Topic: Very new to arduino (first day), need sample code to at least turn on a WS2811 (Read 5476 times) previous topic - next topic
hamster462
I spent a few hours searching but found 100% no code that would even get one of the LED's to turn on. I managed to import the FastSPI_LED library and then must have tried 30 different pieces of code and nothing has worked.
Hi, I recently got an arduino uno and would and a 50LED WS2811 light strip.
The LED strip has 4 wires (red, black (which I connected to a 5V rail of an old computer power supply), and the final 2 wires are a green and a white wire.  (the white and black wire seem to be connected together as the resistance reads as 0.3 ohms )
I took a picture of the hardware. http://i.imgur.com/SDrDLsY.jpg
I would at least like to get the LED's to turn on  (First time using arduino)
The LED's purchased were these: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=151023467725&ssPageName=ADME:X:BOCOR:US:1123
hamster462
That was one of the first ones I tried. (the writer made it quite difficult to find the code )
http://sourceforge.net/p/abavr/lib/ci/e3429e3493e08015d94d9237699bf15c085970c7/tree/WS2811/WS2811.h
That was the one I tried copying, and confirmed that the correct pin was used, and the LED's did not attempt to light.
the next that I tried was
http://funkboxing.com/wordpress/wp-content/_postfiles/sk_qLEDFX_POST.ino
but it would not even let me flash it
I also tried
http://arduino.cc/forum/index.php?topic=80567.20;wap2
and other than those, I mostly found forum post with sample code but none of the code was in a form where it can just be used, they were all partial.
eg http://arduino.cc/forum/index.php?topic=164120.0
Just not sure what I am doing wrong.
Edit: I originally started off with the info provided on this video and imported the libraries listed http://code.google.com/p/fastspi/source/browse/#svn%2Ftrunk%253Fstate%253Dclosed for the library, and
https://github.com/tomfinnie/LEDstrip/tree/master/switched for the users code (also did not work)
fungus
Try this:
Code: [Select]
 WS2811 demo
#include <Arduino.h>
#include <util/delay.h>
 Pin mappings for different chips
#if defined (__AVR_ATtiny85__)
#define LED_DDR DDRB
#define LED_PORT PORTB
#define LED_PIN PINB
#define LED_BIT _BV(3)
#elif defined (__AVR_ATtiny84__)
#define LED_DDR DDRA
#define LED_PORT PORTA
#define LED_PIN PINA
#define LED_BIT _BV(0)
#else
// Assume Arduino Uno, digital pin 8 (ie. port B, pin 0)
// See http://arduino.cc/en/Hacking/PinMapping168 for pin mappings
#endif
#define NOP __asm__("nop\n\t")
 Set the LED pin as output on startup
class WS2811 {
public:
 static void init() {
   LED_PORT &= ~LED_BIT;
   LED_DDR |= LED_BIT;
 static void sendByte(byte b) {
   byte i=8;
   do {
     if ((b&0x80)==0) {
       // Send a '0'
       if (F_CPU==16000000L) {
         LED_PIN=LED_BIT;NOP;// Hi (start)
         NOP;NOP;            // Hi
         LED_PIN=LED_BIT;NOP;// Lo (250ns)
         NOP;NOP;            // Lo
         NOP;NOP;            // Lo (500ns)
       else if (F_CPU==8000000L) {
         LED_PIN = LED_BIT;  // Hi (start)
         NOP;                // Hi
         LED_PIN = LED_BIT;  // Lo (250ns)
         NOP;                // Lo
         NOP;                // Lo (500ns)
         NOP;                // Lo (data bit here!)
         NOP;                // Lo (750ns)
     else {
       // Send a '1'
         NOP;NOP;            // Hi
         NOP;NOP;            // Hi (250ns)
         NOP;NOP;            // Hi
         NOP;NOP;            // Hi (500ns)
         LED_PIN=LED_BIT;    // Lo (625ns)
         NOP;                // Hi
         NOP;                // Hi (250ns)
         NOP;                // Hi
         NOP;                // Hi (500ns)
         NOP;                // Hi (data bit here!)
         LED_PIN = LED_BIT;  // Lo (750ns)
     b = b+b;
   } while (--i!=0);
WS2811 ws2811;
 LED object
class LED {
 byte r_,g_,b_;
public:
 LED& setColor(byte r, byte g, byte b) {
   r_ = r;
   g_ = g;
   b_ = b;
 // nb. Interrupts must be disabled when you call this (use "cli()")
 void send() const {
   ws2811.sendByte(g_);
   ws2811.sendByte(b_);
   ws2811.sendByte(r_);
 Three LEDs
LED led1,led2,led3;
void sendLEDs()
 // Interrupts off
 cli();
 // Send 60 LEDs
 for (byte i=0; i<20; ++i) {
   led1.send();
   led2.send();
   led3.send();
 // Interrupts on again
 sei();
 Testing on the Mega328
 // Initialize ws2811 object
 ws2811.init();
 // Set LED colors
 byte a = 0x00;
 byte b = 0xff;
 led1.setColor(b,b,a);
 led2.setColor(a,a,b);
 led3.setColor(a,b,b);
 // Update LEDs
 sendLEDs();
 // Wait one second
 _delay_ms(1000);
 // Swap the LEDs around
 LED t = led1;
 led1 = led2;
 led2 = led3;
 led3 = t;
Connect the green wire to Arduino pin 8 and the white wire to Arduino GND.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
Renizy
okay that sample code worked for me very well. After I flipped around my strips so I was using the right input T-T
I was wondering if someone could elaborate on how it all works?
I have worked out that the A is 0 and B is 1 or at least A makes one of the colors turn off in the RGB on and then B make them turn on and that I can add more to the led1-led3 and make more than 3 in a row changing color.
so if the first part of the coding has the timing that sends out the on and off how would I add more precise color changing to my strip like having it make R255, G128, B000, hex color ff8000, which should be orange in color.
fungus
led1.setColor(255,128,0);
Oh, and some strips have the colors switched around. You might need to change the "send()" function in the LED class to this:
Code: [Select]
  void send() const {
Renizy
Okay I have fiddled with it for a while.  I have found that the best results are from using the ws2811.h library from  http://bleaklow.com/2012/12/02/driving_the_ws2811_at_800khz_with_a_16mhz_avr.html and the code that this guy made https://www.youtube.com/watch?v=qwWkKQoja8s  I am do not have a mic to hook up to it at the moment but they do make a really pretty color flow with nothing but the lights attached on my arduino uno. http://www.amazon.com/gp/product/B006H06TVG/ref=oh_details_o03_s00_i00?ie=UTF8&psc=1
Basically what I want to do is use either a few buttons, or a few pots (I have both) to switch between light patterns.
thanks for any help.
