Topic: Stacking Shields (Read 954 times) previous topic - next topic
Skywolf
Hello,
I'm finally starting to get used to the Arduino! As I get more involved with projects that require more modules, I've found myself blocked by the fact that there are only 2 voltage pins and 3 GND ports on my Uno.
I was wondering if I could stack multiple shields on top of each other so that I could preserve my GND/Voltage ports for modules that didn't have shields. If this wasn't an option, is there any way I could set up one/multiple Arduinos to be able to power multiple modules?
AmbiLobe
Yes. You have the flexibility to make a customized system with multiple boards. It is not easy. I just use DB-25 connectors between my 4 boards. I stacked onto an Arduino Due for a vertically stacked layer, but after that, I expanded horizontally with DB-25 connectors.
oric_dan
Check out various prototyping shields.
robtillaart
Quote
see - http://shieldlist.org -
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
