Topic: I keep getting "Error compiling." when trying to upload sketches (Read 5983 times) previous topic - next topic
PhyberLogik
I've been using my Arduino Uno for a few months without any problems. Today I tried to compile a sketch and it gave me a Error compiling message. It didn't give me any errors in the output field. I tried it again with the Blink sketch and it gave me the same error.
If it's at all helpful, this is what the output said,
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\variants\standard C:\Users\PHYBER~1\AppData\Local\Temp\build7313227511724971617.tmp\Blink.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build7313227511724971617.tmp\Blink.cpp.o
Any help would be greatly appreciated.
CrossRoads
Under File:Preferences, check the verbose output boxes, recompile again and post all the notes that come up.
Perhaps your IDE got corrupted. You could try reloading it.
PhyberLogik
The verbose output boxes were checked, that was the entirety of the output. I uninstalled the IDE and reinstalled it, it gives me the same problem.
CrossRoads
When I select Uno, and Blink sketch, I see all this when Verify button is clicked.  You can enlarge the IDE window and the lower section, highlight all that is there:
Code: [Select]
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\Blink.cpp -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\Blink.cpp.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\avr-libc\malloc.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\malloc.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\avr-libc\realloc.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\realloc.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\WInterrupts.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\WInterrupts.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\wiring.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\wiring.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\wiring_analog.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\wiring_analog.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\wiring_digital.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\wiring_digital.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\wiring_pulse.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\wiring_pulse.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\wiring_shift.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\wiring_shift.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\CDC.cpp -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\CDC.cpp.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\HardwareSerial.cpp.o
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void store_char(unsigned char, ring_buffer*)':
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:98: warning: comparison between signed and unsigned integer expressions
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void __vector_18()':
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:127: warning: unused variable 'c'
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'void HardwareSerial::begin(long unsigned int, byte)':
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:368: warning: unused variable 'current_config'
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'virtual size_t HardwareSerial::write(uint8_t)':
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:467: warning: comparison between signed and unsigned integer expressions
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HID.cpp -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\HID.cpp.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\IPAddress.cpp -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\IPAddress.cpp.o
: AND SO ON, EDITED TO FIT IN ONE POST
C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\Blink.cpp.elf C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\Blink.cpp.hex
Binary sketch size: 1,084 bytes (of a 32,256 byte maximum)
PhyberLogik
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\variants\standard C:\Users\PHYBER~1\AppData\Local\Temp\build995371091343257421.tmp\Blink.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build995371091343257421.tmp\Blink.cpp.o
That's everything.
CrossRoads
Wow, that doesn't look right at all.
I don't know what to advise when it just stops like that.
CrossRoads
Any chance its a Windows permission issue, not letting the IDE create needed folders or something like that?
PhyberLogik
I just tried running as administrator, I got the same error but it gave me a lot more information.
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\Blink.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\Blink.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\avr-libc\malloc.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\malloc.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\avr-libc\realloc.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\realloc.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\WInterrupts.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\WInterrupts.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\wiring.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\wiring.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\wiring_analog.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\wiring_analog.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\wiring_digital.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\wiring_digital.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\wiring_pulse.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\wiring_pulse.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\wiring_shift.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\wiring_shift.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\CDC.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\CDC.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\HardwareSerial.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void store_char(unsigned char, ring_buffer*)':
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:98: warning: comparison between signed and unsigned integer expressions
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void __vector_18()':
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:127: warning: unused variable 'c'
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'void HardwareSerial::begin(long unsigned int, byte)':
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:368: warning: unused variable 'current_config'
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'virtual size_t HardwareSerial::write(uint8_t)':
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:467: warning: comparison between signed and unsigned integer expressions
PhyberLogik
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HID.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\HID.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\IPAddress.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\IPAddress.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\main.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\main.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\new.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\new.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\Print.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\Print.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\Print.cpp: In member function 'size_t Print::print(const __FlashStringHelper*)':
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\Print.cpp:44: warning: '__progmem__' attribute ignored
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\Stream.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\Stream.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\Tone.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\Tone.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\Tone.cpp:119: warning: only initialized variables can be placed into program memory area
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\USBCore.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\USBCore.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\WMath.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\WMath.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\WString.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\WString.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-ar rcs C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\core.a C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\malloc.c.o
CrossRoads
Ok, we need some software guru help here. I don't all that should be coming up.
If you compile a 2nd time, does it do the same?
PhyberLogik
CrossRoads
Okay, I'm calling in the cavalry - sent a request to the other moderators. Some one is bound to have seen this.
What is your computer & operating system? Does it have any recent upgrades/patches?
nickgammon
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
PhyberLogik
I'm running Windows 8. 1.30 GHz processor, 2GB Ram. It's a Toshiba Satellite C855D-S5302. No upgrades of any kind. I'm using 38GB out of 287GB on my C drive.
leo72
I don't use Windows but are you using the right IDE for the right OS?
I mean, are you using a 32-bits IDE on a 64-bits OS? Have you downloaded the IDE installer or the IDE package?
I see "programs-(x86)" into your path.
Try completely removing the IDE and downloading again the installer.
