Topic: Sketch for making a Voice call with single push of a button - Not working... (Read 3697 times) previous topic - next topic
bishkot
Hi to all
i have this sketch
Code: [Select]
// libraries
#include <GSM.h>
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess; // include a 'true' parameter for debug enabled
GSM_SMS sms;
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 6;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  // initialize serial communications
  Serial.println("SMS Messages Sender");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, HIGH);
  if(vcs.voiceCall("+12345678"))
          Serial.println("Call Established. Enter line to end");
          // Wait for some input from the line
          while(Serial.read()!='\n' && (vcs.getvoiceCallStatus()==TALKING));
          // And hang up
          vcs.hangCall();
        Serial.println("Call Finished");
  else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
But i get error while trying to upload it.
Please can anyone post a working sketch for making a voice call with press of a button (not with asking to enter a phone number etc..) only press of a button and then call
Thanks
bishkot
This is compiling and uploading with no problem...can someone let me know if it will work
Code: [Select]
#include <GSM.h>
#include <GSM3CircularBuffer.h>
#include <GSM3MobileAccessProvider.h>
#include <GSM3MobileCellManagement.h>
#include <GSM3MobileClientProvider.h>
#include <GSM3MobileClientService.h>
#include <GSM3MobileDataNetworkProvider.h>
#include <GSM3MobileMockupProvider.h>
#include <GSM3MobileNetworkProvider.h>
#include <GSM3MobileNetworkRegistry.h>
#include <GSM3MobileServerProvider.h>
#include <GSM3MobileServerService.h>
#include <GSM3MobileSMSProvider.h>
#include <GSM3MobileVoiceProvider.h>
#include <GSM3ShieldV1.h>
#include <GSM3ShieldV1AccessProvider.h>
#include <GSM3ShieldV1BandManagement.h>
#include <GSM3ShieldV1BaseProvider.h>
#include <GSM3ShieldV1CellManagement.h>
#include <GSM3ShieldV1ClientProvider.h>
#include <GSM3ShieldV1DataNetworkProvider.h>
#include <GSM3ShieldV1DirectModemProvider.h>
#include <GSM3ShieldV1ModemCore.h>
#include <GSM3ShieldV1ModemVerification.h>
#include <GSM3ShieldV1MultiClientProvider.h>
#include <GSM3ShieldV1MultiServerProvider.h>
#include <GSM3ShieldV1PinManagement.h>
#include <GSM3ShieldV1ScanNetworks.h>
#include <GSM3ShieldV1ServerProvider.h>
#include <GSM3ShieldV1SMSProvider.h>
#include <GSM3ShieldV1VoiceProvider.h>
#include <GSM3SMSService.h>
#include <GSM3SoftSerial.h>
#include <GSM3VoiceCallService.h>
// libraries
#include <GSM.h>
GSM_SMS sms;
GSMVoiceCall vcs;
// set pin numbers:
 // connection state
 // Start GSM shield
 while(notConnected)
   // turn LED on:
 if(vcs.voiceCall("0887087696"))
         // And hang up
         vcs.hangCall();
Question 1 : will it work if i connect directly pin 2 to 5V with a button so by pressing it will make connection between pin2 and 5V or it is nessecary to connect pin2 to GND with 10K resistor and with switch to 5V
Question 2: as i understand arduino gsm shield and arduino uno are connected to upload our sketch. After we have uploaded our sketch, will the gsm shield work without the arduino uno i we power it up with the 5V (given normally from the arduino uno to the gsm shield) or they need to be connected together all the time to work.
Thanks
zorzano
Hi:
Remember you have to add the voice circuit for the sketch to run, if you want to be able to hold a conversation.It is described here: http://arduino.cc/en/Main/ArduinoGSMShield
Regarding the questions:
1-Use the resistor, otherwise when the switch is open the input would be a random value.
2.-The Shield has to be connected to the Arduino UNO. The Arduino runs the sketch and sends commands to the shield (such as "call", "hang", etc...)
