Topic: GSM , Replay to SMS problem ? (Read 3245 times) previous topic - next topic
mohammadKTaha
May 03, 2013, 06:00 pm Last Edit: May 06, 2013, 12:19 am by mohammadKTaha Reason: 1
hi all ,
i am using arduino to control an SM100B GSM , every thing is working perfectly except when i want to send an sms after receive an sms
"replay to message ", i get this
Code: [Select]
O K > + C M G S : 2 5 O K + C M E E R R O R : 4
i know that CME ERROR: 4    means Operation not supported .
but what i can do to prevent it ?
dose any one have any idea about that ?
my  code :
Code: [Select]
#include <SoftwareSerial.h>  //Include the NewSoftSerial library to send serial commands to the cellular module.
   char inchar;                //Will hold the incoming character from the Serial Port.
   SoftwareSerial cell(2,3);    //Create a 'fake' serial port. Pin 2 is the Rx pin, pin 3 is the Tx pin.
   char mobilenumber[] = "0597010129";  // Replace xxxxxxxx with the recipient's mobile number
   //GSM
   Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
   Serial.println("Initialize GSM module serial port for communication.");
   cell.begin(9600);
   delay(35000); // give time for GSM module to register on network etc.
   Serial.println("delay off");
   cell.println("AT+CMGF=1"); // set SMS mode to text
   delay(200);
   cell.println("AT+CNMI=3,3,0,0"); // set module to send SMS data to serial out upon receipt
   delay(200);
    if(cell.available() >0)//If a character comes in, from the cellular module
    inchar=cell.read();
    Serial.println(inchar);
    if (inchar=='#'){ // OK - the start of our command
      delay(10);
      inchar=cell.read();
        if (inchar=='a'){
          delay(10);
          Serial.println("The folowing SMS : \n");
          inchar=cell.read();
          if (inchar=='0'){ //sequance = #a0
            Serial.println("#a0 was received");
        else if (inchar=='1'){//sequance = #a1
           Serial.println("#a1 was received ");
           sendSms();
    cell.println("AT+CMGD=1,4");// AT command to delete all msgs
    Serial.println(" delete all SMS");
   }//end of  if(cell.available() >0) {...}
   void sendSms(){
   //cell.println("AT+CMGF=1"); // set SMS mode to text
   cell.print("AT+CMGS=");  // now send message...
   cell.print((char)34); // ASCII equivalent of "
   cell.print(mobilenumber);
   cell.println((char)34);  // ASCII equivalent of "
   delay(500); // give the module some thinking time
   cell.print(":D hello m3alleg :D");   // our message to send
   cell.println((char)26);  // ASCII equivalent of Ctrl-Z
   delay(20000);
