Topic: Arduino with Philips LED (Read 3098 times) previous topic - next topic
wprgmr
I am quite new to electronics and recently i've been playing with an Arduino UNO. I am trying to connect a Philips 423244 10-Watt 60-Watt  to the Arduino. Can anyone roughly explain to me what additional equipments do i need and how the block diagram should be? Do i need a LED driver/transistor for the dimming to work?
fungus
You need a matching LED driver with a PWM input.
Advanced Arduino
CrossRoads
What's the voltage requirement for that light? Got a spec?
fungus
Did you mean "current"?
Advanced Arduino
sonnyyu
PRODUCT DESCRIPTION
Philips Award Winning L-Prize LED 10W A19 light bulb is the efficient alternative to a standard 60W incandescent A19 bulb. This dimmable LED is so energy efficient, it is the first 60W equivalent A19 LED bulb to win the L-prize from the U.S. Department of Energy. Providing omni-directional light, this A19 LED is ideal for use in kitchens, living rooms, bedrooms and hallways. It provides a beautiful, soft white light and can save you up to $135.50 in energy costs.
Brightness: 940 Lumens
Estimated Yearly Energy Cost: $1.20 (Based on 3 hrs/day, 11/kWh. Costs depend on rates and use.)
Life: 22.4 years (Based on 3 hrs/day)
Light Appearance: 2700K soft white
Energy Used: 10 watts
Voltage:110 VAC
Lumens per Watt: 94
Meets Federal minimum efficiency standards for Energy Star rating
Uses 83% less energy compared to a standard incandescent light bulb
Instant-on technology, quiet (no-hum) operation and will not fade fabrics or furnishings
A19-shape, medium base
Dimmable: Y
MFG Model # : 423244
MFG Part # : 423244
No pwm dim support
sonnyyu
#5
Jun 04, 2013, 03:29 pm Last Edit: Jun 04, 2013, 04:19 pm by sonnyyu Reason: 1
10 W LED light bulb  reference diagram;-
This is not Philips diagram which I do not know, and it is better not. Philips LED Bulb better use Philips/NXP chipset.
fungus
No pwm dim support
Right...it's not a "LED" at all, it's a complete "bulb" with built in current regulator circuit.
PWM isn't going to work (could even damage it).
The only way to dim it with an Arduino would be a digital variac (or a normal light dimmer moved by a servo motor...)
Advanced Arduino
sonnyyu
#7
Jun 04, 2013, 04:25 pm Last Edit: Jun 04, 2013, 04:40 pm by sonnyyu Reason: 1
Two types LED bulb;
  • 1. Standard, use diagram I list above which IC is working as 80~230 V AC. The Bulb still has 110/220 V version  since Cx voltage.
  • 2. Dimmable, working fine with variac.
sonnyyu
Cree 9.5-Watt (60W) A19 Warm White (2700K) Dimmable LED Light Bulb (1-Pack)
Homedepot, $12.97
wprgmr
I've been trying to use with this.
http://www.amazon.com/gp/product/B008RWSC94/ref=pd_lpo_k2_dp_sr_2/190-3999661-5424806?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=lpo-top-stripe-1&pf_rd_r=1TEBJ076264B4CRN01G2&pf_rd_t=201&pf_rd_p=1535523722&pf_rd_i=B004IUMGV4
