Topic: Voice Calls questions (Read 6029 times) previous topic - next topic
bishkot
Hi to everybody, i want to be able to call a number and speak each other without any problem (just like calling the number from my mobile phone) , the only differance is that i will be staying about 1m-1.5m from the speaker and i should be able to hear normal from the arduino`s speaker.
So i will need:
1.Arduino uno rev3
2.Arduino GSM shield right
right?
my questions are
1. Can i make a call with  a single click of a button? If the answer is yes, is this button built in or i have to do it myself (where i should solder 2 wires of the button)
2. How big speaker can i solder to the system ? Can i solder something like this
and also how many Watts can the speaker be?
3.Do i need to have any other board(s) accessoaries or parts to make this work?
Thanks!
davidgoth
You can make a call pushing down a button writing a function in your sketch. This function checks button status and, if it pressed, do something like this:
Using this code, you can finish the call by pressing enter in the serial monitor (with new line option selected).
Code: [Select]
char remoteNumber[21] = "+12345678910"; // Telephone number
  // let the user know you're calling:
  Serial.print("Calling to : ");
  Serial.println(remoteNumber);
  // Check if the receiving end has picked up the call
  if(vcs.voiceCall(remoteNumber))
    Serial.println("Call Established. Enter line to end");
    // Wait for some input from the line
    while(Serial.read()!='\n' && (vcs.getvoiceCallStatus()==TALKING));
    // And hang up
    vcs.hangCall();
  Serial.println("Call Finished");
To connect a speaker to the GSM shield, you can read this tutorial to learn how to connect the hardware: http://arduino.cc/en/Guide/ArduinoGSMShield#toc11
Greetings.
bishkot
Thanks for your reply. But how i will set up exactly wich button to be listened and by pressing it, this function to be executed?
Does this shield has several different buttons pins so i can solder couple of buttons and setup different functions to them?
How can i define in my program/function for example if it was php
function b1()
$my_number='00359888888';
if($button1_status=='pressed')
lets_call_my_number();
if ($button2_status=='pressed')
send_sms_to_my_number();
i hope you can understand my idea, i am not a professional in c or c++ but like in php this gives a simple view of my idea
Thanks
call
bishkot
any examples where to solder a button for voice calling ?
bishkot
Please i need to do this ->http://www.youtube.com/watch?v=zTCXtRiVk9Y
what is the wiring diagram of the button and also how can i tell to call a given number by pressing the button
any tutorials?
zorzano
Hello:
You need to use the Arduino to control the button. See here:
http://arduino.cc/en/Tutorial/Button
but use pin number 2.
Remember that the shield pins are connected to the Arduino pins except pins 2, 3 and 7.
You have to merge both sketches (button example and SMS example). This should run:
// libraries
#include <GSM.h>
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess; // include a 'true' parameter for debug enabled
GSM_SMS sms;
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 6;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
// initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  // initialize serial communications
  Serial.println("SMS Messages Sender");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
  Serial.print("Enter a mobile number: ");
  char remoteNumber[20]; // telephone number to send sms
  readSerial(remoteNumber);
  // sms text
  Serial.print("Now, enter SMS content: ");
  char txtMsg[200];
  readSerial(txtMsg);
  Serial.println("SENDING");
  Serial.println("Message:");
  Serial.println(txtMsg);
  // send the message
  sms.beginSMS(remoteNumber);
  sms.print(txtMsg);
  sms.endSMS();
  Serial.println("\nCOMPLETE!\n");
Read input serial
int readSerial(char result[])
  int i = 0;
  while(1)
    while (Serial.available() > 0)
      char inChar = Serial.read();
      if (inChar == '\n')
        result = '\0';
        Serial.flush();
        return 0;
      if(inChar!='\r')
        result = inChar;
        i++;
zorzano
You have to use the Arduino to control the button.
See this page for button control, but use pin 6 instead of 2.
Remember shield pins are connected to Arduino pins (except 2,3 and 7), so you can connect to the shield +GND, 5V and pin 6.
Now you have to merge both examples: sendSMS and button. This sketch should run, please check it:
// libraries
#include <GSM.h>
GSM_SMS sms;
// set pin numbers:
  // connection state
  // Start GSM shield
  while(notConnected)
// read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, HIGH);
  // send the message
  sms.beginSMS("+123456789");
  sms.print("Hi!");
  sms.endSMS();
  else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
bishkot
thank you, but i just need it to make a voice call instead of sending sms , how i shoud connect 2 pin button to the 3 pin as you said (GND, PIN6, 5V) ??
mldemarie
HI,
   I've been working with the GMS shield for a couple weeks now, but i'm at the point in need to set up voice calling.  I don't believe i have a software issue, but just a hardware issue.  When i establish a call, my speaker is unclear and crackly.  I'm just trying to use the speaker and mic setup from the GSM tutorial guide.
   In the picture i attached there are two parts circled in red.  I assumed they were some zener diode.  Can any specify exactly what these are suppose to be?  If they are some kind of diode, what rating should it be? also, do i need anything for the "differential layout"?  I think these are my problems.  Thanks.
