Topic: Receive SMS example (Read 91426 times) previous topic - next topic
akashroy
Hey guys,
     I noticed on the Receive gsm text for the shield that multiple msgs cannot be received. The coding is only detecting the first msg and stop detecting until it is reset.
Code: [Select]
SMS receiver
This sketch, for the Arduino GSM shield, waits for a SMS message
and displays it through the Serial port.
Circuit:
* GSM shield attached to and Arduino
* SIM card that can receive SMS messages
created 25 Feb 2012
by Javier Zorzano / TD
This example is in the public domain.
http://arduino.cc/en/Tutorial/GSMExamplesReceiveSMS
// include the GSM library
#include <GSM.h>
// PIN Number for the SIM
#define PINNUMBER "1111"
// initialize the library instances
GSM gsmAccess;
GSM_SMS sms;
// Array to hold the number a SMS is retreived from
char senderNumber[20];
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("SMS Messages Receiver");
  // connection state
  boolean notConnected = true;
  // Start GSM connection
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
  Serial.println("Waiting for messages");
  char c;
  // If there are any SMSs available()
  if (sms.available())
    Serial.println("Message received from:");
    // Get remote number
    sms.remoteNumber(senderNumber, 20);
    Serial.println(senderNumber);
    // An example of message disposal
    // Any messages starting with # should be discarded
    if(sms.peek()=='#')
      Serial.println("Discarded SMS");
      sms.flush();
    // Read message bytes and print them
    while(c=sms.read())
      Serial.print(c);
    Serial.println("\nEND OF MESSAGE");
    // Delete message from modem memory
    sms.flush();
    Serial.println("MESSAGE DELETED");
Thank you, in advance.
davidgoth
Hello,
Try to receive sms using AT commands with the next code and sending them via serial monitor (configured CR / NL).
Code: [Select]
#include <SoftwareSerial.h>
#include <string.h>
char incoming_char = 0;
SoftwareSerial cell(2, 3);
  cell.begin(9600);
  Serial.print("Starting modem communication...");
  delay(12000);
  Serial.print("OK\nIntroduce your AT commands:\n");
  if(cell.available() > 0)
    incoming_char=cell.read();
    if((incoming_char >= ' ') && (incoming_char <= 'z'))
      Serial.print(incoming_char);
      Serial.print("%");
      Serial.print((int)incoming_char);
      Serial.print("%");
      if(incoming_char==10)
  if(Serial.available() > 0)
    incoming_char = Serial.read();
    cell.print(incoming_char);
The AT commands for receiving SMS are:
ATE1 --> Set echo ON
AT+CMGF=1 --> Establishes text mode in modem
AT+CMGL="REC UNREAD",1 --> Checks if exists unread SMS. Return OK if not exist any SMS, in other case returns a list with them (the first number of each of them are the index of each of them).
AT+CMGR=[sms_index],0 --> Read SMS with index sms_index from modem memory (ej: AT+CMGR=1,0).
AT+CMGD=[sms_index] --> Delete SMS with index sms_index from modem memory (ej: AT+CMGD=1).
The problem can be attached with your local operator. Are you using the SIM that came with the shield?.
akashroy
I live in Canada and the SIM card that was provided did not work here. So I am using a Fido/Rogers SIM card. I will try this code out now.
akashroy
#3
Apr 30, 2013, 03:06 pm Last Edit: Apr 30, 2013, 03:08 pm by akashroy Reason: 1
I could not get the codes to work, so I changed this (the 10 to 11) because of the + coming in front.
Code: [Select]
     Serial.print("%");
     Serial.print("%");
     if(incoming_char==11)
So to clarify the issue - the gsm picks up the first text message coming in but not any others that comes in after unless it is reset
I appreciate the help guys.
zorzano
Did you manage to execute the AT dialogue? When you execute the sketch you shall see the modem answers. May you copy here the output received through the Serial monitor?
thanks.
akashroy
#5
May 01, 2013, 02:27 am Last Edit: May 01, 2013, 02:30 am by akashroy Reason: 1
Quote
I'm not sure if I understood what to do with these commands guys.
After I executed the given code, all I got was:
____
Starting modem communication...OK
____
Nothing else occurred after I had texted the SIM card number either.
Thanks for the help guys - You guys are my lifeline right now!
akashroy
I would like to notify that I am using the mega, so would the line:
Would be different, or no ?
Thanks guys
zorzano
First of all, sorry for the delay answering. Long holiday in Madrid.
And yes, things are a bit different in a Mega because interrupts are not the same and communications between modem and arduino have to change.
First, go to the library file called GSM3SoftSerial.cpp and uncomment the lines:
// These can be used in Arduino Mega
#define __TXPIN__ 11
#define __RXPIN__ 10
#define __RXINT__ 4
Now you have to throw a couple of wires:
- From the shield pin called "GSM TX" to pin number 10
- From the shield pin called "GSM RX" to pin number 11
Now you should be able to execute the AT commands and see the answers. Please tell us how it is going.
If you move to UNO remember to take out the wires and comment again the lines.
akashroy
Hey guys,
        Thanks for your help - the service was mistakenly cut off.
Akash
captainhooyah
#9
Jul 23, 2013, 01:30 am Last Edit: Jul 23, 2013, 01:54 am by captainhooyah Reason: 1
Hi, I hope you guys can help me.  I can use the following code to receive SMS messages, and then use the body of the SMS message to do some conditional programming.  The only problem is that I can only do it by typing my AT commands into the serial monitor. When I try to put the receive SMS command (AT+CMGR=1,0) in my loop, it doesn't work.  Ideally I would be able to check for a new SMS every 30 seconds.  This is the working code:
Code: [Select]
#include <string.h>
char command = 0; //Conditional Programming Variable changes with SMS content.
SoftwareSerial cell(7, 8); //my shield uses these pins for software serial.
 Serial.begin(19200);
 cell.begin(19200);
 delay(2000);
 delay(12000);
   if(incoming_char=='#'){
     Serial.println("SMS command mode:"); //If the SMS contains "#" the arduino looks for commands that follow.
     command=cell.read();
   if (command == 'a'){  //If the next character in the SMS is "a", then do the following
     Serial.println("Commands would execute here and now.");
     command = 0;
     Serial.print("%");
     Serial.print("%");
     //Serial.println(incoming_char);
When I send a SMS to my cell shield that contains "#a" in the body of the message and enter the "AT+CMGR=1,0" into the serial monitor the program reads the SMS and then does whatever I tell it to do.  Right now it just executes a serial print that says "Commands would execute here and now".
After I run this I'd also like to delete the SMS with the "AT+CMGD=1" command.
Here is my code with the timed SMS check... It runs the "AT+CMGR=1,0" command every 30 seconds, but doesn't work.
Code: [Select]
#include <string.h>
//These variables are for timing the Receive SMS command.
long previousMillis = 0; //Equals current millis every time interval is met.
long interval = 30000; //Amount of time to wait between Receive SMS commands
 cell.begin(19200);
 delay(2000);
 delay(12000);
//--------Timed SMS Receive command code ---------
 if (currentMillis - previousMillis > interval) {
   cell.print('AT+CMGR=1,0');
     command = 0;
     Serial.print("%");
     Serial.print("%");
The result is this:
"1%49%1%49%3%51%1%49%2%50%"
Which makes no sense to me... I realize I haven't included the auto delete code in either example, that's because I haven't even gotten to that point yet.  The previous posts were very helpful, could you please point out what I am doing wrong? I spent all day trying to figure it out. Thanks in advance.
captainhooyah
I needed to include a carriage return. I should note I am using the Seeed Studio GPRS shield and not the official arduino shield.  I got it to receive messages using AT commands like this:
Code: [Select]
cell.println("AT+CMGR=1,0");
cell.print("\r");
Thanks to Davidgoth for helping me out via private message.
If anyone is having issues with the this and the seeed studio gprs shield send me a PM, I can probably help you out at this point.
captainhooyah
Also it was a lot easier to debug via serial monitor if I took this code chunk and changed it.
Code: [Select]
      Serial.print("%");
      Serial.print("%");
Code: [Select]
      //Serial.print("%");
Capt_Rhizz
Just thought I'd resurrect this old girl again. For anyone still having issues with this it can be a simple fix if you are not like me and am having trouble following other peoples code.
Here is the sample code provided by arduino:
Code: [Select]
 SMS receiver
 Circuit:
 created 25 Feb 2012
#include <GSM.h>
#define PINNUMBER ""
GSM gsmAccess;
GSM_SMS sms;
  while (!Serial) {
  // connection state
  while (notConnected)
    if (gsmAccess.begin(PINNUMBER) == GSM_READY)
  char c;
    if (sms.peek() == '#')
      sms.flush();
    while (c = sms.read())
      Serial.print(c);
    sms.flush();
-->Now adding another sms.flush() at the end right before the delay like so:
Code: [Select]
 SMS receiver
 Circuit:
 created 25 Feb 2012
#include <GSM.h>
GSM gsmAccess;
GSM_SMS sms;
  while (!Serial) {
  // connection state
  char c;
      sms.flush();
      Serial.print(c);
    sms.flush();
   sms.flush();//********************right here is what I added************************
To me, I saw this issue of getting only one SMS at a time to be an issue with how it is stored in the modems memory. It worked for me!! I was able to continually get sms cycling through as they came it.
Looking up the flush() command didn't give me insight into how this really made the code function correctly or buggy and correctly. For whatever reason, I thought I'd bring this up again in hopes the experts can give some insight.
-Rhizz :smiley-draw:
kosarbahir
I can not receive a message , i have a Telit 865 Dual , Can you help to change any things in Library ? is there any things wrong at here ?
_______________________________________
#include <GSM3ShieldV1AccessProvider.h>
#include <Arduino.h>
#include "GSM3IO.h"
#define __TOUTSHUTDOWN__ 5000
#define __TOUTMODEMCONFIGURATION__ 5000//equivalent to 30000 because of time in interrupt routine.
#define __TOUTAT__ 1000
const char _command_AT[] PROGMEM = "AT";
const char _command_CGREG[] PROGMEM = "AT+CGREG?";
GSM3ShieldV1AccessProvider::GSM3ShieldV1AccessProvider(bool debug)
   theGSM3ShieldV1ModemCore.setDebug(debug);
void GSM3ShieldV1AccessProvider::manageResponse(byte from, byte to)
   switch(theGSM3ShieldV1ModemCore.getOngoingCommand())
      case MODEMCONFIG:
         ModemConfigurationContinue();
      case ALIVETEST:
         isModemAliveContinue();
///////////////////////////////////////////////////////CONFIGURATION FUNCTIONS///////////////////////////////////////////////////////////////////
// Begin
// Restart or start the modem
// May be synchronous
GSM3_NetworkStatus_t GSM3ShieldV1AccessProvider::begin(char* pin, bool restart, bool synchronous)
   pinMode(__RESETPIN__, OUTPUT);
   #ifdef TTOPEN_V1
   pinMode(__POWERPIN__, OUTPUT);
   digitalWrite(__POWERPIN__, HIGH);
   #endif
   // If asked for modem restart, restart
   if (restart)
      HWrestart();
       HWstart();
   theGSM3ShieldV1ModemCore.gss.begin(9600);
   // Launch modem configuration commands
   ModemConfiguration(pin);
   // If synchronous, wait till ModemConfiguration is over
   if(synchronous)
      // if we shorten this delay, the command fails
      while(ready()==0)
   return getStatus();
//HWrestart.
int GSM3ShieldV1AccessProvider::HWrestart()
   #ifdef TTOPEN_V1
   #endif
   theGSM3ShieldV1ModemCore.setStatus(IDLE);
   digitalWrite(__RESETPIN__, HIGH);
   delay(12000);
   digitalWrite(__RESETPIN__, LOW);
   return 1; //configandwait(pin);
//HWrestart.
int GSM3ShieldV1AccessProvider::HWstart()
   delay(2000);
   //delay(1000);
//Initial configuration main function.
int GSM3ShieldV1AccessProvider::ModemConfiguration(char* pin)
   theGSM3ShieldV1ModemCore.setPhoneNumber(pin);
   theGSM3ShieldV1ModemCore.openCommand(this,MODEMCONFIG);
   theGSM3ShieldV1ModemCore.setStatus(CONNECTING);
   return theGSM3ShieldV1ModemCore.getCommandError();
//Initial configuration continue function.
void GSM3ShieldV1AccessProvider::ModemConfigurationContinue()
   bool resp;
   // 1: Send AT
   // 2: Wait AT OK and SetPin or CGREG
   // 3: Wait Pin OK and CGREG
   // 4: Wait CGREG and Flow SW control or CGREG
   // 5: Wait IFC OK and SMS Text Mode
   // 6: Wait SMS text Mode OK and Calling line identification
   // 7: Wait Calling Line Id OK and Echo off
   // 8: Wait for OK and COLP command for connecting line identification.
   // 9: Wait for OK.
   int ct=theGSM3ShieldV1ModemCore.getCommandCounter();
   if(ct==1)
      // Launch AT
      theGSM3ShieldV1ModemCore.setCommandCounter(2);
      theGSM3ShieldV1ModemCore.genericCommand_rq(_command_AT);
   else if(ct==2)
      // Wait for AT - OK.
      if(theGSM3ShieldV1ModemCore.genericParse_rsp(resp))
         if(resp)
            // OK received
            if(theGSM3ShieldV1ModemCore.getPhoneNumber() && (theGSM3ShieldV1ModemCore.getPhoneNumber()[0]!=0))
                  theGSM3ShieldV1ModemCore.genericCommand_rq(PSTR("AT+CPIN="), false);
                  theGSM3ShieldV1ModemCore.setCommandCounter(3);
                  theGSM3ShieldV1ModemCore.genericCommand_rqc(theGSM3ShieldV1ModemCore.getPhoneNumber());
                  //DEBUG
                  //Serial.println("AT+CGREG?");
                  theGSM3ShieldV1ModemCore.setCommandCounter(4);
                  theGSM3ShieldV1ModemCore.takeMilliseconds();
                  theGSM3ShieldV1ModemCore.genericCommand_rq(_command_CGREG);
         else theGSM3ShieldV1ModemCore.closeCommand(3);
   else if(ct==3)
         if(resp)
            theGSM3ShieldV1ModemCore.delayInsideInterrupt(2000);
   else if(ct==4)
      char auxLocate1 [12];
      char auxLocate2 [12];
      prepareAuxLocate(PSTR("+CGREG: 0,1"), auxLocate1);
      prepareAuxLocate(PSTR("+CGREG: 0,5"), auxLocate2);
      if(theGSM3ShieldV1ModemCore.genericParse_rsp(resp, auxLocate1, auxLocate2))
         if(resp)
            theGSM3ShieldV1ModemCore.setCommandCounter(5);
            theGSM3ShieldV1ModemCore.genericCommand_rq(PSTR("AT+IFC=1,1"));
            // If not, launch command again
            if(theGSM3ShieldV1ModemCore.takeMilliseconds() > __TOUTMODEMCONFIGURATION__)
   else if(ct==5)
      // 5: Wait IFC OK
         //Delay for SW flow control being active.
         // 9: SMS Text Mode
         theGSM3ShieldV1ModemCore.setCommandCounter(6);
         theGSM3ShieldV1ModemCore.genericCommand_rq(PSTR("AT+CMGF=1"));
   else if(ct==6)
         //Calling line identification
         theGSM3ShieldV1ModemCore.setCommandCounter(7);
         theGSM3ShieldV1ModemCore.genericCommand_rq(PSTR("AT+CLIP=1"));
   else if(ct==7)
         // Echo off
         theGSM3ShieldV1ModemCore.setCommandCounter(8);
         theGSM3ShieldV1ModemCore.genericCommand_rq(PSTR("ATE0"));
   else if(ct==8)
      // 8: Wait ATEO OK, send COLP
      // In Arduino Mega, attention, take away the COLP step
      // It looks as we can only have 8 steps
         theGSM3ShieldV1ModemCore.setCommandCounter(9);
         theGSM3ShieldV1ModemCore.genericCommand_rq(PSTR("AT#NCIH=1"));
   else if(ct==9)
      // 9: Wait ATCOLP OK
         if (resp)
               theGSM3ShieldV1ModemCore.setStatus(GSM_READY);
               theGSM3ShieldV1ModemCore.closeCommand(1);
//Alive Test main function.
int GSM3ShieldV1AccessProvider::isAccessAlive()
   theGSM3ShieldV1ModemCore.setCommandError(0);
   theGSM3ShieldV1ModemCore.setCommandCounter(1);
   theGSM3ShieldV1ModemCore.openCommand(this,ALIVETEST);
//Alive Test continue function.
void GSM3ShieldV1AccessProvider::isModemAliveContinue()
bool rsp;
switch (theGSM3ShieldV1ModemCore.getCommandCounter()) {
    case 1:
   case 2:
      if(theGSM3ShieldV1ModemCore.genericParse_rsp(rsp))
         if (rsp) theGSM3ShieldV1ModemCore.closeCommand(1);
//Shutdown.
bool GSM3ShieldV1AccessProvider::shutdown()
   unsigned long m;
   bool resp;
   char auxLocate [18];
   // It makes no sense to have an asynchronous shutdown
   delay(1500);
   theGSM3ShieldV1ModemCore.gss.close();
   m=millis();
   prepareAuxLocate(PSTR("POWER DOWN"), auxLocate);
   while((millis()-m) < __TOUTSHUTDOWN__)
      delay(1);
      if(theGSM3ShieldV1ModemCore.genericParse_rsp(resp, auxLocate))
         return resp;
   return false;
//Secure shutdown.
bool GSM3ShieldV1AccessProvider::secureShutdown()
   delay(900);
   theGSM3ShieldV1ModemCore.setStatus(OFF);
#ifdef TTOPEN_V1
   _delay_ms(12000);
   digitalWrite(__POWERPIN__, LOW);
#endif
   return true;
jirgale
Hello,
I want to receive sms using gsm and arduino... I have wrote a program for it, but it's not working. Can you plz check the code and suggest corrections?
 Here is my code...
#include<LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
char RcvdMsg[200] = "";
int RcvdCheck = 0;
int RcvdConf = 0;
int index = 0;
int RcvdEnd = 0;
char MsgMob[15];
char MsgTxt[50];
int MsgLength = 0;
 lcd.begin(16, 2);
 lcd.print("Good Afternoon!");
 Config();
 RecSMS();
void Config() // This function is configuring our SIM900 module i.e. sending the initial AT commands
 Serial.print("ATE0\r");
 Response();
 Serial.print("AT\r");
 Response();
 Serial.print("AT+CMGF=1\r");
 Response();
 Serial.print("AT+CNMI=1,2,0,0,0\r");
 Response();
void Response() // Get the Response of each AT Command
 int count = 0;
 while (1)
   if (Serial.available())
     char data = Serial.read();
     if (data == 'K') {
       Serial.println("OK");
     if (data == 'R') {
       Serial.println("GSM Not Working");
   count++;
   delay(10);
   if (count == 1000) {
     Serial.println("GSM not Found");
void RecSMS() // Receiving the SMS and extracting the Sender Mobile number & Message Text
   if (data == '+') {
     RcvdCheck = 1;
   if ((data == 'C') && (RcvdCheck == 1)) {
     RcvdCheck = 2;
   if ((data == 'M') && (RcvdCheck == 2)) {
     RcvdCheck = 3;
   if ((data == 'T') && (RcvdCheck == 3)) {
     RcvdCheck = 4;
   if (RcvdCheck == 4) {
     index = 0;
     RcvdConf = 1;
     RcvdCheck = 0;
   if (RcvdConf == 1)
     if (data == '\n') {
       RcvdEnd++;
     RcvdMsg[index] = data;
     index++;
     if (RcvdEnd == 2) {
       RcvdConf = 0;
       MsgLength = index - 2;
       RcvdEnd = 0;
     if (RcvdConf == 0)
       Serial.print("Mobile Number is: ");
       for (int x = 4; x < 17; x++)
         MsgMob[x - 4] = RcvdMsg
         Serial.print(MsgMob[x - 4]);
       Serial.print("Message Text: ");
       lcd.setCursor(0, 0);
       for (int x = 46; x < 62; x++)
         MsgTxt[x - 46] = RcvdMsg
         lcd.print(MsgTxt[x - 46]);
         Serial.print(MsgTxt[x - 46]);
       Serial.println(MsgTxt[0]);
       Serial.println(MsgTxt[1]);
       Serial.println(MsgTxt[2]);
       Serial.println(MsgTxt[3]);
       Serial.println(MsgTxt[4]);
       lcd.setCursor(0, 1);
       for (int x = 62; x < MsgLength; x++)
         MsgTxt[x - 62] = RcvdMsg
         lcd.print(MsgTxt[x - 62]);
         Serial.print(MsgTxt[x - 62]);
