Topic: Upload Sketch su Arduino Mega 2560 da rete o via SD (Read 26119 times) previous topic - next topic
ambro7
PaoloP
Non riesce a riprogrammare fuse e bootloader ma quello che c'è carica gli sketch correttamente?  :smiley-roll-blue:
ambro7
Se provo a mettere il fuse -->FF
Code: [Select]
c:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude.exe -CC:\avrdude.c
onf -patmega2560 -cstk500v1 -P\\.\COM8 -b19200 -Uefuse:w:0xFF:m
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.06s
avrdude.exe: Device signature = 0x1e9801
avrdude.exe: reading input file "0xFF"
avrdude.exe: writing efuse (1 bytes):
Writing | ################################################## | 100% 0.06s
avrdude.exe: 1 bytes of efuse written
avrdude.exe: verifying efuse memory against 0xFF:
avrdude.exe: load data efuse data from input file 0xFF:
avrdude.exe: input file 0xFF contains 1 bytes
avrdude.exe: reading on-chip efuse data:
Reading | ################################################## | 100% 0.01s
avrdude.exe: verifying ...
avrdude.exe: 1 bytes of efuse verified
avrdude.exe: safemode: Fuses OK
avrdude.exe done.  Thank you.
Così non sembra vada in errore, però poi andato a caricare il bootloader, ricevo ancora errori.
Ne stò uscendo pazzo :smiley-roll-sweat: :smiley-roll-sweat:
PaoloP
#18
Jun 21, 2013, 05:41 pm Last Edit: Jun 21, 2013, 05:46 pm by PaoloP Reason: 1
Il tutto è nato quando ho provato a caricare il bootloader Adriadne.
La board per caricare il bootloade di Codebender è questa:
Code: [Select]
ariadne2560M.name=Arduino Mega 2560 (Ariadne Bootloader)
ariadne2560M.upload.protocol=stk500v2
ariadne2560M.upload.maximum_size=258048
ariadne2560M.upload.speed=115200
ariadne2560M.bootloader.low_fuses=0xFF
ariadne2560M.bootloader.high_fuses=0xD8
ariadne2560M.bootloader.extended_fuses=0xFD
ariadne2560M.bootloader.path=ariadne
ariadne2560M.bootloader.file=ariadne_atmega2560.hex
ariadne2560M.bootloader.unlock_bits=0x3F
ariadne2560M.bootloader.lock_bits=0x0F
ariadne2560M.build.mcu=atmega2560
ariadne2560M.build.f_cpu=16000000L
ariadne2560M.build.core=arduino:arduino
ariadne2560M.build.variant=arduino:mega
I fuse sono: FF D8 FD
SPI enable
Boot Size 0
Boot Size 1
Boot Reset
BoD level 1
--> -U lfuse:w:0xff:m -U hfuse:w:0xd8:m -U efuse:w:0xfd:m
Trovi il file board.txt completo qui --> https://github.com/codebendercc/Ariadne-Bootloader/tree/mega/hardware/ariadne
menniti
ma i fuse sono identici alla board originale!!!
Fai una cosa, con avrdude leggi tutti e tre i fuse e cerchiamo di capire cosa dobbiamo sistemare, certamente l'extended che è FD e non FF, ma vediamo gli altri due
Manuale "Arduino e le tecniche di programmazione dei microcontrollori ATMEL"
http://www.michelemenniti.it/manuale_di_programmazione.html
http://www.michelemenniti.it/offerta.html
Articoli ElettronicaIN
http://www.michelemenniti.it/elettronica_in.html
ambro7
Ma questo è il contenuto del file boards.txt che è sotto C:\Program Files (x86)\Arduino\hardware\ariadne
I fuse glieli imposta l'ide arduino quando scrivo il bootloader giusto?
Oppure li devo impostare in manuale.
Grazie ancora per l'aiuto!!!
ambro7
Per leggerli quale comando devo utilizzare?
menniti
dovrebbe essere:
-U lfuse:r:-:h -U hfuse:r:-:h -U efuse:r:-:h
ambro7
Ora sono lontano dall'Arduino....Penso di provare lunedì mattina....
Vi ringrazio
menniti
OK, allora ti lascio i compitini :D
1 - leggi i tre fuse
2 - confrontali con gli standard: low=FF high=D8 extended=FD
3 - se trovi valori diversi ripristina quelli originali, poi rifai le tue prove
4 - se con i fuse a posto hai ancora problemi rivediamo tecnica e collegamenti ISP
leo72
Rileggevo il messaggo di errore:
Code: [Select]
avrdude: verification error, first mismatch at byte 0x1e000
Qui mi pare che ci sia stato un pò un miscuglio di problemi. Sono stati cioè mescolati i problemi con i fuse con quelli relativi alla programmazione della Flash.
L'errore che si evidenzia in alto parrebbe relativo alla barriera dei 128 kB ($1E000 = 120 kB) dell'Arduino MEGA.
Non mi ricordo se l'hai specificato, per cui ti chiedo cortesemente: stai usando che cosa per programmare lo sketch?
menniti
Sta usando IDE 1.0.5
Gli sketch riesce a programmarli senza problemi, tramite IDE + USB
NON riesce a caricare il bootloader via ISP ed ottiene quegli errori
Il dubbio che mi è venuto è che il fuse h sia programmato a favella per cui non ci sia spazio sufficiente per il bootloader
Ho constatato che sulla carta la board che ha usato per quel suo bl ha gli stessi fuse della originale MEGA 2560/ADK, quindi non dovrebbe aver brickato.
Da qui la richiesta di leggere i tre fuse prima di fare altre prove e verificare per bene (cosa che finora non abbiamo fatto) tutta la tecnica ISP che usa.
leo72
Il problema è che stia usando un qualcosa (Arduino UNO con sketch ArduinoISP?) che non riesca a scrivere oltre la barriera dei 128K di Flash. Siccome il bootloader sta nella parte più alta della memoria, il programmatore DEVE per forza passare oltre i 128K. Magari scrivendo il suo sketch  tale limite non lo supera e l'errore non si presenta.
Quindi era per sapere che versione di Arduino usava e capire quale fosse il bootloader sopra caricato.
menniti
All'inizio ha riportato le connessioni, è palese che sta usando due Arduino MEGA ;). Ora, se non erro, il problema over 128K è del compilatore e non dell'Arduino, ma è possibilissimo che le cose stiano come dici tu, per cui potrebbe risolvere con l'aggiornamento software di Astrobeed.
leo72
Quindi è probabile che stia usando l'ArduinoISP compilato con un compilatore che non può indirizzare dati oltre i 128 kB. Ergo, l'ArduinoISP può non riuscire a scrivere oltre i 128 kB della memoria della seconda Mega. Io la prova la farei.
