Topic: How to erase WHITE TEXT from a PCB (Read 11925 times) previous topic - next topic
nemo4all
I have some PCBs from which I would like to remove the WHITE TEXT on the component side as well as the copper layer side.. As it is hiding some tracks.. I do not want to scratch it as the mask will come off..
What chemical will remove the texts.??
majenko
You probably won't be able to - not without damaging the PCB or the solder mask.
CrossRoads
Its some kind of paint. You could try paint thinner, mineral spirits, turpentine.
Are you trying to modify the traces underneath?
majenko
It is unlikely any of those will work.  The "paint" is resistant to neat isopropanol (isopropyl alcohol) which is used to clean PCBs.
dc42
It might be worth trying white spirit or acetone - they will dissolve many things that isopropanol won't.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
MarkT
Might dissolve the solder mask too though...  Soldermask is tough, so fine emery paper might remove the
paint before the solder mask is too badly scratched?  For small areas a sharp knife / scalpel could be used to carefully
scrape the paint away.
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
fungus
Maybe do a small test before dunking the board...?
Advanced Arduino
Docedison
The white legend or silk screen layer is not soluble in any solvent you'd want in your house and in a special locker if at all. The paint is usually a 2 part epoxy and in 40 years of doing PC boards I've never managed to remove it as a process with any solvent including various concoctions containing chlorinated hydrocarbons... It is most tough, It has to be to look pretty after the shake and bake of PCB assembly and testing...
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
majenko
Aqua Regia (nitro-hydrochloric acid) will get it off.  It'll also get off the solder mask, the copper tracks, the skin from you hands, the muscles from your bones, the bones from what's left of your hands...   Nasty stuff...
Docedison
That or for small "corrections" a Dremel or motorized hobby grinder works but it is sure a lot of work and short of "Water of Kings" about the only thing I've ever found that did
--> WA7EMS <--
sonnyyu
Dissolve epoxy resin might be day to day job for people do reverse engineering.
There are off-the-shelf  epoxy resin dissolver solvent available;-
"Attack" Epoxy Resin and Adhesive Dissolver Solvent Remover & Cleaner
www.esslinger.com, $12.95
Safe for use on metal, stones, glass, and wood
The plastic is missing here, since solvent might be very aggressive to most types of plastic.
I guess either holohil.com replace new case or use customer solvent which safe for case.
Your university has chemical department?  It should be a piece of cake jobs to make customer solvent.
westfw
Don't forget that the solder mask and the PCB itself are probably built from the same plastic (epoxy) as the silkscreen ink.
Docedison
#12
May 31, 2013, 09:48 am Last Edit: May 31, 2013, 10:23 am by Docedison Reason: 1
The reason I say that you don't want them in anything but an isolated fire buffer is that those chemicals are toxic... to most of the body, liver spleen and kidneys. Really strictly bad news for certain types of black Epoxy used to pot some TI TMS 7K processors and the roms were potted most carefully... But that was 30 years ago. Perhaps things are different now.
Bad News chemicals. Then.
Doc
--> WA7EMS <--
fungus
Do you know what "ROHS" stands for?
Advanced Arduino
majenko
Really Obtuse High-cost Standard.
A system imposed by bureaucrats who don't have a clue about the real world - they just sit there in their ivory towers having their egos massaged by a dozen spotless virgins passing down idiotic dictates that make no sense at all to us proles.
And anyway it's RoHS.
