Topic: Pin mapping a ATmega2561 (Read 10425 times) previous topic - next topic
stank
Hello,
I am interested in using a ATmega2561 in place of the Atmega2560 on a custom PCB. I have looked around in the files and can't figure out what needs to be done. I know the internal functions are the same on each part but the 2561 has four less ports. Can any one direct me to the correct way to do this.
Thanks
StanK
CrossRoads
You need to create a new section in boards.txt for a '2561 board, with the details of the chip.
Also, make some edits to pins_arduino.h to  add the '2561 as a recognized processor type, or make a new variant.
Atmega2561 is already in avrdude.conf, so no changes needed there:
Code: [Select]
# ATmega2561
part
    id               = "m2561";
    desc             = "ATMEGA2561";
    signature        = 0x1e 0x98 0x02;
stank
Thanks for the reply, I have looked over the files you mentioned. I presume that the AVRDUDE  assigns the actual pins numbers to  the pin names, is that correct? If so, I should only have to delete the ports and associated pin names that are not on the 2561. I don't know where the information you sent me regarding the part ID and such, go?
StanK
CrossRoads
The pin mappings are called out in pins-arduino.h
The stuff from avrdude.conf just needed to exist.
The boards.txt entry needs to reflect the same name that avrdude.conf calls.
If you go here
https://github.com/maniacbug/mighty-1284p
you can see the kind of things that were setup for the 1284P chip. The 2561 is in between the 1284 and the 2560,
so  you'll need  a pins_arduino.h that will be in between the 2 as well.
stank
Bob,
I have no idea what the labels NOT_A_PORT or NOT_A_TIMER mean or how they are used.
I cant figure out what order of the const to PROMEM means, such as,
const uint8_t PROGMEM digital_pin_to_port_PGM[] = {
   // PORTLIST
   PE   , // PE 0 ** 0 ** USART0_RX
   PE   , // PE 1 ** 1 ** USART0_TX
   PE   , // PE 4 ** 2 ** PWM2
   PE   , // PE 5 ** 3 ** PWM3
Nor do I know what to program the fuses to in the boards.txt file, i.e.
mega.bootloader.high_fuses=0xDA
mega.bootloader.extended_fuses=0xF5
I really don't know what I am doing here.
StanK
CrossRoads
There are 3 large arrays, of which you've copied part of the first.
The first list the ports that are assigned from D0 down to whatever the highest D# will be.
The 2nd assigns the bits for a specific port
So if the first started
PE,
PE,
PE,
PE,
PD,
PD,
PD,
PD,
and the second started
0,
1,
2,
3,
7,
6,
5,
4,
then DO would map to PORTE-Bit0
D1 >> PE1
D2>> PE2
D3>> PE3
D4>>PD7
D5>>PD6
D6>>PD5
D7>>PD4
And in the 3rd array:
the pins that not have OCxA or OCxB would have
NOT_A_TIMER,
while pins that Did have OCxA or OCxB would be
TIMER (or whatever it is)
to indicate they are PWM capable output pins.
There are other lines that assign PCINT #s to the pins, and that assign the Analog numbers to the ADC pins.
I have a hard time interpreting those as written, would have been easier if those were arrays as well.
Get the 3 arrays set up, post what you have, see if one of the software guys will jump into the conversation.
stank
OK,
I'll try to put these files together. It may be a little while but when I do I'll post it.
Till then
StanK
CrossRoads
Might be easier to study the 2560 section of the distributed pins_arduino.h, make a copy and strip out the unsupported ports, and clean up  some.
Then copy the boards.txt section of 2560, rename the lines for a new 2561, and, callout the correct  chip.
stank
Hello,
I am back with my pins_arduino.h for the ATmega2561.  If you care to take a look at it, maybe you can find any errors. I don't know if I correctly modified the second set of definitions where I have maked them old/new. I am not sure how to write these definitions.
I arranged the pins in an order that reflects the pin order of the chip pins.
What do you think? Oh, I left off the last table because the file was to big
Stank
Code: [Select]
 $Id: wiring.h 249 2007-02-03 16:52:51Z mellis $
#ifndef Pins_Arduino_h
#define Pins_Arduino_h
#include <avr/pgmspace.h>
#define NUM_DIGITAL_PINS            54
#define NUM_ANALOG_INPUTS           8
#define analogInputToDigitalPin(p)  ((p < 8) ? (p) + 46 : -1)
//old#define analogInputToDigitalPin(p)  ((p < 16) ? (p) + 54 : -1)
#define digitalPinHasPWM(p)         (((p) >= 3 && (p) <= 5) || ((p) >= 12 && (p)<= 15))
//old#define digitalPinHasPWM(p)         (((p) >= 2 && (p) <= 13) || ((p) >= 44 && (p)<= 46))
static const uint8_t SS   = 8;
static const uint8_t SCK  = 9;
static const uint8_t MOSI = 10;
static const uint8_t MISO = 11;
static const uint8_t SCL = 16;
static const uint8_t SDA = 17;
static const uint8_t LED_BUILTIN = 13;
static const uint8_t A0 = 53;
static const uint8_t A1 = 52;
static const uint8_t A2 = 51;
static const uint8_t A3 = 50;
static const uint8_t A4 = 49;
static const uint8_t A5 = 48;
static const uint8_t A6 = 47;
static const uint8_t A7 = 46;
// A majority of the pins are NOT PCINTs, SO BE WARNED (i.e. you cannot use them as receive pins)
// Only pins available for RECEIVE (TRANSMIT can be on any pin):
// (I've deliberately left out pin mapping to the Hardware USARTs - seems senseless to me)
// Pins: 10, 11, 12, 13,  50, 51, 52, 53,  62, 63, 64, 65, 66, 67, 68, 69
//old#define digitalPinToPCICR(p)    ( (((p) >= 10) && ((p) <= 13)) || \
//old                                  (((p) >= 50) && ((p) <= 53)) || \
//old                                  (((p) >= 62) && ((p) <= 69)) ? (&PCICR) : ((uint8_t *)0) )
#define digitalPinToPCICR(p)    ( (((p) >= 12) && ((p) <= 15)) || \
                                 (((p) >= 8) && ((p) <= 11)) || \
                                 (((p) >= 54) && ((p) <= 53)) ? (&PCICR) : ((uint8_t *)0) )
//old#define digitalPinToPCICRbit(p) ( (((p) >= 10) && ((p) <= 13)) || (((p) >= 50) && ((p) <= 53)) ? 0 : \
//old                                ( (((p) >= 62) && ((p) <= 69)) ? 2 : \
//old                                0 ) )
#define digitalPinToPCICRbit(p) ( (((p) >= 12) && ((p) <= 15)) || (((p) >= 8) && ((p) <= 11)) ? 0 : \
                               ( (((p) >= 54) && ((p) <= 53)) ? 2 : \
                               0 ) )
//old#define digitalPinToPCMSK(p)    ( (((p) >= 10) && ((p) <= 13)) || (((p) >= 50) && ((p) <= 53)) ? (&PCMSK0) : \
//old                                ( (((p) >= 62) && ((p) <= 69)) ? (&PCMSK2) : \
//old                                ((uint8_t *)0) ) )
#define digitalPinToPCMSK(p)    ( (((p) >= 12) && ((p) <= 15)) || (((p) >= 8) && ((p) <= 11)) ? (&PCMSK0) : \
                               ( (((p) >= 54) && ((p) <= 53)) ? (&PCMSK2) : \
                               ((uint8_t *)0) ) )
//old#define digitalPinToPCMSKbit(p) ( (((p) >= 10) && ((p) <= 13)) ? ((p) - 6) : \
//                                ( ((p) == 50) ? 3 : \
//                                ( ((p) == 51) ? 2 : \
//                                ( ((p) == 52) ? 1 : \
//                                ( ((p) == 53) ? 0 : \
//                                ( (((p) >= 62) && ((p) <= 69)) ? ((p) - 62) : \
//                                0 ) ) ) ) ) )
#define digitalPinToPCMSKbit(p) ( (((p) >= 12) && ((p) <= 15)) ? ((p) - 6) : \
                               ( ((p) == 11) ? 3 : \
                               ( ((p) == 10) ? 2 : \
                               ( ((p) == 9) ? 1 : \
                               ( ((p) == 8) ? 0 : \
                               ( (((p) >= 54) && ((p) <= 53)) ? ((p) - 54) : \
                               0 ) ) ) ) ) )
#ifdef ARDUINO_MAIN
const uint16_t PROGMEM port_to_mode_PGM[] = {
NOT_A_PORT,
(uint16_t) &DDRA,
(uint16_t) &DDRB,
(uint16_t) &DDRC,
(uint16_t) &DDRD,
(uint16_t) &DDRE,
(uint16_t) &DDRF,
(uint16_t) &DDRG,
const uint16_t PROGMEM port_to_output_PGM[] = {
NOT_A_PORT,
(uint16_t) &PORTA,
(uint16_t) &PORTB,
(uint16_t) &PORTC,
(uint16_t) &PORTD,
(uint16_t) &PORTE,
(uint16_t) &PORTF,
(uint16_t) &PORTG,
const uint16_t PROGMEM port_to_input_PGM[] = {
NOT_A_PIN,
(uint16_t) &PINA,
(uint16_t) &PINB,
(uint16_t) &PINC,
(uint16_t) &PIND,
(uint16_t) &PINE,
(uint16_t) &PINF,
(uint16_t) &PING,
// PORTLIST
PE , // PE 2 ** 2 ** D2
PE , // PE 3 ** 3 ** PWM1
PE , // PE 4 ** 4 ** PWM2
PE , // PE 5 ** 5 ** PWM3
PE , // PE 6 ** 6 ** D6
PE , // PE 7 ** 7 ** D7
PB , // PB 0 ** 8 ** SPI_SS
PB , // PB 1 ** 9 ** SPI_SCK
PB , // PB 2 ** 10 ** SPI_MOSI
PB , // PB 3 ** 11 ** SPI_MISO
PB , // PB 4 ** 12 ** PWM4
PB , // PB 5 ** 13 ** PWM5
PB , // PB 6 ** 14 ** PWM6
PB , // PB 7 ** 15 ** PWM7
PD , // PD 0 ** 16 ** I2C_SCL
PD , // PD 1 ** 17 ** I2C_SDA
PD , // PD 2 ** 18 ** USART1_RX
PD , // PD 3 ** 19 ** USART1_TX
PD , // PD 4 ** 20 ** D20
PD , // PD 5 ** 21 ** D21
PD , // PD 6 ** 22 ** D22
PD , // PD 7 ** 23 ** D23
PC , // PC 0 ** 24 ** D24
PC , // PC 1 ** 25 ** D25
PC , // PC 2 ** 26 ** D26
PC , // PC 3 ** 27 ** D27
PC , // PC 4 ** 28 ** D28
PC , // PC 5 ** 29 ** D29
PC , // PC 6 ** 30 ** D30
PC , // PC 7 ** 31 ** D31
PA , // PA 7 ** 32 ** D32
PA , // PA 6 ** 33 ** D33
PA , // PA 5 ** 34 ** D34
PA , // PA 4 ** 35 ** D35
PA , // PA 3 ** 36 ** D36
PA , // PA 2 ** 37 ** D37
PA , // PA 1 ** 38 ** D38
PA , // PA 0 ** 39 ** D39
PG , // PG 0 ** 40 ** D40
PG , // PG 1 ** 41 ** D41
PG , // PG 2 ** 42 ** D42
PG , // PG 3 ** 43 ** D43
PG , // PG 4 ** 44 ** D44
PG , // PG 5 ** 45 ** PWM8
PF , // PF 7 ** 46 ** A7
PF , // PF 6 ** 47 ** A6
PF , // PF 5 ** 48 ** A5
PF , // PF 4 ** 49 ** A4
PF , // PF 3 ** 50 ** A3
PF , // PF 2 ** 51 ** A2
PF , // PF 1 ** 52 ** A1
PF , // PF 0 ** 53 ** A0
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] = {
// PIN IN PORT
_BV( 0 ) , // PE 0 ** 0 ** USART0_RX
_BV( 1 ) , // PE 1 ** 1 ** USART0_TX
_BV( 2 ) , // PE 2 ** 2 ** D2
_BV( 3 ) , // PE 3 ** 3 ** PWM1
_BV( 4 ) , // PE 4 ** 4 ** PWM2
_BV( 5 ) , // PE 5 ** 5 ** PWM3
_BV( 6 ) , // PE 6 ** 6 ** D6
_BV( 7 ) , // PE 7 ** 7 ** D7
_BV( 0 ) , // PB 0 ** 8 ** SPI_SS
_BV( 1 ) , // PB 1 ** 9 ** SPI_SCK
_BV( 2 ) , // PB 2 ** 10 ** SPI_MOSI
_BV( 3 ) , // PB 3 ** 11 ** SPI_MISO
_BV( 4 ) , // PB 4 ** 12 ** PWM4
_BV( 5 ) , // PB 5 ** 13 ** PWM5
_BV( 6 ) , // PB 6 ** 14 ** PWM6
_BV( 7 ) , // PB 7 ** 15 ** PWM7
_BV( 0 ) , // PD 0 ** 16 ** I2C_SCL
_BV( 1 ) , // PD 1 ** 17 ** I2C_SDA
_BV( 2 ) , // PD 2 ** 18 ** USART1_RX
_BV( 3 ) , // PD 3 ** 19 ** USART1_TX
_BV( 4 ) , // PD 4 ** 20 ** D20
_BV( 5 ) , // PD 5 ** 21 ** D21
_BV( 6 ) , // PD 6 ** 22 ** D22
_BV( 7 ) , // PD 7 ** 23 ** D23
_BV( 0 ) , // PC 0 ** 24 ** D24
_BV( 1 ) , // PC 1 ** 25 ** D25
_BV( 2 ) , // PC 2 ** 26 ** D26
_BV( 3 ) , // PC 3 ** 27 ** D27
_BV( 4 ) , // PC 4 ** 28 ** D28
_BV( 5 ) , // PC 5 ** 29 ** D29
_BV( 6 ) , // PC 6 ** 30 ** D30
_BV( 7 ) , // PC 7 ** 31 ** D31
_BV( 7 ) , // PA 7 ** 32 ** D32
_BV( 6 ) , // PA 6 ** 33 ** D33
_BV( 5 ) , // PA 5 ** 34 ** D34
_BV( 4 ) , // PA 4 ** 35 ** D35
_BV( 3 ) , // PA 3 ** 36 ** D36
_BV( 2 ) , // PA 2 ** 37 ** D37
_BV( 1 ) , // PA 1 ** 38 ** D38
_BV( 0 ) , // PA 0 ** 39 ** D39
_BV( 0 ) , // PG 0 ** 40 ** D40
_BV( 1 ) , // PG 1 ** 41 ** D41
_BV( 2 ) , // PG 2 ** 42 ** D42
_BV( 3 ) , // PG 3 ** 43 ** D43
_BV( 4 ) , // PG 4 ** 44 ** D44
_BV( 5 ) , // PG 5 ** 45 ** PWM8
_BV( 7 ) , // PF 7 ** 46 ** A7
_BV( 6 ) , // PF 6 ** 47 ** A6
_BV( 5 ) , // PF 5 ** 48 ** A5
_BV( 4 ) , // PF 4 ** 49 ** A4
_BV( 3 ) , // PF 3 ** 50 ** A3
_BV( 2 ) , // PF 2 ** 51 ** A2
_BV( 1 ) , // PF 1 ** 52 ** A1
_BV( 0 ) , // PF 0 ** 53 ** A0
CrossRoads
Looks pretty good so far.
Third array will be mostly NOT_A_TIMER except for the 8 PWM pins, 3-4-5, 12-15, 45
This line
Code: [Select]
need 45 in it for the 8th PWM
(Seems redundant with 3rd array, doesn't it?  Am sure there is some reason behind it tho)
This looks a little off:
Code: [Select]
as the PCINTs are only from 8 to 15.
Same for the other PCINT related sections.
I didn't check the data sheet to see if PCMSK0 is the right one for PortB
Same for PCICR.
Also
Code: [Select]
                                0 ) )
I don't know what the "? 0: \ " means on the end of the line, need some one a little smarter to explain that.
I see there are 8 hardware interrupt pins in place of PCINTs.
This note:
Was RX0, TX0, RX1, TX1 or something similar defined earlier?
stank
I included the first part of the file with this code and I left off the tables because I think they are correct and they won't fit here. I changed the digitalPinHasPWM definitions to include DP45 and the reason I have (((p) >= 54) && ((p) <= 53)) in the others, digitalPinToPCMSKxxx, is that I don't know what effect it would have if I removed the statement. The way I wrote it, the return value would be false under all conditions and wouldn't make any assignments for that part. I hope this will work. What do you think?
StanK
Code: [Select]
  pins_arduino.h - Pin definition functions for Arduino
  Part of Arduino - http://www.arduino.cc/
  Copyright (c) 2007 David A. Mellis
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General
  Public License along with this library; if not, write to the
  Free Software Foundation, Inc., 59 Temple Place, Suite 330,
  Boston, MA  02111-1307  USA
#define digitalPinHasPWM(p)         ( ((p) >= 3 && (p) <= 5) || ((p) >= 12 && (p)<= 15) || ((p) == 45 ) )
                                  (((p) >= 8) && ((p) <= 11)) ? (&PCICR) : ((uint8_t *)0) )
//old                                0 ) )
                                0 ) )
                                ((uint8_t *)0) ) )
//                                0 ) ) ) ) ) )
                                0 ) ) ) ) ) )
CrossRoads
Give it a try and do some testing.
I think the 53/54 stuff can likely be deleted from t he PCINT stuff, like you I am not sure what the  best way to clean that up is.
stank
Well, I cleaned up some of the definitions. I think I got it right except I don't know what the -6 is on this statement, It's on the origonal definition.
I still have to do the boards.txt. I am still not sure about these settings,
I suppose I could leave them as they are.
I don't have any hardware to try it on but I could try to compile it.
Code: [Select]
#define digitalPinToPCICR(p)    ( (((p) >= 8) && ((p) <= 15)) || ? (&PCICR) : ((uint8_t *)0) )
#define digitalPinToPCICRbit(p) ( (((p) >= 8) && ((p) <= 15)) ? 0 : 0 )
#define digitalPinToPCMSK(p)    ( (((p) >= 8) && ((p) <= 15)) ? (&PCMSK0) : ((uint8_t *)0) )
                                ( ((p) == 8) ? 0 : 0  ) ) ) ) )
#ifdef ARDUINO_MAIN
Also, here is the last table I didn't include before.
Code: [Select]
const uint8_t PROGMEM digital_pin_to_timer_PGM[] = {
// TIMERS
NOT_ON_TIMER , // PE 0 ** 0 ** USART0_RX
NOT_ON_TIMER , // PE 1 ** 1 ** USART0_TX
NOT_ON_TIMER , // PE 2 ** 2 ** D2
TIMER3A   , // PE 3 ** 3 ** PWM1
TIMER3B , // PE 4 ** 4 ** PWM2
TIMER3C , // PE 5 ** 5 ** PWM3
NOT_ON_TIMER , // PE 6 ** 6 ** D6
NOT_ON_TIMER , // PE 7 ** 7 ** D7
NOT_ON_TIMER , // PB 0 ** 8 ** SPI_MISO
NOT_ON_TIMER , // PB 1 ** 9 ** SPI_MOSI
NOT_ON_TIMER , // PB 2 ** 10 ** SPI_SCK
NOT_ON_TIMER , // PB 3 ** 11 ** SPI_SS
TIMER2A , // PB 4 ** 12 ** PWM4
TIMER1A , // PB 5 ** 13 ** PWM5
TIMER1B , // PB 6 ** 14 ** PWM6
TIMER0A , // PB 7 ** 15 ** PWM7
NOT_ON_TIMER , // PD 0 ** 16 ** I2C_SCL
NOT_ON_TIMER , // PD 1 ** 17 ** I2C_SDA
NOT_ON_TIMER , // PD 2 ** 18 ** USART1_RX
NOT_ON_TIMER , // PD 3 ** 19 ** USART1_TX
NOT_ON_TIMER , // PD 4 ** 20 ** D20
NOT_ON_TIMER , // PD 5 ** 21 ** D21
NOT_ON_TIMER , // PD 6 ** 22 ** D22
NOT_ON_TIMER , // PD 7 ** 23 ** D23
NOT_ON_TIMER , // PC 0 ** 24 ** D24
NOT_ON_TIMER , // PC 1 ** 25 ** D25
NOT_ON_TIMER , // PC 2 ** 26 ** D26
NOT_ON_TIMER , // PC 3 ** 27 ** D27
NOT_ON_TIMER , // PC 4 ** 28 ** D28
NOT_ON_TIMER , // PC 5 ** 29 ** D29
NOT_ON_TIMER , // PC 6 ** 30 ** D30
NOT_ON_TIMER , // PC 7 ** 31 ** D31
NOT_ON_TIMER , // PA 7 ** 32 ** D32
NOT_ON_TIMER , // PA 6 ** 33 ** D33
NOT_ON_TIMER , // PA 5 ** 34 ** D34
NOT_ON_TIMER , // PA 4 ** 35 ** D35
NOT_ON_TIMER , // PA 3 ** 36 ** D36
NOT_ON_TIMER , // PA 2 ** 37 ** D37
NOT_ON_TIMER , // PA 1 ** 38 ** D38
NOT_ON_TIMER , // PA 0 ** 39 ** D39
NOT_ON_TIMER , // PG 0 ** 40 ** D40
NOT_ON_TIMER , // PG 1 ** 41 ** D41
NOT_ON_TIMER , // PG 2 ** 42 ** D42
NOT_ON_TIMER , // PG 3 ** 43 ** D43
NOT_ON_TIMER , // PG 4 ** 44 ** D44
TIMER0B , // PG 5 ** 45 ** PWM4
NOT_ON_TIMER , // PF 7 ** 46 ** A7
NOT_ON_TIMER , // PF 6 ** 47 ** A6
NOT_ON_TIMER , // PF 5 ** 48 ** A5
NOT_ON_TIMER , // PF 4 ** 49 ** A4
NOT_ON_TIMER , // PF 3 ** 50 ** A3
NOT_ON_TIMER , // PF 2 ** 51 ** A2
NOT_ON_TIMER , // PF 1 ** 52 ** A1
NOT_ON_TIMER , // PF 0 ** 53 ** A0
CrossRoads
I bet you that should be adjusted to be -8 so that 12-13-14-15 end up as 4-5-6-7 to continue from the 0-1-2-3 below it.
Or even simpler:
( ((p) == 15) ? 7 : \
( ((p) == 14) ? 6 : \
( ((p) == 13) ? 5 : \
( ((p) == 12) ? 4 : \
Uncommented cryptic C/C++ programming, hard to follow most of the time.
Last array looks good.
stank
Yeah,, I figured that the -6  should be a -8 after I sent it.
Well now I seem to have other problems. I ran the compiler with the new boards.txt which looks this,
Code: [Select]
mega2560.name=Arduino Mega 2560 or Mega ADK
mega2560.upload.protocol=wiring
mega2560.upload.maximum_size=258048
mega2560.upload.speed=115200
mega2560.bootloader.low_fuses=0xFF
mega2560.bootloader.high_fuses=0xD8
mega2560.bootloader.extended_fuses=0xFD
mega2560.bootloader.path=stk500v2
mega2560.bootloader.file=stk500boot_v2_mega2560.hex
mega2560.bootloader.unlock_bits=0x3F
mega2560.bootloader.lock_bits=0x0F
mega2560.build.mcu=atmega2560
mega2560.build.f_cpu=16000000L
mega2560.build.core=arduino
mega2560.build.variant=mega
mega2561.name=Arduino Mega 2561
mega2561.upload.protocol=wiring
mega2561.upload.maximum_size=258048
mega2561.upload.speed=115200
mega2561.bootloader.low_fuses=0xFF
mega2561.bootloader.high_fuses=0xD8
mega2561.bootloader.extended_fuses=0xFD
mega2561.bootloader.path=stk500v2
mega2561.bootloader.file=stk500boot_v2_mega2561.hex
mega2561.bootloader.unlock_bits=0x3F
mega2561.bootloader.lock_bits=0x0F
mega2561.build.mcu=atmega2561
mega2561.build.f_cpu=16000000L
mega2561.build.core=arduino
mega2561.build.variant=mega2561
It's the second list. I don't know it it is correct but the compiler compiles with it.
The problem I have now is with the softwareSerial. I can compile the example with any board except the Mega2560. I am not using the Mega2561 data yet.
I think I will post my problem with a new topic.
