Topic: Si4735 shield works only after pressing the shield's reset-button. (Read 769 times) previous topic - next topic
Muck
Hello Everyone,
Everything works great for me with the AM/FM transmitter shield (with Arduino Duemilanove), except that each time I unplug it's electricity and then plug it again I hear static noise until I press the shield's reset button - only then I can hear a radio transmission. I can't figure out why that's happening. I tried resetting the board using the code but it didn't work - only pressing the button does the job.
Any Idea?
BTW - I use the SI4735 Library.
Many Thanks!
BillSacks
Consider a simple hardware power on reset pulse generated by a capacitor charging at power up on that pin...
Muck
Thank you for the advice. I'll try it.
The thing is the code itself resets the whole system on the power-up, so I can't figure out why it needs another hardware reset. It seems like the shield requires another reset after the power-up procedure and the configuration ends, from some reason.
