Topic: Proposed update for the printFloat code of print.cpp (Read 11575 times) previous topic - next topic
dariosalvi
how do I use this library?
if I just import it, I can't instantiate any Print object because it's virutal...
Any suggestion?
aweatherguy
You don't directly instantiate it. This is a replacement for the Print.cpp file in the hardware/arduino/avr/cores/arduino directory. You overwrite the files in that directory with the new ones. This re-defines the print class which propagates to Serial, HardwareSerial and so on.
If you do this, then you must do it again everytime you update the Arduino IDE installation because that will re-install a default Print.cpp file.
robtillaart
Included updated code for print.cpp and print.h work with IDE 1.8.1
This is not the latest version IDE and I will check 1.8.5 compatibility a.s.a.p.
This code also prints 64 bit integers, signed and unsigned.
(so you can get that prime sieve beyond 32 bit)
Unfortunatelly I did not have time to test all integers and floats ;)
so remarks and comments are welcome.
Rob Tillaart
robtillaart
#18
Oct 09, 2017, 01:45 pm Last Edit: Oct 09, 2017, 01:45 pm by robtillaart
Checked compatibility with IDE 1.8.5 ==> OK
Rob Tillaart
seradu
aweatherguy.... I follow your instruccions and replace both files print.h and print.cpp into my directory
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino... but it is still not working.
My example code is:
double Wo = 500;
double L5 ;
double resultado;
            L5 = pow(Wo,5);
            Serial.println(L5);
            resultado = L5 - (L5-2);//31249999999999;
            Serial.println(resultado);
            while(1);
And the serial monitor is showing
ovf
2.00
I even try removing the files (print.h, print.cpp) from the directory, expecting to see a error message. But de IDE still showing
ovf
2.00
robtillaart
#20
Dec 09, 2017, 08:45 pm Last Edit: Dec 09, 2017, 08:45 pm by robtillaart
@seradu
You might need to stop all instances of the IDE before the new version is used.
Rob Tillaart
dlcflv
I see that this topic is still there and the standard printFloat is not yet (after 7 years!) supporting exponential notation.
Anyway, I tried your code posted in replay #17 with the example posted in replay #10, and I get the error:
       'SCI' was not declared in this scope
If I use the definition suggested in replay #2, I get the error:
no matching function for call to 'HardwareSerial::println(float&, int, int)'
Where is the trick?
I'm using IDE 1.8.12 and I tested the code on an Arduino Uno.
Thank you for your suggestions
