Topic: Helicopter - autopilot (Read 3124 times) previous topic - next topic
Rixterz
Hello
I am making a project where my helicopter gradually starts up it's 4 motors as an autopilot feature, but i do not know how to slowly increase the speed from 0 to speed X (whatever speed it hovers at).
The helicopter looks like this from above:
                motor
motor -----arduino-----motor
                 motor
I only got my arduino yesterday so i really need help on these little things before my project can truly begin.
Thanks in advance- any functions that you can think of would be useful :)
johnwasser
Speed control is usually done with analogWrite().
Increasing slowly from 0 is usually done with a loop:
Code: [Select]
for (int speed = 0; speed <= HOVER_SPEED; speed++) {
    analogWrite(Motor1Pin, speed);
    analogWrite(Motor2Pin, speed);
    analogWrite(Motor3Pin, speed);
    analogWrite(Motor4Pin, speed);
    delay(RampUpDelay);  // The higher the number the slower the ramp
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Rixterz
AWOL
Quote
...but if you want to do other stuff, like looking at gyros or accelerometers, you're probably best not using for loops, and doing the work of the loop  explicitly as part of a state machine.
GunnerCAF
#4
Jul 22, 2013, 06:18 am Last Edit: Jul 22, 2013, 06:23 am by GunnerCAF Reason: 1
I am working on a single motor airplane, and I am not using delays.  This is the function I am using to ramp up and down the motor speed:
Code: [Select]
/* ========================== MOTOR POWER ==========================
/ GWS ICS-300E
/ note: min power = 70, full power = 120
/ This ramps up or down the power settings for smooth power changes
void motorPower() {
 if (millis() >= motorTimer) {                // check motor timer
   motorTimer = millis() + 30;                // set next timer
   if ((motorTarget + mv) > motorVal) {       // if target speed is greater than current setting
     motorVal++;                              // increment motor power setting
   if ((motorTarget + mv) < motorVal) {       // if target speed is less than current setting
     motorVal--;                              // deincrement motor power setting
   motorVal= constrain((motorVal), 60, 130);  // limit motor values
   motorServo.write(motorVal);                // adjust power to new value
motorTimer = Every 30 ms the speed continues the ramp up or ramp down.
motorTarget = This is my target motor speed
motorVal = Current motor speed
mv = This is a value from my radio control so I can override the autopilot if needed.
Maybe you can get some ideas from this for your project.
Good luck,
Dave
