Topic: 555 timer - failed at the first hurdle [FIXED] (Read 7225 times) previous topic - next topic
acboother
Jul 07, 2013, 10:10 pm Last Edit: Jul 08, 2013, 01:19 am by acboother Reason: 1
Even before I get to do anything with my 555 timer I thought I'd play with it and already I have fallen at the first hurdle (perhaps even before getting to the starting gate) :(
It wired up as per http://www.instructables.com/file/F0UNQNHH742SU5Y for an astable timer (or so I hope).
I've plugged in a PC scope that I think I've gotten to grips with and have pin 3 on the scope and it grounded.
I have a 5v power supply which I use to power my breadboard Arduino plugged in (no MEGA328 or anything).
I have lovely square wave output... that doesn't change when I change the resistor values, pull out the capacitors.... WTF?!
And the thing that really bothers me though is the 555 is getting very hot! Is this normal or am I stoking up a little BBQ.
Changing briefly to a 9v battery and the square wave goes away to be replaced by nothing useful looking. So I deduce the square wave signal is something to do with the 5v regulated power supply (which is powered by a 10v DC plug in the wall thingy) although that defeats my logic as well.
Obviously I'm looking for the wiring cock-up but don't see it so will have to plug it back in soon sometime but I'm worried I may just burn all my sausages and burgers before I get it sorted.
larryd
The speaker is probably 8 ohms so drive it with a power transistor not the 555
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
acboother
I'm not driving the speaker... I'm driving nothing but the scope on pin 3
larryd
No technical PMs.
SurferTim
If you are using a 100K pot as the schematic shows, insure you do not turn it to zero ohms. I usually use a 1K resistor in series just to prevent overloading the discharge FET. Without a little resistance, that would be a short circuit.
acboother
Well here we go...
Yellow wire is pin3 to scope. both scope channels plugged into it.
capacitors are 103 and 104 respectively towards the top right. have had a 470uF in place of the 104
variable resistors are now 207k upper and 110k lower set to max by plugging into outer pins but I have had them using centre pin and end pins to vary the resistance.
sorry its in a pickle but i've been tearing it apart and...
acboother
runaway_pancake
Rig it up with resistors first.
(It looks like the pot wipers aren't connected anyway.)
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
acboother
In this photo they aren't connected - I did this to ensure that I didn't have zero resistance in error by a wiper being at the wrong end.
larryd
Confirm with a DVM you have +v on pin 8 to pin 1
Double check the red wire going to the top Pot, is it going to the lead of the Pot?
No technical PMs.
runaway_pancake
I think that an 8? speaker on the output is not a great idea.
I'd put a resistor in series; 100?, 220?, something like that.
acboother
I have no speaker o the output. I have only a scope
runaway_pancake
Have some load on the output.
  got "2K"?
larryd
What is written on the capacitor connected to pin 6 and ground?
No technical PMs.
AmbiLobe
Proto boards may need 22 gauge wire to fit in the hole. If the jumpers are 20 gauge and the pot is 24 gauge, a loose connection may exist which places a gap between wires instead of a node. A cap may use thin wire and a jumper may have fat wire that spreads the internal metal strips.
The power decoupling cap is not seen.
