Topic: Sleep mode demo code (Read 13980 times) previous topic - next topic
jabella78
#15
Apr 23, 2014, 12:01 am Last Edit: Apr 23, 2014, 12:05 am by jabella78 Reason: 1
Hi everyone,
I was wondering if adding an astable 555 timer instead of a button to wake up from sleep mode my attiny 85 will draw more power than a simple delay cycle.
JChristensen
Hi everyone,
A 555 will draw power continuously, so no that would not be the lowest power solution.
Not sure exactly what you mean by "a simple delay cycle".
Give us a little more detail on what you're trying to accomplish and maybe we can be of a little more help.
jabella78
I have an attiny 85 checking every 10 seconds the temperature of the room and decides to power on the AC via 38khz LED.
This is the code:
Code: [Select]
#include <IRTinyTX.h>
float temp;
int tempPin = 3;
int on_off = 1;
unsigned int rawCodes[] = {8850,  4500, 600,  1650, 600,  1650, 600,  550, 600,  600, 550,  550, 600,  550, 600,  550, 600,  1700, 550,  550, 600,  1650, 600,  1650, 650,  550, 600,  550, 600,  550, 600,  550, 600,  550, 600,  550, 600,  550, 600,  1650, 600,  550, 650,  500, 600,  550, 600,  550, 600,  600, 600,  500, 650,  1650, 600,  500, 650,  550, 600,  550, 600,  550, 600,  1650, 600,  550, 600,  550, 600,  600, 550,  550, 600,  600, 600,  550, 600, 500, 600,  550, 600,  600, 600,  550, 600,  550, 600,  550, 600,  550, 600,  550, 600,  550, 600,  550, 600,  550, 600};
IRsend irsend;
   for (byte i=0; i<5; i++) {
     pinMode(i, INPUT);
     digitalWrite(i, HIGH);
   digitalWrite(tempPin, LOW);
   pinMode(1, OUTPUT);
   digitalWrite(1, LOW);
  temp = analogRead(tempPin);
  temp = temp * 0.48828125;
  if (temp > 26.00 && on_off == 0) {
      irsend.sendRaw(rawCodes, 99, 38);
       on_off = 1;
  else if (temp < 24.00 && on_off == 1) {
        on_off = 0;
  delay(10000);
Instead of delay(10000) I was wondering if implementing your code with a 555 as  trigger, the power consumption would be less.
JChristensen
Beats me, really, without checking a 555 data sheet. I'm not current on the CMOS versions, I imagine they draw less current than the older bipolar types.
But why not use the watchdog timer to wake the MCU? No additional hardware needed, and I'd bet that the ATtiny85 sleeping with just the WDT running will draw less current than any 555 (should be on the order of 4-6µA).
Checking every 10 seconds seems maybe a bit excessive but done properly it shouldn't make all that much difference to the energy budget. I might also keep a running average over about a minute or something like that. Might make for smoother operation but I see there is already some hysteresis built in so that is good.
jabella78
#19
Apr 23, 2014, 09:21 pm Last Edit: Apr 23, 2014, 09:28 pm by jabella78 Reason: 1
Just see how to set watchdog timer!
Should this work?
Code: [Select]
#include <avr/sleep.h>
#include <avr/wdt.h>
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
float temp;
volatile boolean f_wdt = 1;
int tempPin = 3;
int on_off = 0;
IRsend irsend;
     pinMode(i, INPUT);
   pinMode(1, OUTPUT);
   setup_watchdog(9);
   if (f_wdt==1) {  // wait for timed out watchdog / flag is set when a watchdog timeout occurs
    f_wdt=0;       // reset flag
       on_off = 1;
        on_off = 0;
  system_sleep();
void system_sleep() {
  cbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter OFF
  set_sleep_mode(SLEEP_MODE_PWR_DOWN); // sleep mode is set here
  sleep_enable();
  sleep_mode();                        // System sleeps here
  sleep_disable();                     // System continues execution here when watchdog timed out
  sbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter ON
// 0=16ms, 1=32ms,2=64ms,3=128ms,4=250ms,5=500ms
// 6=1 sec,7=2 sec, 8=4 sec, 9= 8sec
void setup_watchdog(int ii) {
  byte bb;
  int ww;
  if (ii > 9 ) ii=9;
  bb=ii & 7;
  if (ii > 7) bb|= (1<<5);
  bb|= (1<<WDCE);
  ww=bb;
  MCUSR &= ~(1<<WDRF);
  // start timed sequence
  WDTCR |= (1<<WDCE) | (1<<WDE);
  // set new watchdog timeout value
  WDTCR = bb;
  WDTCR |= _BV(WDIE);
// Watchdog Interrupt Service / is executed when watchdog timed out
ISR(WDT_vect) {
  f_wdt=1;  // set global flag
Thank you for suggestion, appreciated!
gvgv
#20
Aug 14, 2015, 08:36 am Last Edit: Aug 14, 2015, 08:37 am by gvgv
Hello
I tried to put up this example with Attiny85, but it does not seem to work. When I ground PB2, the led flashes once (5 times). If I repeat the procedure disconnecting and connecting PB2 to ground, the led does not flash any longer. It looks like the interrupt works only for the first pin change. I have not changed fuses - I am not yet comfortable with that. Could it be the reason the example does not work or am I expecting something that should not work?
Also, I've seen a number of posts advising that to save power one should use lower voltage (3.3V) and lower micropocessor speed (1MHz). Example here. Jack's example suggests running at 8 MHz and on 5V. So where is the truth?
kowalski
Yes
Yes
gvgv
With regard to the first "Yes" - it is yes, that I am expecting something different than Jack's example was supposed to do?
kowalski
Yes, the fuse setting is important for the behavior.
hmeijdam
Hello
I experienced the same result the first time, testing on attiny85. What actually is causing this problem is that if PB2 is at ground when it goes to sleep, you cannot wake it up anymore. It seems to be important that PB2 is at HIGH when entering sleep state.
I would like it to work that if PB2 is at ground it won't go to sleep.
so I changed:
Code: [Select]
goToSleep();
into
Code: [Select]
if (digitalRead(PB2) == HIGH) goToSleep();  //  to avoid to go to sleep when PB2 is still low, as then it will not wake up again
And got what I want.
