Topic: UsbtinyISP in arduino IDE (Read 4056 times) previous topic - next topic
Portal
I'm trying to program the arduino uno with a usbtiny but after selecting ubstinyisp under programmer. But I upload the blink code but Iit says, "Com 3" not found. What do I do
runaway_pancake
Is the USBtinyISP connected to COM3?
Is it on another COM (Tools \ Serial Port dropdown) ?
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
hugo007
#2
Jul 07, 2013, 07:25 pm Last Edit: Jul 07, 2013, 07:32 pm by HugoPT Reason: 1
Quote
Well if you are using a usbtinyisp the to upload the program you must go to file and then use the option "Upload using programmer"
Quote
@Runaway Pancake
Usbtiny programmer does not use Serial Port.
You know uploading the code using the usbtiny will overwrite the bootloader right?
This is not a problem just a feature.
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
runaway_pancake
#3
Jul 07, 2013, 07:32 pm Last Edit: Jul 07, 2013, 08:17 pm by Runaway Pancake Reason: 1
Tools \  Board
Select [usbtinyisp]ATmega328
(if that's what it is)
click the Upload button from there (No?)
OK.  I hadn't noticed that before, but the USBtinyISP doesn't show up in the Serial Port dropdown.
I broke away, got mine out, and plugged it in and all.
It uploaded sketches whether COM1 or COM3 checked.
When I plug the USBtinyISP in, I get the Windows confirmation "dingdong", and the green LED goes on.  The red one goes on during transfers.
Found I forgot a step about burning bootloaders, too.  Put that in my notebook.
Portal
Cool thanks guys, I had to hit ctrl + shift + u or go to file upload using programmer.
Cactusface
Hi All,
            Not quite the same thing but it seems that in any one programming period, if I unplug my Uno to test then re-connect to program, good old Windows re-assigns the port so the upload stops, requesting another port to be selected. I am sure this is another windows querk!! even on Win-7 64bit. I sometimes wish I was still using a MAC...
Regards
Mel.
Open your mind! But not too far, your brains might fall out.
Also like Photography, model building and my 300+ Cacti and Succs.
