Topic: Due not detected via USB (Read 17733 times) previous topic - next topic
alinmesser
I tried both the programming and native USB ports, in a Windows 7, Windows 8 and two Linux machines, but my new Arduino Due is not detected. The power led is on and the L blinks about once a second - which seems to be the factory sketch loaded.
I also tried to power it differently, with a 850mA/5V adapter, and a 2x to one USB Y cable with no luck.
I would have thought the ATMega16U2 was bad, but if that was the case why isn't the native port being detected either?
I'm a new user and really don't know what else to try.
Gericom
Try connecting using the native usb port. Then press the erase and the reset button at the same time. If everything went well, the bossac port will connect to your pc. You can upload a random sketch with the arduino ide then. After that, press the reset button again. And everything should work again.
Subscribe my youtube channel: http://www.youtube.com/user/MKDS3
djabailey
I have the same problem, the suggested fix didn't work for me.
Gericom
No? Are you sure you connected the NATIVE port? (Not the programming one) Did you press the both buttpns correctly at the same time?
djabailey
Yes, I did exactly as recommended, the board appears not to work.
I played around with it a little using my AVR ISP Mk2 and the chip seems fine (the 16u2) and yet the computer doesn't detect it, the only reason I can see for it not working is if the board is faulty so I'm going to get it swapped for a new one.
Gericom
That chip is not important! That one will work always. The programming port should be recognized. It's all about the sam3x chip.
djabailey
Yes I know, the port SHOULD be recognised. If it isn't recognised by the computer AT ALL that must be a faulty board, right?
Gericom
Yes, if the programming port is still recognized, the solution above works. Otherwise your board is damaged.
kgoveas
Hey,
I have the same problem with the Arduino Due. Since the programming port is recognized under Device Manager, It is obvious that the AtMega16u2 is working. But since the Native USB port does not work it concludes that the SAM3X is not responding and I have no idea why. It shows up as Unknown Device. When you try programming the Due through the programming port it shows that there is no device on the COMx which further confirms that the SAM3X is unresponsive.
Sadly it worked for 2 days and now only seems to be nothing more than a paper-weight. I hope there is a way to ressurect it.
kgoveas
Gericom
Hey,
kgoveas
Have you tried the 2 button solution?
kgoveas
Yes. I have tried the 2 buttons manipulation. I am sure it is dead.  =(
It is not responding to the RESET or the ERASE button whatsoever. Majority of the pins are just HIGH.. @3.3V (Pun Intended) :)
aditya_jain
Two button reset procedure worked for my DUE board and it detected as bossac port in device manager, all this procedure is done with USB native port. I pressed two buttons erase and reset simultaneously for 2 seconds,  and later every thing was fine ...
thank you ....  :)
xKoldFuzionx
I thought there was something wrong with my Due as well, but I just tried a different USB cable and Windows recognized it and started installing the drivers.  Now I don't have any problems.
I know this was posted a few years ago, but maybe if anyone else has these problems, they can try swapping out the cable and see if that fixes their troubles.
hussaa1
#13
May 19, 2017, 10:50 am Last Edit: May 19, 2017, 11:07 am by hussaa1
A couple of my Due's stopped working completely i.e. Windows 7 on few different platforms of mine just won't recognise them anymore. That was through both the normal programming port and through the Native programming port. I used a USB viewer program called USBDeView.exe which you can download from (http://www.nirsoft.net/utils/usb_devices_view.html) and I could see the drivers assigned to the Due's previously when they did work. I uninstalled the drivers completely thinking that Windows may be able to detect the boards but it didn't work. I tried the two button press trick several times but no luck.
In the end I followed what xKoldFuzionx said, and viola - my boards started to work. Thanks man. sometime something so simple can sort things out. we just don't realise it.
Try changing your USB cable folks.
OldRon
hussaa1,
That W O R K E D !. Apparently there are charging cables without communication. The cable that I was using came with my cell phone.
For others that might be 3 years late to the party; Arduino recommends using the programming port. For a first time connection all that you will accomplish by pushing the buttons will be to clear the factory test sketch.
Ron
