Topic: DHT: Celsius to Fahrenheit Conversion (Read 23046 times) previous topic - next topic
easterly81
does anyone have lib or sektch to convert Fahrenheit Conversion with a dth11 sensor
dannable
#1
Jun 10, 2013, 07:20 pm Last Edit: Jun 10, 2013, 07:22 pm by dannable Reason: 1
For temperatures greater than zero:
Celsius * 1.8 + 32
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
el_supremo
That also works for temperatures below zero degrees C.
Pete
Don't send me technical questions via Private Message.
easterly81
how do i add that to the code
Code: [Select]
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHTPIN 2     // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);
  Serial.println("DHTxx test!");
  dht.begin();
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  // check if returns are valid, if they are NaN (not a number) then something went wrong!
  if (isnan(t) || isnan(h)) {
    Serial.println("Failed to read from DHT");
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print("Temperature: ");
    Serial.print(t);
    Serial.println(" *C");
el_supremo
Change this:
Code: [Select]
    Serial.print(t);
to this:
Code: [Select]
    Serial.print((int)round(1.8*t+32));
    Serial.println(" *F");
Pete
Sembazuru
Change this:
Code: [Select]
    Serial.print(t);
to this:
Code: [Select]
Pete
Not sure if the round function and casting as an int is needed... The sample code provided has the Celsius temperature stored as a float, and Serial.print() knows what to do with floats.
http://www.catb.org/jargon/html/I/I-didn-t-change-anything-.html
Jimmy60
IIRC the dht library has a method for returning either F or C.
A quick look in the library and yes.
Code: [Select]
t = dht.readTemperature();         // will return C
t =  dht.readTemperature(true);  // returns F
el_supremo
The accuracy of the DHT11 is plus or minus two degrees Celsius so printing fractions of a degree (Celsius or Fahrenheit) is pointless.
Pete
Sembazuru
Pete
Good point. But, I think Jimmy60 has the better solution (let the library deal with it).
easterly81
Code: [Select]
Thanks just what i was looking for
Patty0465
I have the same problem changing C to F
This is my first sketch most of it from the internet
My code is a little different from the above example not sure what to change to get F
Code: [Select]
//I2C bus support
#include <Wire.h>
//I2C
//OneWire bus suport
#include <OneWire.h>
//DS18B20 temperature sensor support
#include <DallasTemperature.h>
//DS18B20 sensor pin
#define ONE_WIRE_BUS 8
// Setup a oneWire instance to communicate with any OneWire devices
// (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
LiquidCrystal_I2C lcd(0x3f, 16, 2); // set the LCD address for the LCD display
  lcd.init();
  lcd.setBacklight(HIGH);; //Turns backlight on
  sensors.begin();
  sensors.requestTemperatures();
  //Temperature Sensor #1
  float temp = sensors.getTempCByIndex(0);
  //Print first sensor results
  float temp50 = sensors.getTempCByIndex(0);  // give temp a better and unique name
  temp50 = temp50 + .4;   // If Temp is out you can add or subtract here
  lcd.setCursor (0, 0 );
  lcd.print("OutsideTemp ");
  lcd.print(temp50);
  //Read second sensor
  temp = sensors.getTempCByIndex(1);
  //Temperature Sensor #2
  float temp100 = sensors.getTempCByIndex(1);  // give temp a better and unique name
  temp100 = temp100 + .4;   // If Temp is out you can add or subtract here
  //Print second sensor result
  lcd.setCursor (0, 1 );
  lcd.print("Pool Temp   ");
  lcd.print(temp100);
  //Wait 0.1 sec
  delay(100);
septillion
What about reading the library you use...
sensors.getTempFByIndex(0);
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
Bamatrainfan
Code: [Select]
How do you read a library?  Kind new and still learning
ChrisTenone
Find the library code files (library.h, and .cpp, possibly more files as well) in the libraries folder in your arduino folder. Open the code files with a text editor, such as TextEdit (mac) or NotePad (pc). Read the contents.
What, I need to say something else too?
