Topic: Stuck on program (Read 2444 times) previous topic - next topic
aaron361068
Jun 30, 2013, 09:10 am Last Edit: Jun 30, 2013, 09:13 am by Coding Badly Reason: 1
this is my first real project and im a bit stuck
I have a jeep that has a lot of broken/added electronics and the diver seat is starting to look like a spacecraft do to all the extra switches.
so my plan is to have a 2X16 LCD Screen and a 8 channel relay  nd two push buttons to do all the work.
i got it started but im kinda stuck. i want to add a feature of having some of the items like the radio go off with the accessories or on all the time depending on what i want. i think i have a start with this program but i might be way off base.
i havent figured out how to make a detector to see if the accessory on the jeep is on and then implement them.
There is a strong possibility that i might be way over my head on this..... hahaa
Code: [Select]
const int pushButtonPin = 2;
const int selector = 12;
int pressCount = 0;
int selectCount = 0;
int windshieldstatus = 1;
int frontlightsstatus = 10;
int rearlightstatus = 11;
int radiostatus = 13;
int flashlightstatus = A1;
int hamstatus = A2;
int antennaup = A3;
int antennadown = A4;
int prevState = LOW;
int currState;
int prevState2 = LOW;
int currState2;
#include <Wire.h>
#include <LiquidCrystal.h>   // include LCD library
#define LCD_BACKLIGHT_OFF()     digitalWrite( LCD_BACKLIGHT_PIN, LOW )
#define LCD_BACKLIGHT_ON()      digitalWrite( LCD_BACKLIGHT_PIN, HIGH )
#define LCD_BACKLIGHT(state)    { if( state ){digitalWrite( LCD_BACKLIGHT_PIN, HIGH );}else{digitalWrite( LCD_BACKLIGHT_PIN, LOW );} }
byte buttonJustPressed  = false;         //this will be true after a ReadButtons() call if triggered
byte buttonJustReleased = false;         //this will be true after a ReadButtons() call if triggered
LiquidCrystal lcd( 8, 9, 4, 5, 6, 7 );
int lastpresscount = 0;
int windshieldmode = 0;
int frontlightsmode = 0;
int rearlightmode = 0;
int radiomode = 0;
int flashlightmode = 0;
int hammode = 0;
  lcd.begin( 16, 2 );
  lcd.setCursor( 1, 0 );
  lcd.print( "SCOUT CONTROL" );
  lcd.setCursor( 5, 1 );
  lcd.print( "Ready" );
pinMode(pushButtonPin, INPUT);
  digitalRead(pushButtonPin);
pinMode(selector, INPUT);
  digitalRead(selector);
pinMode(windshieldstatus, OUTPUT);
pinMode(frontlightsstatus, OUTPUT);
pinMode(rearlightstatus, OUTPUT);
pinMode(radiostatus , OUTPUT);
pinMode(flashlightstatus , OUTPUT);
pinMode(hamstatus , OUTPUT);
pinMode(antennaup, OUTPUT);
pinMode(antennadown, OUTPUT);
  currState = digitalRead(pushButtonPin);
 if (currState != prevState)
   if (currState == HIGH)
     pressCount++;
   delay(10);
 prevState = currState;
    currState2 = digitalRead(selector);
 if (currState2 != prevState2)
   if (currState2 == HIGH)
      selectCount++;
   delay(100);
 prevState2 = currState2;
if(pressCount > 9) {pressCount = 0;}
if(pressCount != lastpresscount){
if(pressCount == 1){
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("windsheild");
 lcd.setCursor(0,1);
 lcd.print("Mode:");
selectCount = windshieldmode;
if(pressCount == 2){
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("frontlights");
 lcd.setCursor(0,1);
 lcd.print("Mode:");
 selectCount = frontlightsmode;
if(pressCount == 3){
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("rearlight");
 lcd.setCursor(0,1);
 lcd.print("Mode:");
 selectCount = rearlightmode;
if(pressCount == 4){
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("radio");
 lcd.setCursor(0,1);
 lcd.print("Mode:");
 selectCount = radiomode;
if(pressCount == 5){
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("flashlight");
 lcd.setCursor(0,1);
 lcd.print("Mode:");
 selectCount = flashlightmode;
if(pressCount == 6){
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("HAM");
 lcd.setCursor(0,1);
 lcd.print("Mode:");
 selectCount = hammode;
/* if(pressCount == 7){
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("Antenna");
 lcd.setCursor(0,1);
 lcd.print("Mode:");
 selectCount = antennamode;
if(pressCount == 0){
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("Scout Control");
Serial.println(selectCount);
 if(selectCount == 0){
   lcd.setCursor(7,1);
   lcd.print("OFF");
   digitalWrite(windshieldstatus,LOW);
 if(selectCount == 1){
   lcd.setCursor(7,1);
   lcd.print(" ON");
   digitalWrite(windshieldstatus,HIGH);
 if(selectCount > 1)
   {selectCount = 0;}
windshieldmode = selectCount;
   lcd.setCursor(7,1);
   lcd.print("OFF");
   digitalWrite(frontlightsstatus ,LOW);
 if(selectCount == 2){
   lcd.setCursor(7,1);
   lcd.print(" ON");
   digitalWrite(frontlightsstatus ,HIGH);
 if(selectCount > 1)
   {selectCount = 0;}
frontlightsmode = selectCount;
   lcd.setCursor(7,1);
   lcd.print("OFF");
   digitalWrite(rearlightstatus ,LOW);
   lcd.setCursor(7,1);
   lcd.print(" ON");
   digitalWrite(rearlightstatus ,HIGH);
 if(selectCount > 1)
   {selectCount = 0;}
rearlightmode = selectCount;
   lcd.setCursor(7,1);
   lcd.print("OFF");
   digitalWrite(radiostatus ,LOW);
   lcd.setCursor(7,1);
   lcd.print(" ON");
   digitalWrite(radiostatus ,HIGH);
 if(selectCount > 1)
   {selectCount = 0;}
radiomode = selectCount;
   lcd.setCursor(7,1);
   lcd.print("OFF");
   digitalWrite(flashlightstatus ,LOW);
   lcd.setCursor(7,1);
   lcd.print(" ON");
   digitalWrite(flashlightstatus ,HIGH);
 if(selectCount > 1)
   {selectCount = 0;}
flashlightmode = selectCount;
   lcd.setCursor(7,1);
   lcd.print("OFF");
   digitalWrite(hamstatus ,LOW);
   lcd.setCursor(7,1);
   lcd.print(" ON");
   digitalWrite(hamstatus ,HIGH);
 if(selectCount > 1)
   {selectCount = 0;}
hammode = selectCount;
  lcd.setCursor(7,1);
  lcd.print("OFF");
   lcd.setCursor(7,1);
   lcd.print(" ON");
 if(selectCount > 1)
   {selectCount = 0;}
lastpresscount = pressCount;
Moderator edit: [code] [/code] tags added.
AWOL
Did you have a question?
aaron361068
Yes, sorry if I was not clear.
How do I make it so that I have an option to make a device only go on when the jeeps accessories are on so I will not kill the battery, or always on or always off.
AWOL
Can I suggest a code tidy-up before you add any features?
You have stuff Iike this
Code: [Select]
int frontlightsstatus = 10; which is difficult to tell of it is an input pin designator, or an actual status.
Pin designators should be byte constants.
A trip through the code auto-format would be welcome too.
aaron361068
Thank you ill work on that and get back.
nicoverduin
While you are at it, some more comments helps :)...does not cost any more code. :)
Met vriendelijke groet / kindest regards
Nico Verduin
www.verelec.nl
Do not PM me for personal consultancy unless you are willing to pay for it.
aaron361068
ok i changed some things. what do you think now
Code: [Select]
const int pushButtonPin = 2;  //button that will swithch between modes, like windsheld wippers, and rearlight
const int selector = 12;   // button that will change the settings of each modewindshieldpower
int pressCount = 0;
int windshieldpower = 1;  // i want this to be able have to ability to be on / off / and intermittently on so that
int frontlightspower = 10;
int rearlightpower = 11;
int radiopower = 13;
int flashlightpower = A1;
int hampower = A2;
int antennaup = A3; //antenna up and down is seperate because the factory motor has a seperate wire for moving up and moving down
int prevState = LOW; //part of debounce/counter for the mode button
int currState;
int prevState2 = LOW; //part of dedbounce/ coutner for the selector button
int currState2;
#include <Wire.h>
int radiomode = 0;
int hammode = 0;
  lcd.begin( 16, 2 );
  pinMode(windshieldpower, OUTPUT);
  pinMode(frontlightspower, OUTPUT);
  pinMode(rearlightpower, OUTPUT);
  pinMode(radiopower , OUTPUT);
  pinMode(flashlightpower , OUTPUT);
  pinMode(hampower , OUTPUT);
      pressCount++;
    delay(10);
      selectCount++;
    delay(100);
    pressCount = 0;
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print("Mode:");
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print("Mode:");
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print("Mode:");
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("radio");
      lcd.setCursor(0,1);
      lcd.print("Mode:");
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print("Mode:");
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("HAM");
      lcd.setCursor(0,1);
      lcd.print("Mode:");
    /* if(pressCount == 7){                  not using this yet
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.setCursor(0,1);
     lcd.print("Mode:");
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(7,1);
      lcd.print("OFF");
      digitalWrite(windshieldpower,LOW);
      lcd.setCursor(7,1);
      lcd.print(" ON");
      digitalWrite(windshieldpower,HIGH);
    if(selectCount > 1)
      selectCount = 0;
      lcd.setCursor(7,1);
      lcd.print("OFF");
      digitalWrite(frontlightspower ,LOW);
      lcd.setCursor(7,1);
      lcd.print(" ON");
      digitalWrite(frontlightspower ,HIGH);
    if(selectCount > 1)
      selectCount = 0;
      lcd.setCursor(7,1);
      lcd.print("OFF");
      digitalWrite(rearlightpower ,LOW);
      lcd.setCursor(7,1);
      lcd.print(" ON");
      digitalWrite(rearlightpower ,HIGH);
    if(selectCount > 1)
      selectCount = 0;
      lcd.setCursor(7,1);
      lcd.print("OFF");
      digitalWrite(radiopower ,LOW);
      lcd.setCursor(7,1);
      lcd.print(" ON");
      digitalWrite(radiopower ,HIGH);
    if(selectCount > 1)
      selectCount = 0;
      lcd.setCursor(7,1);
      lcd.print("OFF");
      digitalWrite(flashlightpower ,LOW);
      lcd.setCursor(7,1);
      lcd.print(" ON");
      digitalWrite(flashlightpower ,HIGH);
    if(selectCount > 1)
      selectCount = 0;
      lcd.setCursor(7,1);
      lcd.print("OFF");
      digitalWrite(hampower ,LOW);
      lcd.setCursor(7,1);
      lcd.print(" ON");
      digitalWrite(hampower ,HIGH);
    if(selectCount > 1)
      selectCount = 0;
      lcd.setCursor(7,1);
      lcd.print("OFF");
      lcd.setCursor(7,1);
      lcd.print(" ON");
    if(selectCount > 1)
      selectCount = 0;
Arrch
I think you have a ridiculous amount of white space between globals and setup, as well as between setup and loop. I also think you should be more consistent with your curly braces: either have them on separate lines (recommended):
Code: [Select]
if (someCondition)
  // code here
or on the same line as the if statement, but with a space between the end of the statement and the brace:
Code: [Select]
if (someCondition) {
  // code here
aaron361068
more changes, im learning slowly but surely
Code: [Select]
int pressCount = 0;
int hampower = A2;
int currState;
int currState2;
#include <Wire.h>
int radiomode = 0;
int hammode = 0;
  lcd.begin( 16, 2 );
      pressCount++;
    delay(10);
      selectCount++;
    delay(100);
  if(pressCount > 9)
    pressCount = 0;
    if(pressCount == 1)
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print("Mode:");
    if(pressCount == 2)
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print("Mode:");
    if(pressCount == 3)
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print("Mode:");
    if(pressCount == 4)
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("radio");
      lcd.setCursor(0,1);
      lcd.print("Mode:");
    if(pressCount == 5)
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print("Mode:");
    if(pressCount == 6)
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("HAM");
      lcd.setCursor(0,1);
      lcd.print("Mode:");
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.setCursor(0,1);
     lcd.print("Mode:");
    if(pressCount == 0)
      lcd.clear();
      lcd.setCursor(0,0);
  if(pressCount == 1)
      lcd.setCursor(7,1);
      lcd.print("OFF");
      lcd.setCursor(7,1);
      lcd.print(" ON");
    if(selectCount > 1)
      selectCount = 0;
  if(pressCount == 2)
      lcd.setCursor(7,1);
      lcd.print("OFF");
      lcd.setCursor(7,1);
      lcd.print(" ON");
    if(selectCount > 1)
      selectCount = 0;
  if(pressCount == 3)
      lcd.setCursor(7,1);
      lcd.print("OFF");
      lcd.setCursor(7,1);
      lcd.print(" ON");
    if(selectCount > 1)
      selectCount = 0;
  if(pressCount == 4)
      lcd.setCursor(7,1);
      lcd.print("OFF");
      lcd.setCursor(7,1);
      lcd.print(" ON");
    if(selectCount > 1)
      selectCount = 0;
  if(pressCount == 5)
      lcd.setCursor(7,1);
      lcd.print("OFF");
      lcd.setCursor(7,1);
      lcd.print(" ON");
    if(selectCount > 1)
      selectCount = 0;
  if(pressCount == 6)
      lcd.setCursor(7,1);
      lcd.print("OFF");
      lcd.setCursor(7,1);
      lcd.print(" ON");
    if(selectCount > 1)
      selectCount = 0;
  if(pressCount == 7)
      lcd.setCursor(7,1);
      lcd.print("OFF");
      lcd.setCursor(7,1);
      lcd.print(" ON");
    if(selectCount > 1)
      selectCount = 0;
AWOL
Quote
UKHeliBob
A couple of suggestions.
Instead of using a series of if tests to check the value of presscount use if/else.  This will avoid the program testing every value of pressount.  Alternatively change to using switch/case.  I find that easier to read than a series of ifs and it also avoids the program testing values that cannot be true.
Why do you have 2 sections of code testing the value of presscount ?  Could you not combine them ?
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
