Topic: Ultrasonic Sensor (Read 3112 times) previous topic - next topic
Vincent19
Code: [Select]
#define trigPin 9
#define echoPin 8
  Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  long duration, distance;
  digitalWrite(trigPin, LOW);  // Added this line
  delayMicroseconds(2); // Added this line
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10); // Added this line
  duration = pulseIn(echoPin, HIGH);
  distance = duration*340 / 20000;
    Serial.print(distance);
    Serial.println(" cm");
Hey guys, this is the code that I get somewhere else online.
Can anyone try to explain to me why is the calculation for distance is such ? I understand that thius is the formula for distance  = time* velocity. How does that 20000 comes from ? I know that the distance that we interest in have to be divided by 2. So I guesse there is where the 2 comes from but why multiple 10 power of 4 ?
Thanks !
Arrch
Speed of sound is ~34 cm per millisecond. pulseIn() returns a value in microseconds.
Vincent19
Okay, now I am suck in the unit conversion. Get confused although I know the facts LOL.
Anyone ?
AWOL
Vincent19
How did I convert it ? I just get myself too confused with that :(
Arrch
Convert what to what?
Vincent19
Ok to be clear, why should I divide by 20000 ?
Thanks
AWOL
340 metres per second.
100 cm per metre.
Twice the distance (round trip timing)
Arrch
Thanks
Because you receive a time in microseconds, and speed travels at 0.034029 centimeters per microsecond
Vincent19
Okay, will take some time to do the math tricks here :)
By the way, why do we need the microsecond(2) in between when trigger LOW and HIGH ?
Thnaks
AWOL
Because the sonar needs a minimum pulse length  to trigger it
Vincent19
And the minimum pulse length is 2 microseconds ? So means thet after 2 uS, the trigger pin will be trigger to send sonar ?
Thanks
Arrch
Don't know, what does the Datasheet say for whatever sensor you are using?
Vincent19
I am using HC-SR04 :) Okay, I should read the datasheets in more details then.
Thanks !
keeper63
Vincent19 - If there is anything you should learn from this exchange, it is this:
Magic numbers are bad.
That is what "20000" is in that piece of code - it's a blatent example of a "magic number" in programming:
https://en.wikipedia.org/wiki/Magic_number_%28programming%29#Unnamed_numerical_constants
Ideally, rather than "20000", named constants or similar (inline or block comments, for instance) would have been used to explicitly tell you, as another programmer, where and why that number was used.
You see these kinds of numbers all over the place in code everywhere (it isn't just limited to code for the Arduino, either, unfortunately); it is a hallmark of poor programming practice. There are only very rare cases when "undefined" constants may be utilized in programming (the stupid thing is invariably you'll see someone stick a comment at the end of these cases that says something like "adding one to this variable").
Learn and understand this, and don't do this in your own code; whether you intend to publish the code or not, you'll save all of us headaches and questions down the road, and you'll be a better programmer as a result.
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
