I don't really have a heatsink. I put it on an upside down old speaker just for now.
But I don't think that's the problem, cause it instantly starts to blink.
Another possibility is that it's overloading the driver which is shutting down. But if it's the recommended one, then why is it doing that. Doesn't make much sense.
Driver says 24V, 350mA. The LED you linked says it works at 350mA. So, technically it should be fine. So it's possible that it's a thermal shutdown. One thing you could do is add a series resistor to lower the amount of mA that the LED receives from the driver, bring it down to say 200 or 100mA, see if it continues to blink.
Okay, I've put 2 6,8 ohm resistors between the driver and the led, and now I'm getting a constant light source.
So the problem must be in the driver right?
I believe I might have found the problem. http://www.proaudiomusic.nl/contents/media/l_ledtrf08.jpg
On the driver it says Output Power: 4-6x1w
I think that means that you have to have a minimum of 4 leds attached otherwise the outputpower is too high.
