Topic: Help with ModBus RTU Master-Slave: SimpleModbus [SOLVED] (Read 352801 times) previous topic - next topic
noiasca
... I checked your crosspost - but to be honest
- I don't see your code (with your code I've meant a sketch which compiles, not a snapshot of a function out of the library!)
- I don't see a datasheet to your 1000 register device
DE: Wie man Fragen postet:
1. was hat man (Sketch und Hardware)
2. was SOLL es machen
3. was macht es: IST (Fehlverhalten, Fehlermeldungen, Serial.Output ...)
4. Eine Frage stellen bzw. erklären was man erwartet
Ashokjay
Hi ,
I am using LT+5310 multifunction meter with rs485 and arduino uno micro controller
communication between micro controller and energy meter(multi function meter ) is not happening. i am getting data all zeros
please help where is the problem my source code is posted  below
#include <SimpleModbusMaster.h>
//////////////////// Port information ///////////////////
#define baud 9600
#define timeout 1000
#define polling 500 // the scan rate
#define retry_count 10
// used to toggle the receive/transmit pin on the driver
#define TxEnablePin 2
// The total amount of available memory on the master to store data
#define TOTAL_NO_OF_REGISTERS 2
// This is the easiest way to create new packets
// Add as many as you want. TOTAL_NO_OF_PACKETS
// is automatically updated.
enum
  PACKET1,
  TOTAL_NO_OF_PACKETS // leave this last entry
// Create an array of Packets to be configured
Packet packets[TOTAL_NO_OF_PACKETS];
// Masters register array
unsigned int regs[TOTAL_NO_OF_REGISTERS];
 // Initialize each packet
  modbus_construct(&packets[PACKET1], 1, READ_HOLDING_REGISTERS, 40101, 2, 0);
  // Initialize the Modbus Finite State Machine
  modbus_configure(&Serial1, baud, SERIAL_8E2, timeout, polling, retry_count, TxEnablePin, packets, TOTAL_NO_OF_PACKETS, regs);
    modbus_update();
    Serial.print(packets[PACKET1].requests);
    Serial.print(";successful_requests: ");
    Serial.print(packets[PACKET1].successful_requests);
    Serial.print(";failed_requests: ");
    Serial.print(packets[PACKET1].failed_requests);
    Serial.print(";exception_errors: ");
    Serial.print(packets[PACKET1].exception_errors);
    Serial.println(regs[0]);
    Serial.println(regs[1]);
noiasca
please:
- write which target/processor you are using.
- add a link from where you have downloaded the library (there are unfortunatly some variants online - so we need the exact information what you are using)
- put your code in code tags
- copy you serial output to a post with code tags
- provide a link to the datasheet of your slave device you want to read (we do not know why you have choosen READ_HOLDING_REGISTERS and start adress 40101)
- upload a picture wherein we can clearly see you wiring between processor - 485breakout and slave - which pin goes where?
kprakash
Hello all,
I am Nike, working with an energy meter (Schneider Conzerv EM 6436), and trying to read the register values using modbus. I saw the post http://forum.arduino.cc/index.php?topic=176142.15 and went through the entire thread (took nearly 2 days).
I followed the schematic at https://aglasspool.files.wordpress.com/2010/03/diagram1rev3.jpeg. I modified the connections with necessary resistors and Arduino Yun is master and conzerv meter is slave.
I tried with the simpleModbusMaster example with necessary baud rate, slave ID and couldn't get any response. Please help me out. I am here by attaching the manual of energy meter.
Manual : http://www.powertechinternational.in/catalouges/SCHNEIDER-CONZERV-EM-6400.pdf
Thanks in advance
Nike
nehe_bhimaji
Dear All
I am also struggling for Modbus communication between Arduino UNO and Multispan Energy Meter AVH 14N-M1
I am using RS485 Board and UNO hardware serial connection is attached
In manual on page 5  they have given register MAP as 30001  to 30052 as 16 bit and each parameter value occupi 2 16 bit registers
Buad rate set in 9600  and port setting is 8E1  as meter is also in same setting
but as tried to read register 30009 ( r phase voltage  & 30029 Frequency)  on Serial monitor I get only 0,0,0,0 and so on and some garbage characters
I think it may be due to I am using Same Serial port for Serial monitor
and i do not know wheather is it correct to use one serial port for both???
Then I decide to display the value on Nextion display using software serial
I have also tried to convert both register in float and send to Nextion but still result is 0.0 on dispaly
Float conversion
Please suggest
Code is also attached
noiasca
using one serial port for debug messages and for the nextion display will not work.
Use the sample sketch with debug information to the serial and leave away the nextion as long as you can't get information from your device.
If you don't have another option, use soft serial for the modbus and hardware serial for debug messages. But best solution is a microcontroller with more than one hardware serial, i.e. the Arduino Mega.
Check if your device has really device ID 3
Check if you find any information in your manual if its READ_HOLDING_REGISTERS, or READ_INPUT_REGISTERS or any other MODBUS function.
Check if the registers are decimal base or hex in the manual. In the second case use 0x30001 instead.
If you need more specific advices, link to the map / datasheet of your device.
sayali07
I have 3 phase DC1040 pid controller .I want to read pv value of controller through RS485-ttl module using arduino.The meter details is baud rate =38400
                                           pv register=139
this is my code
#define baud 38400
#define polling 300 // the scan rate
#define retry_count 50
#define TOTAL_NO_OF_REGISTERS 13
enum
  PACKET1,
  PACKET2,
  PACKET3,
  PACKET4,
  Serial.begin(38400);
  modbus_construct(&packets[PACKET1], 1, READ_INPUT_REGISTERS, 139, 1, 10);
 // modbus_construct(&packets[PACKET2], 1, READ_HOLDING_REGISTERS, 0000, 1, 11);
  //modbus_construct(&packets[PACKET4], 1, READ_HOLDING_REGISTERS, 1, 1, 12);
  //modbus_construct(&packets[PACKET1], 1, PRESET_MULTIPLE_REGISTERS,1, 1,0);
  modbus_configure(&Serial, baud, SERIAL_8N1, timeout, polling, retry_count, TxEnablePin, packets, TOTAL_NO_OF_PACKETS, regs);
  modbus_update();
  float pv;
  pv = regs[10];
  Serial.print("requests: ");
  Serial.println(packets[PACKET1].requests);
  Serial.print("successful_requests: ");
  Serial.println(packets[PACKET1].successful_requests);
  Serial.print("failed_requests: ");
  Serial.println(packets[PACKET1].failed_requests);
  Serial.print("exception_errors: ");
  Serial.println(packets[PACKET1].exception_errors);
  Serial.print("pv: ");
  Serial.println(regs[10]);
when i run this code no output is o..
noiasca
If you wonder, why you haven't got any response so far, rephrase your qestion please.
Be more specific:
-What output do you get (copy-paste the serial monitor output using code tags)
-Write which values you expect instead.
-Provide a link of the datasheet of your device, where we can see the registers and functions of your device
sayali07
Hello,
I want to read data from a DC 1040 PID Controller, with my Arduino and I am using RS485-TTL module .  I'am using a simple modbus master library  it's default communication is :
Protocol: MOdBUS RTU
Baud Rate: 38400
Parity: ODD
Stop Bits: 1
Data Bits: 8
 I want to read PV Value  which is register 138.
this is my code....
Code: [Select]
#define baud 38400
enum
  PACKET1,
  PACKET2,
  PACKET3,
  PACKET4,
  modbus_construct(&packets[PACKET1], 1, READ_HOLDING_REGISTERS,138, 1, 10);
  modbus_configure(&Serial, baud, SERIAL_8O1, timeout, polling, retry_count, TxEnablePin, packets, TOTAL_NO_OF_PACKETS, regs);
  modbus_update();
  float pv;
  pv = regs[10];
The following attachment include connection made, datasheet, comm regs mapping,output
noiasca
just as a quick tipp: in the manual page 27 you find
PV
Process Value
008A 138 03H -1999~9999
on page
03 (03H) Reading multiple registers value from slave controller
in the pdf of the library you will find following information:
Function 4 - READ_INPUT_REGISTERS 4 // Reads the binary contents of input registers (3X references) in
the slave. Not writable.
therefore I guess your modbus_construct is wrong.
sayali07
I change the construct in my code ...
Code: [Select]
#include <SimpleModbusMaster.h>[color=#222222][/color]
//////////////////// Port information ///////////////////[color=#222222][/color]
#define baud 38400[color=#222222][/color]
#define timeout 1000  [color=#222222][/color]
#define polling 300 // the scan rate[color=#222222][/color]
#define retry_count 50[color=#222222][/color]
// used to toggle the receive/transmit pin on the driver[color=#222222][/color]
#define TxEnablePin 2 [color=#222222][/color]
// The total amount of available memory on the master to store data[color=#222222][/color]
#define TOTAL_NO_OF_REGISTERS 13[color=#222222][/color]
// This is the easiest way to create new packets[color=#222222][/color]
// Add as many as you want. TOTAL_NO_OF_PACKETS[color=#222222][/color]
// is automatically updated.[color=#222222][/color]
enum[color=#222222][/color]
{[color=#222222][/color]
  PACKET1,[color=#222222][/color]
  PACKET2,[color=#222222][/color]
  PACKET3,[color=#222222][/color]
  PACKET4,[color=#222222][/color]
  TOTAL_NO_OF_PACKETS // leave this last entry[color=#222222][/color]
};[color=#222222][/color]
// Create an array of Packets to be configured[color=#222222][/color]
Packet packets[TOTAL_NO_OF_PACKETS];[color=#222222][/color]
// Masters register array[color=#222222][/color]
unsigned int regs[TOTAL_NO_OF_REGISTERS];[color=#222222][/color]
void setup()[color=#222222][/color]
  // Initialize each packet[color=#222222][/color]
  Serial.begin(38400);[color=#222222][/color]
  modbus_construct(&packets[PACKET1], 1, READ_MULTIPLE_REGISTERS,138, 1, 10);[color=#222222][/color]
  // Initialize the Modbus Finite State Machine[color=#222222][/color]
  modbus_configure(&Serial, baud, SERIAL_8O1, timeout, polling, retry_count, TxEnablePin, packets, TOTAL_NO_OF_PACKETS, regs);[color=#222222][/color]
}[color=#222222][/color]
void loop()[color=#222222][/color]
  modbus_update();[color=#222222][/color]
  float pv;[color=#222222][/color]
  pv = regs[10];[color=#222222][/color]
  delay(1000);[color=#222222][/color]
  Serial.print("requests: ");    [color=#222222][/color]
  Serial.println(packets[PACKET1].requests);[color=#222222][/color]
  Serial.print("successful_requests: ");  [color=#222222][/color]
  Serial.println(packets[PACKET1].successful_requests);[color=#222222][/color]
  Serial.print("failed_requests: ");  [color=#222222][/color]
  Serial.println(packets[PACKET1].failed_requests);  [color=#222222][/color]
  Serial.print("exception_errors: ");  [color=#222222][/color]
  Serial.println(packets[PACKET1].exception_errors); [color=#222222][/color]
  Serial.print("pv: ");  [color=#222222][/color]
  Serial.println(regs[10]);                          [color=#222222][/color]
}       [color=#222222][/color]
Still no output.......
please correct me.
noiasca
sayali07
I change my construct in my code..
Code: [Select]
#define baud 38400
enum
  PACKET1,
  PACKET2,
  PACKET3,
  PACKET4,
  modbus_construct(&packets[PACKET1], 1, READ_MULTIPAL_REGISTERS,138, 1, 10);
  modbus_update();
  float pv;
  pv = regs[10];
Please correct me if anything else..
dhrubajyoti2009
Hello All,
I am facing trouble with interfacing Selec Panel Meter MFM376C with RS485 Modbus. Somebody please help me out.
Microcontroller - Arduino Mega 2560
Panel Meter - MFM376C
Library - SimpleModbusMaster V2.2
Connections are done like  -
   Set the slave device as per mentioned configuration
   Panel Meter - Selec MFM376C
   Baud Rate - 19200
   Bits,Parity,Stop bits - 8N1  (8Bits, No Parity, Stop bit 1)
   Slave ID - 5
   RS485 Pin - 7 +Ve, 14 -Ve
   Conversion Module
   RS485 to RS232 Conversion Module
   VCC - External Stable Power 5V DC
   GND - Common with all circuit
   A - Connected to 7  MFM376C (+Ve)
   B - Connected to 14 MFM376C (-Ve)
   DI - Arduino TX1 Pin
   RO - Arduino RX1 Pin
   DE - RO - Connected together attached to one digital pin of Arduino 22
The code -
//Main header file for operation
//Inititalize the modbus communication parameters
#define Baud_Rate 19200        //Baud rate for the Sslave
#define Time_Out 1000          //Time out for the Slave
#define Polling 100            //Number of times data retreival for Slave
#define Retry_Count 10         //Retry count for failures of Slave
#define RX_TX_Enable 22        //Toggling pin for the data retreival & transmission
//Initialize the master device configurations
#define Total_Registers 1      //Total number of registers data reads
//Packet configuration
enum
  Packet_1,
  Total_Packets                //Total number of packets created
//Create an array of Packets to be configured
Packet Packets[Total_Packets];
//Defining the data storage array in master
unsigned int Data[Total_Registers];
//Variables for normal Arduino operations
long Old_Time = 0;             //Storing the millisec for the last phase
long Wait_Time = 1200;         //Defines the wait before the next printing
unsigned long Curr_Time;       //Defines the current millisec
//Setting up the Arduino
  //Configuring the serial communication
  Serial.println("MODBUS Testing");
  //Inititalizing the packet
  //Packet Identity, Slave ID, Operation Code, Address of register, No of register, Local start ID
  modbus_construct(&Packets[Packet_1], 5, READ_HOLDING_REGISTERS, 0x3903, 2, 0);
  modbus_configure(&Serial1, Baud_Rate, SERIAL_8N1, Time_Out, Polling, Retry_Count, RX_TX_Enable, Packets, Total_Packets, Data);
  modbus_update();
  float Active_Power;
  unsigned long Temp_Val = (unsigned long)Data[1] << 16 | Data[0];
  Active_Power = *(float*)&Temp_Val;
  Curr_Time = millis();
  if (Curr_Time - Old_Time >= Wait_Time)
    Serial.print("Exception errors: ");
    Serial.println(Packets[Packet_1].exception_errors);
    Serial.print("Failed requests: ");
    Serial.println(Packets[Packet_1].failed_requests);
    Serial.print("Successful requests: ");
    Serial.println(Packets[Packet_1].successful_requests);
    Serial.print("Low byte: ");
    Serial.println(Data[0]);
    Serial.print("High byte: ");
    Serial.println(Data[1]);
    Serial.print("Active_Power ");
    Serial.println(Active_Power);
    Serial.println("----------------------------------");
    Old_Time = Curr_Time;
Now I am frustated trying all the options, please please please help me out.
noiasca
a)
Quote
please check twice:
to the MEGA?
to the RS485 module ?
to your slave device ?
to your external Power device ?
b)
What result do you get on the Serial Monitor?
c)
Additionally, please provide a link to the datasheet of your device.
