Topic: Can't compile anything (Read 1 time) previous topic - next topic
AlephNull37
When I try to run something as simple as -
I get this error (orange text) -
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void store_char(unsigned char, ring_buffer*)':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:98: warning: comparison between signed and unsigned integer expressions
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void __vector_18()':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:127: warning: unused variable 'c'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'void HardwareSerial::begin(long unsigned int, byte)':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:368: warning: unused variable 'current_config'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'virtual size_t HardwareSerial::write(uint8_t)':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:467: warning: comparison between signed and unsigned integer expressions
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\Print.cpp: In member function 'size_t Print::print(const __FlashStringHelper*)':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\Print.cpp:44: warning: '__progmem__' attribute ignored
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\Tone.cpp:119: warning: only initialized variables can be placed into program memory area
I've tried clearing my temp directory, deleting and reinstalling arduino, compiling with no board connected.
Any ideas?
AlephNull37
CrossRoads
aleandrogreete
I have this issue too (IDE 1.05) but I can reproduce on my Win7/64bit only within this conditions:
- Clearing temp dir (arduino ide should not running)
- Verbose out during compilation on settings
Just first compile shows the errors, all subsequential ones doesn't, and all works as expected.
