Topic: Android Bluetooth joystick (Read 378928 times) previous topic - next topic
kas
#570
Feb 07, 2016, 12:21 pm Last Edit: Feb 07, 2016, 12:21 pm by kas
Quote
Here is a video
Seems we are on the right track  ;)
Quote
How can I display mAh and voltage ? The other things I'm curious about as if signal is weak or missing then it will act as dead man switch to motors .
Let's start by the Dead Man implementation
Which safety level do you require ??
 - moderate: boot will stop if signal is lost and immediately restart when signal is back
 - high: needs Arduino reboot to restart motion
Let me have a copy of your actual working sketch
We need to work on the very same code
Is there mV and mA outputs on your driver board ??
Quote
Also can I insert code from example ino file for the button commands to actual a servo ?
Please elaborate
Out of curiosity, where are you based in this Global Village ?
fullspool
#571
Feb 07, 2016, 04:58 pm Last Edit: Feb 08, 2016, 02:12 pm by fullspool
Kas,
This sketch is working really well but I have expo jumper installed on the ESC . If not, it's to sensitive with the joy stick commander app. I am in the USA , if you want exact location I can PM you .
I have no pins assigned on my UNO yet for mA or voltage read out. I am powering my rover with
a 3s lipo (4.1v x 3= 12.3 v fully charged) so I assume I will need to solder in a jumper off the main feed and tie it into an analog pin on the uno? or tie into the balance port  on the Lipo battery itself? I can't use the 5v out pin on the uno as it wont show me true voltage as I am powering it with more then 5v.
I just need moderate dead mans kill switch.
I would also like button 1 to tie into pin 8 on the uno, when button 1 is pushed a new servo will sweep 90 degrees, when button 1 is pressed again it will move back to original state.
Code: [Select]
#define VERSION     "\n\nAndro_Pan&Tilt V3.6 - @kas2014\n** servo's demo for V5.x App **"
// Controls two servo motors
// V3.6: Android BT Commander V5.X compatible, no button data management
// V3.0: Android BT Commander V3.X compatible, no button data management
// V2.5 can receive both Byte & Integer data
// V2.0: removed SoftwareSerial
// Android BT Commander settings:
// Options/Options for advanced users/Data Range        >>>  -100 to +100
// Options/Options for advanced users/Refresh interval  >>>  50ms
//  Arduino pin #0 to TX BlueTooth module
// BT TX to be disconnected from D0 during sketch upload
#include <Servo.h>
boolean    DEBUG =         true;
#define    pinServo_X     9            //<<  ServoX pin
#define    pinServo_Y     10           //<<  ServoY pin
#define    STX            0x02
#define    ETX            0x03
#define    MIN_Y          0  //45             // vertical move limitation,
#define    MAX_Y          180                 // adjust to needs
#define    ZERO_Y         -1  //60             // vertical zero offset
byte cmd[8] = {0, 0, 0, 0, 0, 0, 0, 0};
Servo myservoX;                         // create servo objects
Servo myservoY;
void setup()  {
 Serial.begin(57600);
 myservoX.attach(pinServo_X);
 myservoY.attach(pinServo_Y);
 if(DEBUG)    Serial.println(VERSION);
  if(Serial.available())  {                            // data received from smartphone
   delay(2);
   cmd[0] =  Serial.read();
   if(cmd[0] == STX)  {
     int i=1;
     while(Serial.available())  {
       delay(1);
       cmd[i] = Serial.read();
       if(cmd[i]>127 || i>7)                 break;     // Communication error
       if((cmd[i]==ETX) && (i==2 || i==7))   break;     // Button or Joystick data
       i++;
     if(i==7)     setServoPosition(cmd);
void setServoPosition(byte data[8])    {   // differential steering version
 int servo_L, servo_R;
 int joyX = (data[1]-48)*100 + (data[2]-48)*10 + (data[3]-48);       // obtain the Int from the ASCII representation
 int joyY = (data[4]-48)*100 + (data[5]-48)*10 + (data[6]-48);
 joyX = joyX - 200;                                                  // Offset to avoid
 joyY = joyY - 200;                                                  // transmitting negative numbers
 if(joyX<-100 || joyX>100 || joyY<-100 || joyY>100)     return;      // communication error
 if(joyY >-10)  {                                                    // differential steering
   servo_L = (joyY - (3*joyX)/4);
   servo_R = (joyY + (3*joyX)/4);
 }  else  {
   servo_L = (joyY + (3*joyX)/4);
   servo_R = (joyY - (3*joyX)/4);
 servo_L = map(servo_L, -100, 100, 0, 180);   //  << adjust to change motor direction XXX
 servo_R = map(servo_R, -100, 100, 0, 180);   //  <<
 servo_L = constrain(servo_L, 0, 180);
 servo_R = constrain(servo_R, 0, 180);
 myservoX.write(servo_L/2);
 myservoY.write(servo_R/2);
 if(DEBUG)    {Serial.print(joyX); Serial.print(", "); Serial.println(joyY);}
kas
#572
Feb 08, 2016, 08:32 am Last Edit: Feb 08, 2016, 08:35 am by kas
Quote
Is it OK with the expo jumper ??
The signal can also be tuned within the Arduino code
Quote
I am powering my rover with a 3s lipo (4.1v x 3= 12.3 v fully charged) so I assume I will need to solder in a jumper off the main feed and tie it into an analog pin on the uno?
Don't do that  :smiley-eek:    you will fry your Uno
Analog pins accept no more than 5 Volts, you need a voltage divider
Back to full blown code, with feedback to smartphone
This is AndroTest_Servo_fullspool V1.1, with Dead Man implementation
Code: [Select]
#define VERSION     "\n\nAndroTest_Servo_fullspool V1.x - @kas2016\ndemo for servo's"
// V1.1  added Dead Man feature
// V1.0  Basic implementattion
#include <Servo.h>
#define    STX            0x02
#define    ETX            0x03
#define    ledPin         13
Servo myservoY;
byte cmd[8] = {0, 0, 0, 0, 0, 0, 0, 0};                 // bytes received
byte buttonStatus = 0;                                  // first Byte sent to Android device
long previousMillis = 0;                                // will store last time Buttons status was updated
long sendInterval = 750;                                // interval between Buttons status transmission (milliseconds)
long deadManInterval = 1100;                            // interval between Dead Man checks (milliseconds)
boolean deadManTimeout = false;                         // dead man flag
String displayStatus = "xxxx";                          // message to Android device
int servo_L, servo_R = 90;                              // servo's positioning values
void setup()  {
  pinMode(ledPin, OUTPUT);
  while(Serial.available())  Serial.read();          // empty RX buffer
    deadManTimeout = false;                              // reset Dead Man
    delay(2);
    if(cmd[0] == STX)  {
      int i=1;
        delay(1);
        i++;
      if     (i==2)          getButtonState(cmd[1]);    // 3 Bytes  ex: < STX "C" ETX >
      else if(i==7)          getJoystickState(cmd);     // 6 Bytes  ex: < STX "200" "180" ETX >
  sendBlueToothData();
  checkDeadMan();
  motorsControl();
void checkDeadMan()  {                                                  // stop engines if signal is lost
  static long previousMillis = 0;
  long currentMillis = millis();
  if(currentMillis - previousMillis > deadManInterval) {                // check is performed every deadManInterval ms
    if(deadManTimeout)  {
      myservoX.write(90);                                               // stop motors
      myservoY.write(90);
    deadManTimeout = true;
void motorsControl()  {
void sendBlueToothData()  {
  if(currentMillis - previousMillis > sendInterval) {   // send data back to smartphone
// Data frame transmitted back from Arduino to Android device:
// < 0X02   Buttons state   0X01   DataField#1   0x04   DataField#2   0x05   DataField#3    0x03 >
// < 0X02      "01011"      0X01     "120.00"    0x04     "-4500"     0x05  "Motor enabled" 0x03 >    // example
    Serial.print((char)STX);                                             // Start of Transmission
    Serial.print(getButtonStatusString());  Serial.print((char)0x1);     // buttons status feedback
    Serial.print(GetdataInt1());            Serial.print((char)0x4);     // datafield #1
    Serial.print(GetdataFloat2());          Serial.print((char)0x5);     // datafield #2
    Serial.print(displayStatus);                                         // datafield #3
    Serial.print((char)ETX);                                             // End of Transmission
String getButtonStatusString()  {
  String bStatus = "";
  for(int i=0; i<6; i++)  {
    if(buttonStatus & (B100000 >>i))      bStatus += "1";
    else                                  bStatus += "0";
  return bStatus;
int GetdataInt1()  {              // Data dummy values sent to Android device for demo purpose
  static int i= -30;              // Replace with your own code
  i ++;
  if(i >0)    i = -30;
  return i;
float GetdataFloat2()  {           // Data dummy values sent to Android device for demo purpose
  static float i=50;               // Replace with your own code
  i-=.5;
  if(i <-50)    i = 50;
  return i;
void getJoystickState(byte data[8])    {
  }  else  {
void getButtonState(int bStatus)  {
  switch (bStatus) {
// -----------------  BUTTON #1  -----------------------
    case 'A':
      buttonStatus |= B000001;        // ON
      displayStatus = "LED <ON>";
      digitalWrite(ledPin, HIGH);
    case 'B':
      buttonStatus &= B111110;        // OFF
      displayStatus = "LED <OFF>";
      digitalWrite(ledPin, LOW);
// -----------------  BUTTON #2  -----------------------
    case 'C':
      buttonStatus |= B000010;        // ON
      displayStatus = "Button2 <ON>";
    case 'D':
      buttonStatus &= B111101;        // OFF
      displayStatus = "Button2 <OFF>";
// -----------------  BUTTON #3  -----------------------
    case 'E':
      buttonStatus |= B000100;        // ON
      displayStatus = "Button3 <ON>";
    case 'F':
      buttonStatus &= B111011;      // OFF
      displayStatus = "Button3 <OFF>";
// -----------------  BUTTON #4  -----------------------
    case 'G':
      buttonStatus |= B001000;       // ON
      displayStatus = "Button4 <ON>";
    case 'H':
      buttonStatus &= B110111;    // OFF
      displayStatus = "Button4 <OFF>";
// -----------------  BUTTON #5  -----------------------
    case 'I':                   // configured as momentary button
      displayStatus = "Button5: <pushed>";
// -----------------  BUTTON #6  -----------------------
    case 'K':
      buttonStatus |= B100000;        // ON
      displayStatus = "Button6 <ON>"; // Demo text message
    case 'L':
      buttonStatus &= B011111;        // OFF
      displayStatus = "Button6 <OFF>";
I have no possibilities to test the code for the moment, but at least, it compiles  ;)
Make me a favor, edit your last post and embed your code as such
  [c ode] ... code... [/c ode]     (ommit the two spaces)
or use the </> button at the top left of the "Post reply" dialog
Post will be more legible
fullspool
So I can keep tuning the signal by adjusting this part of the code correct?
If I do a voltage divider will it only show the 5v on the telemetry? Or give me my actual 12v reading?
I fixed the post, thanks for the feed back. I will work on it more today.
kas
#574
Feb 08, 2016, 05:57 pm Last Edit: Feb 29, 2016, 11:28 am by kas
Quote
Yes, you can use any mathematical function (linear or non linear)
Quote
You will read actual battery voltage
Be prepared to have 1/4W resistors:
 1X  4.7K  +  1X  10K
or
 3X  4.7K
For Amp you will need a 5A Current Sensor Module ACS712 such as this one  (2 bucks, shipped)
fullspool
#575
Feb 09, 2016, 03:08 am Last Edit: Feb 09, 2016, 04:47 am by fullspool
Thank you Kas , I will get the parts ordered and research the voltage divider .
I tried the new code , when I press button 1 it lights up the LED however when I connect a servo to pin 13 it just twitches.
https://youtu.be/TyLJ8wD9v-o
Next I tested Deadman , whenever signal is lost the motors keep turning in the last known position .
https://youtu.be/mXp7KRq7sPA
I am not sure how to fix it ?
On a side note I made some new axles as my aluminum axles bend to easy . These are made from drill stock so should be much stronger .
kas
#576
Feb 09, 2016, 10:47 am Last Edit: Feb 09, 2016, 10:54 am by kas
Quote
This is AndroTest_Servo_fullspool Version 1.2
// V1.2  added 3rd servo control, fixed Dead Man
Code is attached, you need to be logged to access it
Make sure to connect the AUX servo to pin #8
What is it used for ??
I also noticed on your video that your smartphone don't get any feedback from Arduino
Please connect BT board RX pin to Arduino pin #1
On your smartphone Datafield #1 and #2 will (should) display demo changing numbers
Datafield #3 will display AUX servo and buttons status
Quote
At least they won't bend anymore  ;)
Again, if you make any change to the code, please send me a copy
We really need to stay synchronized
fullspool
#577
Feb 09, 2016, 02:33 pm Last Edit: Feb 09, 2016, 02:41 pm by fullspool
Kas,
I tested the servo with button 1 and it works now however the dead man test goes from last known for a second or 2 then motors go wide open until signal is restored .  The reason I want to move servo arm is for my locking mechanism .
I will test further , the code is attached.
kas
Please replace
      servo_L = 0;                                               // stop motors
      servo_R = 0;
by
      servo_L = 90;                                               // stop motors
      servo_R = 90;
Can you see changing values in App's datafields ??
fullspool
That fixed it however there is a 2 second delay from last known position till the motors quit.
Controls are getting really smooth , led lights up and servo actuates as it should for now.
I am really happy how this is progressing . I can't wait till my telemetry parts come in.
New video
https://youtu.be/7s2JOm0RWqg
kas
#580
Feb 10, 2016, 10:50 am Last Edit: Feb 10, 2016, 11:07 am by kas
Quote
Want a fast Dead Man ??
replace
by
  long deadManInterval = 550;                             // interval between Dead Man checks (milliseconds)
Want it faster ?? just let me know  ;)
Quote
Let me know the actual resistors values as soon as you receive them
You can get them right away at your local RadioShack
fullspool
#581
Feb 10, 2016, 05:51 pm Last Edit: Feb 10, 2016, 08:24 pm by fullspool
My local radio shack only had 4.7k 1/2 watt resistors so I will be using 3 of those .
Would it be better to use a zener diode since my voltage may change ? (Not now but may in future)
kas
#582
Feb 10, 2016, 09:00 pm Last Edit: Feb 10, 2016, 09:00 pm by kas
RĂ©sistors are OK
Let me know if 1 second signal drop is OK for Dead Man safety, and please let me have a copy of the modified code
fullspool
The deadman works perfect, thanks :)
Code is attached.
fullspool
Here is a new video .
https://youtu.be/WUH83wnfXeg
