Topic: Serial Camera C328 connect to Arduino (Read 10429 times) previous topic - next topic
lokster
Jun 19, 2013, 01:54 am Last Edit: Jun 19, 2013, 01:57 am by lokster Reason: 1
Hi guys, I recently bought e-gizmo serial camera, C328, can you help me interface it with my Arduino?
Here is the camera
http://www.e-gizmo.com/KIT/serial%20camera.html
Datasheet
https://docs.google.com/file/d/0BxdLxDCD6Hidb09lckp2N21FMFk/edit
i am a little confused on the wiring of this to the Arduino board since it has two options, TTL and RS232
Do i use TTL connection or RS232 connection?
I've seen some wiring diagrams online and i'm still confused.
Which part does the TX and RX connect to on the module? TTL or RS232?
I'm going to ignore the resistors since the module he was using is old
i found this instruction manual using either the same or similar module, but i cant tell which part he connected it to, the TTL or the RS232? I will follow the wiring in the diagram found here
http://www.fut-electronics.com/wp-content/plugins/fe_downloads/Uploads/Serial%20Camera%20Module%20Programming%20Instructions%20and%20Tutorial.pdf
both have the same method of connection to the arduino, im just not sure if its the TTL output or the RS232?
Any help and input would be appreciated guys. :)
Need this for a thesis project
manufwi
Well you can directly use the TTL serial interface (which means 0-5V interface): the RX of the cam to the TX of the arduino and the TX of the cam to the RX of the arduino. Then a ground connection and the 5V power supply and you're done.
You can also use other digital pins in place of RX/TX on the arduino but you must use the software serial library (google it).
HTH
pylon
Quote
Baud rate: 115200
Forget serial speeds above 38400 with SoftwareSerial. You must connect this camera to the hardware serial interface. You may use SoftwareSerial for debugging (with lower speeds), but you have to find a way to deal with the image data and how you may send it to the PC. Probably any application other than to store the pictures to an SD card overcharge the Arduino (except maybe the Due). What do you plan to achieve with it?
lokster
Quote
Baud rate: 115200
that explains why it wasnt working yesterday, i tried the code in the manual and everything was working fine but when i used processing it didnt work. it just kept 'waiting for data'
Im going to use an Arduino Uno to send the data straight to the PC using processing while it is connected to the arduino.
I plan to use this as a camera for a quad-copter, for video recording.
I didnt know SoftwareSerial had a limit. So i should connect it directly to the RS232 interface?
pylon
Quote
You want to use an Arduino for video recording? Forget about that, it's massively underpowered for such a task, including processor power and memory size.
If you just want to transfer the picture to the PC, use a USB2Serial converter (Arduino has the USB2Serial Light and several other suppliers have FTDI cables). Even directly connected to a PC you won't get a video with this solution, you probably won't get to 1 frame per second with a serial camera. Use an embedded Linux platform based on some ARM computer and connect a cheap USB web cam to it, you'll probably get the best value for your bucks with that.
lokster
Quote
how about just taking a picture then? i just want to test the camera now using arduino uno.
Il probably use an ARM cortex processor for my final design. But right now i just want the basic feature of taking a picture on the PC using this camera on arduino :)
pylon
Quote
As I already wrote: Take a simple USB2Serial converter and attach it to the PC. If you want to use the Arduino UNO, use the following sketch (to deactivate the serial interface of the processor) and swap the pins 0 and 1 (so camera TX to pin 1 and camera RX to pin 0). This way you just use the ATmega16U2 coprocessor of the UNO as a USB2Serial converter. Upload the sketch before you connect the camera!
Code: [Select]
  pinMode(0, INPUT);
  pinMode(1, INPUT);
lokster
#7
Jun 20, 2013, 05:51 pm Last Edit: Jun 20, 2013, 05:55 pm by lokster Reason: 1
Quote
Code: [Select]
 pinMode(0, INPUT);
 pinMode(1, INPUT);
thanks for the info but my camera looks exactly like this
a better view
RS232 connection on the side
TTL connection at the bottom
i wouldnt know how to connect this to the USB2Serial converter
i do want to use Arduino Uno, i dont want to spend any more money. If i upload this sketch how do i take a snapshot or picture? :( the code ive seen in the PDF ive uploaded seems just right and it compiles just fine. Processing is like the camera control to take a picture.
Sorry if i cant get right away what you are saying, im a little new to using a camera, id like to give you karma for taking the time to help, il be sure to pass it forward in the near future
pylon
Quote
The sketch is to disable the usage of the pins 0 and 1 of the main processor of the Arduino. This way you can use the integrated USB2Serial converter (the ATmega16U2 on the UNO board does exactly that) to access the camera by the PC.
Once you've done that you can control the camera with the PC, it's as if you connected it directly to a PC with an RS232 interface.
Grumpy_Mike
Quote
That means you already have in effect a USB to serial converter circuit in your Arduino. He is telling you how to use JUST this bit of the arduino and not the processor bit.
Quote
You connect the TTL TX pin from your camera to pin 1 of the arduino and the RX pin from your camera to pin 0 of the arduino. You also run that sketch to effectively remove the processor.
Do not connect up the RS232 to anything!!!!
Quote
Two points:-
1) Because code compiles does not mean it will function.
2) If you want a comment about this code then it is best if we do not have to guess which out of the millions of PDFs on the internet you have downloaded.
foxdown
yeah,I plan to use this as a camera for a quad-copter, for video recording too
lokster
Quote
Quote
Quote
Two points:-
thank you so much for your help, i have a little more insight on what im suppose to be doing, sorry if i seem such a newbie
but i still dont know how to take a picture. :( the processor bit
Grumpy_Mike
Quote
For that you need access to the data sheet for the module. That link you posted originally is rubbish and not a data sheet. The data sheet should tell you what commands to send it and what it will return.
eileenangela1408
Two points:-
Hi! Can I ask what this means:
"Once you've done that you can control the camera with the PC, it's as if you connected it directly to a PC with an RS232 interface." -pylon
How can I control the camera with the PC now after connecting my camera to the arduino?
anshumantech
     I am trying to interface 0.3 megapixel Serial JPEG camera (By ZM technology) with PC (using RS232) but it didn't respond on hyperterminal. Can you suggest any solution?
     I  have attached the image of the 0.3 megapixel Serial JPEG camera.
