Topic: Android Bluetooth joystick (Read 390728 times) previous topic - next topic
cshunt
Hi Kas,
I am working with your app and sample code and ran into a snag last night. I am using the adafruit ez-link, nothing seemed to show up over the serial link. I believe the issue is the baud rate for ez-link is not selectable in the rc commander app so I am unsure of what baud it is actually connecting at. I will try with an hc-06 where the baud is set by the module. https://www.adafruit.com/product/1588
Is there a version of the app floating around that may have selectable baud?
Thanks!!
kas
#916
May 28, 2018, 07:12 am Last Edit: May 28, 2018, 07:16 am by kas
Hi cshunt
 No  ::) ::)
There is no such thing as "baud rate" for Bluetooth radio transmission between two devices
Baud rate only apply to the wired serial connection between BT card and Arduino
Try to adjust baud rate in AndroTest.ino demo sketch
BTW Bluefruit EZ-Link had major flaws and is now discontinued, just use a plain HC-05/HC-06 board
RULDI
https://www.youtube.com/watch?v=ET9F-lOTPjQ&feature=youtu.be
Hi, Kas
 I made this video so you can see the chair working perfectly
Kas
is it possible to turn the bluetooth comander design a bit?
When I put the 2 motors forward, I have to by the bluetooth comander diagonally
I would like to go up and go forward.
and back the same thing
the diagonal control is confusing me a little lol
but if you can not do this well
kas
Hi Ruldi,
Thanks for the video, you are now a super driver  ;)
is it possible to turn the bluetooth commander design a bit?
When I put the 2 motors forward, I have to by the bluetooth commander diagonally
Let me see what I can do
kas
#919
Jun 10, 2018, 09:14 pm Last Edit: Jun 24, 2018, 04:12 pm by kas
Hi Rudi,
This is version E, with differential steering
** Cuidado **
I still can't test the code, some joystick positions may produce unexpected moves
Test carefully and let me have your comments
RULDI
Hi, Kas
It really did look strange.
the engines with this code behaved differently
did not work nor the speed control
and so connect the bluetooth comander the motors go out spinning and do not stop
and when I put it forward they slow down
the image I posted shows the position of the joystick diagonally with the 2 front motors
the other image with the joystick up, the chair turns sideways
I do not know if I could explain it well, but that's it.
 Thank you for always being considerate.
http://i64.tinypic.com/15ck4l5.jpg[/img]]
http://i66.tinypic.com/1zh1s89.jpg[/img]]
kas
Sorry for that
I need to setup some equipment to really test the code
A bit busy for the moment, may take a while   :(
please go back to revision D for the moment
RULDI
Sorry for that
Okay Kas, I'll be waiting.
meanwhile I'm going to redo all electrical installation
and set some details
God bless you
kas
I think I got it   ::)
This is version E1 , please test it and let me know
Take  _great_  care
kas
I know this is a really old thread, but is it still possible to get a copy of total RC commander?
Thank you for your time.
-Erik
Thanks for your interest
Check your mail
kas
End of technical support
I have been supporting this project for nearly four years, this was an exciting experience
I have since moved to other projects and it's now time for me to retire
All possible questions have been answered in this thread, just read it  ;)
Feel free to use this thread on a peer to peer basis to share your experience
Please no more PM's
Thanks again for your interest and good luck for your projects
kas
#926
Jul 28, 2018, 02:06 pm Last Edit: Jul 28, 2018, 02:07 pm by kas
One last contribution
Demo sketch for ESP32  V1.1
Enjoy  ;)
xip
Hi, thanks for sharing the Android app!
Is the source code of the Android app available?
Cheers,
David
steamr0ller
#928
Jan 28, 2019, 03:24 am Last Edit: Jan 28, 2019, 03:59 am by steamr0ller
Im working with the arduino mega 2560
and its not working
steamr0ller
/ For Mega 2560:
// remove   #include "SoftwareSerial.h", SoftwareSerial mySerial(2,3);
// search/replace  mySerial  >> Serial1
// pin#18 to RX bluetooth module, pin#19 to TX bluetooth module
This comment is confusing to me
What i did was remove the #include "SoftwareSerial.h", SoftwareSerial mySerial(2,3);" that was at the top of the code and the i did ctrl-F to find and replace all "mySerial" with Serial1 then i moved the pins from 2 and 3 to 18 and 19.
is this correct? i just found this app and am trying to get it to display some info or anything really!!
