Topic: FREE: Arduino plugin for Atmel Studio (Read 17077 times) previous topic - next topic
visualmicro
May 21, 2013, 10:19 pm Last Edit: Jun 03, 2013, 03:47 am by Visual Micro Reason: 1
The Atmel Studio IDE is created by the manufacturer of the Arduino micro-controller and is free. Atmel Studio is based on Microsoft Visual Studio 2010 so this is a great combination for many windows users (mac supported using VMWare)
It has been a lot of fun creating the free Arduino plugin for Visual Studio but even more fun making it work with Atmel Studio. There are still a few rough edges but the plugin does already include a huge number of unique features that help make coding for Arduino more fun.
Read more
High Speed Arduino Compiler, Intellisense, Code Completion
The plugin replicates all of the important features of the Arduino Ide and ensures that sketch projects remain fully compatible with the Arduino Ide. There are no configuration changes required to open and compile any Arduino project.
The plugin works with the various version of Arduino (1.0.5,1.5 beta for 2 weeks), no need to reload the Ide to switch between versions. Similarly, the Arduino sketch book folder can be altered and new libraries can be automatically detected without need to re-start the Ide.
The plugin also provides intellisense and optional debugging. The usb debugger is simple but effective and has just been released after 6 months of beta testing by team of 3000 people.
Beta support for arduino 1.5 is included in the (Beta Channel) on the visual micro downloads site (arduino 1.0.4 recommended for the next week or two). An official Atmel patch is required to enable advanced functions or debugging, the patch is only available from the visual micro web site.
Installation takes less then 10 minutes, after install, if you find that color coding does not work in .pde/.ino files please install the latest beta of the visual micro plugin. The beta is mature and will be released in a few days (mac users need the beta to activate the debugger)
Examples and Tutorials Wizard
You will find a dedicated wiki and active forum at Visual Micro
Arduino for Microsoft Visual Studio Pro and Atmel Studio 6.1 http://www.visualmicro.com
Arduino Debugger http://www.visualmicro.com/post/2012/05/05/Debug-Arduino-Overview.aspx
visualmicro
#1
May 22, 2013, 12:44 am Last Edit: May 23, 2013, 02:10 am by Visual Micro Reason: 1
added Arduino Plugin in Atmel Studio on YouTube no sound but quick overview of some features
The standard Arduino plugin and Atmel Studio are free, BUT if you buy the debugger for the current special offer of $15 I won't complain. Thanks, I hope to raise enough for professional documentation  :)
garballz
CrossRoads
Does it still take forever for Atmel Studio to start up?  (WinVista on Sony Vaio laptop)
I was using it for a while to bootload '1284P chips, but soon got tired of the minutes long start up time and found out how to the change the MKii driver so the IDE could use it.
KirAsh4
It takes about a minute or so on my desktop, 3.6GHz processor, 16Gb RAM, running Win7 Ultimate.
visualmicro
Thanks garballz
@CrossRoads, I have a vista machine at work which only has 1gb of ram. It's a bit slow but VS 2010 and Atmel Studio do take a long time to start up (couple of minutes sometimes). On my win7 machine Atmel Studio takes about 17 seconds, which is slow because the machine is fast. So we can certainly loose some project time waiting for start-up but then the plugin gives so many other savings that for most users the start-up time will be fine. The faster compiler times alone might entirely negate the start-up time, especially for less expert users like myself that have to test every small code change with compile and upload.  As concerns drivers and board settings, this solution does not use any of the standard Atmel config settings, it will use whatever you have set for the standard Arduino IDE. It uses the same cores, boards.txt, libs etc and logic as the arduino ide.
Docedison
@ Tim, I use Enried's Modded Ver 1.04 IDE with Coding Badly's tiny cores. It works well for me and I'm really interested in the debugging thing. Will your application support all of that and where do I sign up for the debugger?.
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
visualmicro
#7
May 23, 2013, 12:03 am Last Edit: May 23, 2013, 01:40 am by Visual Micro Reason: 1
Hi Docedison,
The plugin supports custom cores, I've compiled tiny45/85 in the past if I recall. It also supports a number of additional core options which allow it to compile Arduino code into some pretty diverse applications such as the cygwin "Software In The Loop" SITL system from diydrones.com
So the answer to the question about the cores should be yes, if you uncover anything that needs attention then please report to the visualmicro.com forum and it will be fixed for the next release. To save time, also provide links to download for the core but I would expect it to work.
I suggest pointing Visual Micro to arduino 1.0.4 because from what you say the combination is already tested.
As far as the debugger is concerned it's worth a try. Simply activate the 30 day trial when you run the software or when you attempt to enable the debugging.
There are a couple of points to keep in mind, the debugger is a software debugger. The amount of memory it requires depends on the functions you are already using in your project. I don't know the capacity of your board or the size of your code.
If you have serial print statements in your code for debug then you will find they can be removed and replaced with breakpoints and custom messages which will take less memory because breakpoint message strings are not stored/compiled onto the Arduino. Some newer users have reclaimed 1.7k of ram by doing this. So this works well for some :) (edit: always remember to click OK and save your Atmel solution file when prompted, this is because breakpoints are stored in the solution and not with each project)
Finally, by default, the debugger relies either on serial or softwareSerial. The "serial" must use arduino 1.x format and not 0023 and earlier.
If you find time to try it all out then skip the first couple of minutes of this video and it shows how to switch on some basic debug features http://youtu.be/fFM8_RhIG0U
Thanks
Docedison
Thank You Sir.. I asked because there are others like myself that don't always use an Arduino Uno for code and any little advantage helps. Although there isn't a lot of spare room in many of the smaller chips...  Once the code is debugged and works in a bigger one porting most code can be easily done.
Doc
--> WA7EMS <--
KirAsh4
I actually timed it this time:
20 seconds before the splash screen shows up
58 seconds till it's fully opened ready to start using
visualmicro
#10
May 23, 2013, 01:29 am Last Edit: May 23, 2013, 02:03 am by Visual Micro Reason: 1
Okay, but if you pedal faster it might load quicker  :)
Seriously though here are some productivity gain examples:-
1) Make 1 compile, then modify something in the sketch source code, then make another compile. Hopefully, the re-compile is very fast and saves some time.
2) Use the "update variable" facility to test different values with the debugger, this avoids the need to re-compile and upload so often.
3) Of course, just having intellisense, means that most of us (non-experts) have to go hunting for reference material much less often which is a huge time saver.
4) The facility to inspect analogs, digitalpins, registers, expressions and sensor/variable values with the debugger saves me having to dig out old reference guides for the various bits of hardware that I use from time to time.
5) If you change sketchbook folder very often, or want to switch between arduino versions or if you edit your own custom hardware (boards.txt) files is the fact that the ide does not need to be re-started. The UI can auto detect and reload all cores and libs without even the need to close the current sketch.
6) Atmel Studio comes with VisualAssistX which not only gives great code explorers but also provides code re-factoring. This is a superb set of tools that allow us to easily (single click) re-structure the code of our projects.
All in all, I think we have some huge productivity gains with Atmel Studio but I agree it is nice to have an ide that opens really quickly.
Visual Studio 2012 opens really fast, I hope Atmel use the VS 2012 shell for the next major release of Atmel Studio. I really like Vs2012 and it works very well for Arduino development, you can see some images on the visual micro web site.
EDIT: here is a youtube example of Atmel starting in a relatively short time. Notice I ensure that the Atmel Start-up page and ASF explorer are closed. I don't use those windows very often and they slow start-up time. Win7 64bit i7/8gb.  http://youtu.be/RQkOLCWEAcc
garballz
One big thing I have noticed is the recompile speed when using the Due.
Just a couple of re-compiles will negate any Studio start-up penalty compared to using the standard Arduino IDE.
Visual Micro is an order of magnitude faster on the re-compiles!
JChristensen
Just vanilla Atmel Studio on Win8 Pro, 3.4GHz Core i7, takes at least 30 seconds. Seems like forever.
visualmicro
obiwanjacobi
What would be the recommended way of unit testing Arduino code on Atmel Studio /w the Arduino plugin?
Currently I use the standard Visual Studio 2010 with the Visual Micro plugin and the out of the box Unit Test project template that comes with VS2010.
Do you guys use other Unit testing frameworks or...??
