecksumChunk += SDBuffer[c];
        calcChecksum = calcChecksumChunk;
      // Add the 4Mbit rest
      for (j = 0; j < (524288 / 512); j++) {
      calcChecksum +=  2 * calcChecksumChunk;
    else if (calcFilesize == 24 || calcFilesize == 28) {
      // Momotarou Dentestu Happy Fix 3MB (24Mbit)
      if ((calcFilesize == 24) && (romSizeExp = 0x0C)) {
        for (i = 0; i < (myFile.fileSize() / 512); i++) {
        calcChecksum = 2 * calcChecksumChunk;
      else {
        for (i = 0; i < (calcFilesize / 16); i++ ) {
          // Add all the bits in the 16Mbit chunks
          for (j = 0; j < (2097152 / 512); j++) {
        // Add the 8Mbit rest
    else if (calcFilesize == 48) {
 // Star Ocean/Tales of Phantasia Fix 6MB (48Mbit)
 // Add the 4MB (32Mbit) start
      for (j = 0; j < (4194304 / 512); j++) {
      // Add the 2MB (16Mbit) end
    else {
    //calcFilesize == 2, 4, 8, 16, 32, 40, etc
    myFile.close();
    sd.chdir();
    return (calcChecksum);
  // Else show error
  else {
    display.println("ERROR");
    display.println("DUMP ROM 1ST");
    display.display();
    return 0;
The checksum calculation greatly benefits from the 512 byte buffer. We read the file on the SD card in 512 byte chunks to perform our calculation. Calculations used to take minutes but now it takes only seconds to complete.
Now for the dumping code. In an effort to streamline the dumpROM() code, I created a dumpLoROM() and dumpHiROM(). These routines dump 512 bytes into the SDBuffer then writes the buffer to the file on the SD card.
long dumpLoROM() {
  display.println("Dumping LoROM");
  display.print("Banks: ");
  display.println(numBanks);
  display.display();
  long dumpedBytes = 0;
  // Read up to 96 banks starting at bank 0x00.
  for (int currBank = 0; currBank < numBanks; currBank++) {
    // give status updates via LCD
    display.print(".");
    display.display();
    // Dump the bytes to SD
    for (long currByte = 0x8000; currByte < 0x10000; currByte += 512) {
      for (unsigned long c = 0; c < 512; c++) {
        SDBuffer[c] = dumpByte(currBank, currByte + c, false);
        dumpedBytes++;
      myFile.write(SDBuffer, 512);
  return(dumpedBytes);
long dumpHiROM(int currBank, int endBank, long dumpedBytes) {
  for(currBank; currBank < endBank; currBank++) {
    display.print(".");
    display.display();
   for(long currByte=0; currByte < 0x10000; currByte += 512) {
        dumpedBytes++;
So substitute dumpLoROM() and dumpHiROM() into dumpROM() where needed. Here's the calls as I have them right now.
void dumpROM() {
  if ((romChips != 67)&&(romChips != 69)&&(romChips != 245)&&(romChips != 249)) {
    if (romType == 0) {
       dumpedBytes = dumpLoROM();
    else if (romType == 1) {
        dumpedBytes = dumpHiROM(0xC0, numBanks + 0xC0, dumpedBytes);
  else if((romChips == 67)||(romChips ==69)) {
    // SDD1
    // Street Fighter Alpha/Zero 2 (J, U, E): romChips = 67
    // Star Ocean (J): romChips = 69
      dumpedBytes = dumpHiROM(0xF0, 0x100, dumpedBytes);
  else if((romChips == 245)||(romChips == 249)){
    if (romType == 0) {
      // ST018
      // Hayazashi Nidan Morita Shougi 2: romChips = 245
      // SPC7110
      // Momotarou Dentetsu Happy/Super Power League 4: romChips = 245
      // Far East of Eden Zero: romChips = 249
      dumpedBytes = dumpHiROM(0xC0, 0xE0, dumpedBytes);
      dumpedBytes = dumpHiROM(0xE0, 0xF0, dumpedBytes);
