Topic: Multiplexing inputs of 24V, how do i reduce the voltage (Read 7609 times) previous topic - next topic
Grumpy_Mike
Quote
What made it work with this multiplexer was adding a resistor between the A0 - A3 pins to the GND.
This would not be needed if you connected the A0 to A3 pins to Arduino output pins, and had the sketch set them to outputs and had the outputs set to low.
If you left them unconnected they were floating.
http://www.thebox.myzen.co.uk/Tutorial/Inputs.html
Yarash
I figured that out later on :)
When i did a manual test using a multimeter
I had to use the resistors, but as you said, with the
Arduino there was no need.
Thanks
