Topic: inet.httpGET - submitting sensor data in char* path (Read 2714 times) previous topic - next topic
nchstp30
Now i got one more problem with inet.httpGET char*path below. the following syntax is working
inet.httpGET("api.pushingbox.com", 80, "/pushingbox?devid=v****8&Temperature=30.65", msg, 0);
But I need to put a variable in place of 30.65 in a void loop() as in the following code
float Temp;
Temp  =  analogRead(tempPin);
inet.httpGET("api.pushingbox.com", 80, "/pushingbox?devid=v****8&Temperature=?Temp?", msg, 0);
What should i place instead of ?Temp? in above line?
Thank you
--Santhosh
