Topic: Android Bluetooth joystick (Read 401498 times) previous topic - next topic
kas
#210
May 25, 2014, 08:58 am Last Edit: Nov 12, 2014, 03:52 pm by kas
Quote
Data flow from Arduino to Android problem SOLVED
It is great to see the care and level of attention that you provide to the users of your App.
Again many thanks - Brilliant App
Bob
Thanks Bob for the good new and the kind words  8)
I am investing time because this App should bring a lot to the Arduino community
It is a universal remote for most projects, using wide spread (Android) technologies.
I told my friend to download the App and within a minute he took control of my RC tank
He was rather impressed  :smiley-eek: :smiley-eek: :smiley-eek:
During my support session, I did some interesting stress tests yesterday.
I tried various data refresh interval at different baud rates and found some minor glitches.
Please use AndroTest_V14.ino
Code: [Select]
#define VERSION     "\n\nAndroTest V1.4 - @kas2014\ndemo for V4.X  (6 button version)"
// V1.4  improved communication errors handling
// V1.3  renamed for publishing, posted on 09/05/2014
// V1.2  Text display   ** not backward compatible **
// V1.1  Integer display
// V1.0  6 buttons + 4 data char implemented
    **  The message exceeds the maximum allowed length (9500 characters)  **
See next message
This updated sketch features optimized timing and better transmission error management
Again, make sure your BT board is set @57600bps
Avoid using 25ms refresh interval and continuous timeout count, that's too much data
I am also preparing V5.0, with a pure ASCII communication protocol
Rubik's cube Robot  solver     Android BT joystick     Balancing robot for dummies     GPS Logger
Bob1943
Some thoughts
1. Where is AndroTest_V14.ino - only some lines showing?
2. In the Android app can you recognise when the app has been closed 'illegally' and act upon that action next time the app is opened. Might make it idiot proof.
3. When you first touch the yellow joystick dot, it immediately moves to the centre of the touch point. This changes the xy numbers - most noticeable when you touch the edge. (I want to control two servos but don't want them to move until the joystick is moved intentionally).
Can the touch point be recognised without moving the yellow dot?
4. What do I need to change to alter the data fields fed back to the Android and can it be coded in "Your code here" areas in the Arduino sketch.
I am doing number crunching on Arduino from Joystick positions and would like to send three values back to android.
kas
#212
May 25, 2014, 07:00 pm Last Edit: Jun 02, 2014, 07:23 am by kas Reason: 1
Here it is
Code: [Select]
#define VERSION     "\n\nAndroTest V1.41 - @kas2014\ndemo for V4.X  (6 button version)"
// V1.41 minor modifications
// Demo setup:
// Button #1 controls pin13 LED
// Button #2 starts DEBUG
// Button #3 displays demo message
// Button #4 toggle datafield display rate
// Button #5 configured as "push" button (momentary)
// Arduino pin#2 to TX BlueTooth module
// Arduino pin#3 to RX BlueTooth module
// make sure your BT board is set @57600 bps
// better remove SoftSerial for PWM based projects
// For Mega 2560:
// remove   #include "SoftwareSerial.h", SoftwareSerial mySerial(2,3);
// search/replace  mySerial  >> Serial1
// pin#18 to RX bluetooth module, pin#19 to TX bluetooth module
#define    STX          0x01
#define    ETX          0x00
#define    ledPin       13
#define    SLOW         1000                           // Datafields refresh rate (ms)
#define    FAST         250                            // Datafields refresh rate (ms)
SoftwareSerial mySerial(2,3);                           // BlueTooth module: pin#2=TX pin#3=RX
int i=0;
byte cmd[6] = {0, 0, 0, 0, 0, 0};                       // bytes received
byte buttonStatus = 0;                                  // first Byte sent to Android device
long previousMillis = 0;                                // will store last time Buttons status was updated
boolean setButtonFeedback = false;                      // momentary buttons feedback to Android device
long sendInterval = SLOW;                               // interval between Buttons status transmission (milliseconds)
String displayStatus = "xxxx";                          // message to Android device
void setup()  {
 Serial.begin(57600);
 mySerial.begin(57600);                                // 57600 = max value for softserial
 pinMode(ledPin, OUTPUT);
 Serial.println(VERSION);
 while(mySerial.available())  mySerial.read();         // empty RX buffer    //  <<mod XXXXXXXX
 if(mySerial.available())  {                            // data received from smartphone
   delay(2);                                                              //  <<mod XXXXXXXX
   cmd[0] =  mySerial.read();
   if(cmd[0] == STX)  {
     i=1;
     while(mySerial.available())  {
       delay(1);                                                          //  <<mod XXXXXXXX
       cmd[i] = mySerial.read();
       if(cmd[i]>127 || i>5)                               break;   // Communication error << XXX Mod
       if((cmd[i]==ETX) && ((i==2 && cmd[1]>2) || i==5))   break;   // Button or Joystick data
       i++;
     if     (i==2 && cmd[1]>48 && cmd[1]<68)     getButtonState(cmd[1]);                         // 3 Bytes
     else if(i==5 && cmd[1]<3  && cmd[3]<3 )     getJoystickState(cmd);                          // 6 Bytes
 sendBlueToothData();                                                       //  <<mod XXXXXXXX
//    delay(5);                                                              //  <<mod XXXXXXXX
// your code here
void sendBlueToothData()  {
 static long previousMillis = 0;
 long currentMillis = millis();
 if(setButtonFeedback == true)  {                      // allow momentary button visual effect
   previousMillis = currentMillis + 250;
 if(currentMillis - previousMillis > sendInterval) {   // send data to smartphone
// Data frame transmitted back from Arduino to Android device:
// < 0X02   Buttons state   0X01   DataField#1   0x04   DataField#2   0x05   DataField#3    0x03 >
// < 0X02       01011       0X01      120.00     0x04      -4500      0x05   Motor enabled  0x03 >    // example
   mySerial.print((char)0x2);                                                 // Start of Transmission
   mySerial.print(getButtonStatusString());      mySerial.print((char)0x1);   // buttons status feedback
   mySerial.print(GetDataField_1_int());         mySerial.print((char)0x4);   // datafield #1
   mySerial.print(GetDataField_2_float());       mySerial.print((char)0x5);   // datafield #2
   mySerial.print(displayStatus);                                             // datafield #3
   mySerial.print((char)0x3);                                                 // End of Transmission
String getButtonStatusString()  {
 String bStatus = "";
 for(int i=0; i<6; i++)  {
   if(buttonStatus & (B100000 >>i))      bStatus += "1";
   else                                  bStatus += "0";
 return bStatus;
int GetDataField_1_int()  {            // Data dummy values sent to Android device for demo purpose
 static int i= -30;                   // Replace with your own code
 i ++;
 if(i >0)    i = -3000;
 return i;
float GetDataField_2_float()  {       // Data dummy values sent to Android device for demo purpose
 static float i=50;                  // Replace with your own code
 i-=.5;
 if(i <-50)    i = 50;
 return i;
void getJoystickState(byte data[6])    {                             //  <<mod XXXXXXXX   nasty bug, was byte data[5]
 int joyX = (data[1]<<7) + data[2];
 int joyY = (data[3]<<7) + data[4];
 joyX = joyX - 200;                                            // Offset to avoid
 joyY = joyY - 200;                                            // transmitting negative numbers
 if(joyX<-100 || joyX>100 || joyY<-100 || joyY>100)    return; // commmunication error
 Serial.print("Joystick position:  ");
 Serial.print(joyX); Serial.print(", "); Serial.println(joyY);
// Your code here ...
void getButtonState(int bStatus)  {
 switch (bStatus) {
// -----------------  BUTTON #1  -----------------------
   case '1':
     buttonStatus |= B000001;        // ON
     Serial.println("\n** Button_1: ON **");    // your code here...
     displayStatus = "LED <ON>";
     Serial.println(displayStatus);
     digitalWrite(ledPin, HIGH);
   case '2':
     buttonStatus &= B111110;        // OFF
     Serial.println("\n** Button_1: OFF **");    // your code here...
     displayStatus = "LED <OFF>";
     digitalWrite(ledPin, LOW);
// -----------------  BUTTON #2  -----------------------
   case '3':
     buttonStatus |= B000010;        // ON
     Serial.println("\n** Button_2: ON **");    // your code here...
   case '4':
     buttonStatus &= B111101;        // OFF
     Serial.println("\n** Button_2: OFF **");    // your code here...
// -----------------  BUTTON #3  -----------------------
   case '5':
     buttonStatus |= B000100;        // ON
    // setButtonFeedback = true;            moved to button #5 (for push buttons)
     Serial.println("\n** Button_3: ON **");    // your code here...
     displayStatus = "Motor #1 enabled"; // Demo text message
   case '6':
     buttonStatus &= B111011;      // OFF
     Serial.println("\n** Button_3: OFF **");    // your code here...
     displayStatus = "Motor #1 stopped";
// -----------------  BUTTON #4  -----------------------
   case '7':
     buttonStatus |= B001000;       // ON
     Serial.println("\n** Button_4: ON **");    // your code here...
     displayStatus = "Datafield update <FAST>";
     sendInterval = FAST;
   case '8':
     buttonStatus &= B110111;    // OFF
     Serial.println("\n** Button_4: OFF **");    // your code here...
     displayStatus = "Datafield update <SLOW>";
// -----------------  BUTTON #5  -----------------------
   case '9':           // configured as momentary button
//      buttonStatus |= B010000;        // ON
     setButtonFeedback = true;                     // moved from button #3
     Serial.println("\n** Button_5: + pushed + **"); // your code here...
     displayStatus = "Button_5: ++ pushed ++";
//   case 'A':
//     buttonStatus &= B101111;        // OFF
//     break;
// -----------------  BUTTON #6  -----------------------
   case 'B':
     buttonStatus |= B100000;        // ON
     Serial.println("\n** Button_6: ON **");    // your code here...
      displayStatus = "Button #6 ON"; // Demo text message
   case 'C':
     buttonStatus &= B011111;        // OFF
     Serial.println("\n** Button_6: OFF **");    // your code here...
     displayStatus = "Button #6 OFF";
EDIT: moved       setButtonFeedback        from button #3 to button #5 (push button)
         Added 1ms delay after while(mySerial.available())
         Renamed to AndroTest V1.41        see Reply #225
kas
#213
May 25, 2014, 07:23 pm Last Edit: May 25, 2014, 08:44 pm by kas Reason: 1
Quote
Not sure to understand, please clarify "This allows Apps to be closed by swiping the minimized app icon off the screen"
Quote
I understand your concern, makes sense, let me think about it...
Quote
To send back three values to Android (data_1, data_2,data_3,)  just modify sendBlueToothData()
Code: [Select]
   mySerial.print(data_1);                       mySerial.print((char)0x4);   // datafield #1
   mySerial.print(data_2);                       mySerial.print((char)0x5);   // datafield #2
   mySerial.print(data_3);                                                    // datafield #3
Bob1943
Thanks for information
The swipe-to-close feature is about 40 seconds into video at this site:
http://blog.laptopmag.com/9-awesome-android-ice-cream-sandwich-tips
This method is what was causing problem about no data from Arduino to Android. I wonder if this happens with other users?
kas
Quote
I can't replicate the "swipe" problem both on Galaxy Tab3 tablet and Motorola G phone (V4.4.2)
Please let me have a step by step procedure
Bob1943
I am using a 7 inch tablet which doesn't have phone but allows multitasking.
My Samsung GT-S5570 phone won't recognise the HC-05 so I can't test on mobile phone.
However, the link below shows how to swipe on Galaxy 3. Hope this helps.
I think all Android tablets have swipe-to-close so others may also have a problem.
If you want I can video the actions. Just let me know
https://www.youtube.com/watch?v=I5wRaFSDIPo
(anyone know why my Samsung GT-S5570 phone won't recognise the HC-05)
kas
@ Bob1943
Quote
Quote
I addressed the situation  ;)
Please let me have your email via PM, I will send you V4.1 for testing
kas
Quote
Check your mail ...
Bob1943
Hi Kas,
This version V4.1 works fine.
Wherever you touch on the yellow spot is returned as coordinate 0,0 (x,y) which is exactly what I was looking for.
No jumpy servos anymore. - Many thanks
Bob1943
A couple of comments on Joystick BT Commander.
1. As information can be sent from Arduino to Android, is it possible to use the Android like a Serial monitor to display this information with rolling values - just like the USB to computer screen. You could give the option to change from Joystick to Monitor to make space on the Android screen.
An option to rotate the Android to make a deeper window would help, and an added bonus would be to have a button to pause the display if required.
2. Can the Arduino Bluetooth code be put into a library so the bluetooth device can be connected and used as a monitoring/commander tool. This would make the Arduino coding for the main applications more visible.
Just a thought!!!
kas
Quote
Thanks, I will include this feature in V5.0 (pure ASCII protocol)
Quote
Android Bluetooth joystick is a small footprint App (78Ko), its only task is to emulate a joystick  ;)
There are very good App for serial monitoring, BlueTerm is one of those
Quote
Try sending AT command
Code: [Select]
AT+CLASS=1
Should work
kas
#222
May 29, 2014, 07:29 am Last Edit: May 29, 2014, 07:41 am by kas Reason: 1
@Topicja
Quote
Hi Kas
I really like your excellent android app but after last update i cannot get it to work. I tried to rewrite my program but i don't receive any data. Could you please send me apk file of older version? Version 3.1 was working well for me. My e-mail address is xxxxxxxx@xxx.com
Thank you for your response and your willingness
I could recompile V3.1, but it makes much more sense to have your own program fixed and working
Joystick transmission has not been modified and should work, does it??
Please let me have your original Arduino sketch, I will fix it for you
@all
Should you encounter same difficulties, please contact me via PM
n3kx
Sorry for late response. My problem was in bautrate and also you must press 3.rd button to get work .... so yust overwrite setbuttonfeedback=false to  setbuttonfeedback=true and it work for my.
kas
#224
May 29, 2014, 05:39 pm Last Edit: May 29, 2014, 06:19 pm by kas Reason: 1
@Topicja
Quote
I will send you the modified sketch tomorrow evening
There are too many transmission errors at 9600 bps
Please, in the meantime, configure your BT card at 57600 bps
Are you able to do it by yourself ??
Otherwise, let me have a link to your specific model
