Topic: Relays constantly on using a multiplexer. (Read 1 time) previous topic - next topic
Yarash
Jun 25, 2013, 10:30 pm Last Edit: Jun 25, 2013, 10:37 pm by Yarash Reason: 1
Hi
I am working on a project consisting of 8 relays.
Is it possible to use a multiplexer to control the relays
By cycling thru the channels and providing the power
Needed for a relay thru the multiplexer's common.
As far as i know it wouldnt be a problem to turn
Only one relay on, but if i use a multiplexer
Only one channel can output the voltage at a time.
I am pretty sure the relays respond much slower than
The Arduino's clock.
So i wonder if looping thru the 8 channels very fast
Could keep the relays on constantly?
If it would, should it damage the relays?
Is there a better yet simple way to do this?
Thanks.
johnwasser
The simple way is a serial-in/parallel-out shift register.  That gives you 8 separate outputs that can be individually controlled.
See: http://arduino.cc/en/Tutorial/ShiftOut
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Grumpy_Mike
Quote
It would be possible but absolutely stupid to use single dimension multiplexing to control any output. You get all the hassle of refreshing with absolutely zero advantage.
Quote
There are lot and lots of better ways. Shift registers, latches, port expanders.
Yarash
Quote
Quote
Wouldn't it save power usage?
Using A shift register i must provide the power
To all relays combined, in my case i may multiply the relays to 64 in the future.
Grumpy_Mike
Quote
No.
True holding current is less than pull in current, but you are using a relay so if power is a main concern then don't use a relay.
Quote
Yes and so you must using a multiplexer unless your multiplexer can pass enough current which I think you will find it won't.
zoomkat
Quote
You could use a latching multiplex chip like a 74HC259.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
MarkT
Relays may  not tolerate high frequency AC drive, you'll get significant iron losses
(relay cores are soft iron rather than silicon steel laminate).
Furthermore you'd have to drive them at much higher voltage to get the right
average current, and your multiplexer wouldn't take that.
The correct approach is to use something like a 74HC595 shift register (which latches
output states) and have a drive circuit for each relay (presumably NPN transistor
and flyback diode.  ULN2803 provides 8-channels of such drive, so a 595 and 2803
together would be a common choice.  Check the voltage and current specs of your
relays of course.
Yarash
relays of course.
Your reply is much appreciated.
Thanks.
