Bluetooth Shield Seeeduino
Hi y'all,
Good morning for ones who have some sun and evening for the others. :slight_smile:
I've encountered a problem with my two Bluetooth Shields that I've purchased on the Seeedstudio website.
I've followed the instructions on the wikipage to make them communicate but it doesn't work and I cannot sleep since one week :frowning:
Plz HELP
Despite of all my efforts, the green LED blinks always twice a second.I've also bought a packet sniffer from TI to check if there is any transmission of the bluetooth signal but is not :cry:
What solutions can you provide PLZ
anything is welcomed!
Thanks and have a good day
that's is the code I also tried to connect with the CC2541 sensortag from TI:
In this code, we are goin' to test
the communication between one Arduino Uno Card and the sensor tag
through a bluetooth connection
This code is uploaded in the Master Board
#include <SoftwareSerial.h>
//Pins 2 and 3 defined as RX and TX
#define Rx 2
#define Tx 3
//On crée un objet blueToothSerial pour utiliser l'Uart sur les broches RX et TX
SoftwareSerial blueToothSerial(Rx,Tx); // RX, TX
//Variable which contains received data from the Bluetooth link
char received = '0';
//Buffer which contains data received from the terminal
String received_terminal = "";
//Buffer which contains data received from the Bluetooth link
String received_bt = "";
//Declaration of the buffer of reception
String received_buffer="";
//Boolean variable which turn into true if
//Something has been read
boolean reception_OK=false;
*Setup Function        *
  pinMode(Rx,INPUT);
  pinMode(Tx,OUTPUT);
  //Function which initialize Bluetooth connection
  setupBlueToothConnection();
**Infinite loop        *
    //On vérifie si on a reçu des données via la liaison Bluetooth
    if(blueToothSerial.available()>0)
        //recu_bt is a variable which contains
        //what is read by the bluetooth link
        char recu_bt = blueToothSerial.read();
        received_bt += recu_bt;
        //We confirm reception
        Serial.println("Bluetooth received");
        //We display what we just received
        Serial.println(received_bt);
    if(Serial.available())
        //recu is a variable which contains
        //what is read by the serial link
        char recu = Serial.read();
        received_terminal += recu;
        if(recu=='\n')
          Serial.println("All received");
          Serial.print("La commande est:\r");
          Serial.println(received_terminal);
          Serial.println("Sending by Bluetooth");
          String received_terminal_n = received_terminal;
          received_terminal_n.replace("\n","\r");
          String Commande_blueTooth = "\r\n";
          Commande_blueTooth += received_terminal_n;
          Commande_blueTooth += "\n";
          blueToothSerial.print(Commande_blueTooth);
          received_terminal="";
*Function which initialize Bluetooth Connection                                                             *
void setupBlueToothConnection()
     //Set BluetoothBee BaudRate to default baud rate 38400
    blueToothSerial.begin(38400);
    //Configuring the Board as Master
    blueToothSerial.print("\r\n+STWMOD=1\r\n");
    //The name of our master is just MASTER
    blueToothSerial.print("\r\n+STNA=MASTER\r\n");
    //Activating the auto-connection mode
    blueToothSerial.print("\r\n+STAUTO=1\r\n");
    //Permit to paired devices to connect at UNO
   // blueToothSerial.print("\r\n+STOAUT=1\r\n");
    delay(2000); // This delay is required.
    //make the master inquire
    blueToothSerial.print("\r\n+INQ=1\r\n");
    Serial.println("Master is inquiring!");
    blueToothSerial.flush();
    //Get back datas from the slave
    while(blueToothSerial.available()>0)
        received = blueToothSerial.read();
        received_buffer += received;
        reception_OK=true;
    //We check if something has been read
    if(reception_OK)
      //We display what we have received
      Serial.println(received_buffer);
      Serial.println("Connexion etablie");
      Serial.println("NOTHING has been read!!");
    //Connecting to the sensor Tag
    //whose MAC Adress is:0x9059AF0AAB43
    blueToothSerial.print("\r\n+CONN=90,59,AF,0A,AB,43\r\n");
        reception_OK=true;
    if(reception_OK)
      Serial.println("Connexion au SensorTag etablie");
    //Connecting to the round red thing
    //whose MAC Adress is:0xD466D8E68E5D
    blueToothSerial.print("\r\n+CONN=D4,66,D8,E6,8E,5D\r\n");
          Serial.println("Connexion au bidule rouge etablie");
