Topic: Have you made a joystick from an Arduino? I need your expertise, please. (Read 3089 times) previous topic - next topic
aggrav8d
I did my homework and found two methods of getting an arduino to show up as a joystick.
1) DFU
2) "Don't use DFU, buy specialized hardware."
I'd like to solve this without having to buy extra hardware, if I can.  What's your method?
Thank you!
Dance as if no one is watching; post as if it is going to be read aloud as evidence in court.
Osgeld
vusb
http://www.obdev.at/products/vusb/index.html
and here is an instructable that is for making a wii controller into usb, but its handy as it explains USB descriptors and whatnot
http://www.instructables.com/id/USB-Wii-Classic-Controller/#step1
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
aggrav8d
"making it possible to build USB hardware with almost any AVR® microcontroller, not requiring any additional chip."
Thanks for the quick reply.  Unfortunately this doesn't meet my needs.
I don't want to build any extra hardware.  I don't want to buy some wierd programming device.
I'm led to believe there's a way to change the bootloader so that my existing sketch stays on the chip and it will show up as a joystick.  It's supposed to use the existing USB port.
Have you got a way to do that, please?
aggrav8d
Hi!
I want my UNO to show up as a HID compliant joystick.  I've already written the sketch to run on the microcontroller.  I don't have the bootloader right.  I've been told DFU can do it, but then people in arduino said "no, buy extra hardware to do the job right."  I'd really really like to do the job without buying extra hardware.  Please: Is there a way?
Thank you!
AlxDroidDev
This is easier to achieve with a Leonardo or a USB Host shield.
The UNO itself can't do it, because the Atmega328P on it doesn't talk directly to the USB port on a computer. It needs something in between, be it the Atmega8u2 or Atmega16u2 on it or the USB host shield.
If you reprogram the Atmega8u2 (or 16u2) on your UNO, you'll lose the feature of uploading sketches through the UNO's USB port.
Some of my projects:
Shield for DS1337+, DS1624 and AT24C1024B (RTC, temp & mem): http://forum.arduino.cc/index.php/topic,126197.0.html
CHDK Camera remote shutter (BT, IR, USB): http://forum.arduino.cc/index.php?topic=295377.0
aggrav8d
Total cost UNO + USB Host Shield > Leonardo.  Decision made.
Thanks!
Coding Badly
Osgeld
its 3 resistors and 2 diodes running on a standard arduino, so apparently you didnt look too hard, hack up the usb interface on the uno or buy an Leonardo
