I will use just a standard red LED with no specs for L2, so I am assuming 2v forward drop and 20 mA. With a 2.7v source in the capacitor, the online calculator suggest a 39 ohm resistor in series.
I kind of looked at that and said 1)2.7 v vs 2v, meh; 2) 39 ohms is practically a wire; and, 3) I don't have one of those anyway.
I'll go to the Shack and see if they have a horribly overpriced package of 5 smallish resistors and stick one in there to do SOME current limitation.
Would you concur with a smallish 39 ohm value or suggest something else? Or would you suggest a completely different testing methodology? All I really want to do is see if I could use a giant cap (instead of a rechargeable battery) to drive a solar garden light.
EDIT: In general, what is the preferred method of driving a load needing current limitation from a low impedance source? Particularly when it is a low impedance, low voltage source for which voltage dropout due to something like a diode or resistor means there could be insufficient voltage to accomplish the desired work? Some sort of shunt regulator?
