Topic: Grid follower robot. Need help... (Read 9783 times) previous topic - next topic
aksh4241
did you completed the same project???
if yes, can you please mail it???
or just send it here?
jseery
I cleaned up your code.  You referenced solveTheGrid but the function name was SolveTheGrid.  A few parentheses and brackets were missing as well.  One function was referenced before it was declared so I moved it.  This will compile but as far as working as you want, I didn't spend the time assembling motors and sensors.  As far as the loop, I recommend using If..Else if..Else control structure.
Code: [Select]
#define leftCenterSensor   3
#define leftNearSensor     4
#define leftFarSensor      5
#define rightCenterSensor  2
#define rightNearSensor    1
#define rightFarSensor     0
int state=LOW;
int lastState=LOW;
int count=0;
int leftCenterReading;
int leftNearReading;
int leftFarReading;
int rightCenterReading;
int rightNearReading;
int rightFarReading;
#define leapTime 150
#define leftMotor1  10
#define leftMotor2  9
#define rightMotor1 6
#define rightMotor2 5
void readSensors(){
  leftCenterReading  = analogRead(leftCenterSensor);
  leftNearReading    = analogRead(leftNearSensor);
  leftFarReading     = analogRead(leftFarSensor);
  rightCenterReading = analogRead(rightCenterSensor);
  rightNearReading   = analogRead(rightNearSensor);
  rightFarReading    = analogRead(rightFarSensor);
void turnLeft(){
     while(analogRead(rightCenterSensor)<750||analogRead(leftCenterSensor)<750){
     digitalWrite(leftMotor1, LOW);
    digitalWrite(leftMotor2, HIGH);
    digitalWrite(rightMotor1, HIGH);
    digitalWrite(rightMotor2, LOW);
    delay(2);
    digitalWrite(leftMotor2, LOW);
    digitalWrite(rightMotor1, LOW);
    delay(1);
void SolveTheGrid(){
  if (count==2)
    turnLeft();
  while(analogRead(rightCenterSensor)>750){
    delay(2);
    delay(1);
    void turnRight(){
  while(analogRead(rightCenterSensor)<750){
     digitalWrite(leftMotor1, HIGH);
    digitalWrite(rightMotor2, HIGH);
    delay(2);
    delay(1);
    delay(2);
    delay(1);
   while(analogRead(leftCenterSensor)>750){
    delay(2);
    delay(1);
  void straight(){
  if( analogRead(leftCenterSensor)>750){
    delay(1);
    delay(5);
    return;
  if(analogRead(rightCenterSensor)>750){
    delay(1);
    delay(5);
    return;
    delay(4);
    delay(1);
  void endmotion(){
void setup(){
  pinMode(leftCenterSensor, INPUT);
  pinMode(leftNearSensor, INPUT);
  pinMode(leftFarSensor, INPUT);
  pinMode(rightCenterSensor, INPUT);
  pinMode(rightNearSensor, INPUT);
  pinMode(rightFarSensor, INPUT);
  pinMode(leftMotor1, OUTPUT);
  pinMode(leftMotor2, OUTPUT);
  pinMode(rightMotor1, OUTPUT);
  pinMode(rightMotor2, OUTPUT);
//  state=digitalRead(s1);
void loop(){
  readSensors();
  if(leftNearReading>750 && rightNearReading>750 && (leftCenterReading<750 || rightCenterReading<750)){
    straight();
  else{
    SolveTheGrid();
  if(leftNearReading<750 && rightNearReading<750 && leftCenterReading<750 && rightCenterReading<750){
    state=1;
    count++;
  lastState=state;
