Topic: LED control via Android smartphone (Read 3014 times) previous topic - next topic
kas
This BlinkM LED is controlled via an Android smartphone, using a virtual joystick
http://www.youtube.com/watch?v=Mapb0MIz6GQ
More info re Joystick Bluetooth Commander application in the Networking section
Enjoy
oric_dan
Cool, is there an .ino associated with this to look at?
kas
#2
Jul 19, 2013, 09:04 am Last Edit: Jul 19, 2013, 09:06 am by kas Reason: 1
Quote
Sure
Code: [Select]
// AndroBlinkM V1.2
// Arduino test sketch for Joystick BT Commander
// Drive a BlinkM LED
// * BlinkM connections to Arduino
// * GND     Analog 2
// * +5V     Analog 3
// * SDA     Analog 4
// * SCK     Analog 5
#include "Wire.h"
#include "BlinkM_funcs.h"
#define    DEBUG          true
#define    blinkm_addr  0x00
#define    ledPin       13                // LED pin
#define    STX          0x02
#define    ETX          0x03
int i=0;
int cmd[5] = {9, 9, 9, 9, 9};
void setup()  {
 Serial.begin(57600);                   // Adjust to your specific BT Board
 pinMode(ledPin, OUTPUT);
 BlinkM_beginWithPower();
 BlinkM_stopScript( blinkm_addr );      // turn off BlinkM startup script
 BlinkM_fadeToRGB( blinkm_addr, 0x00, 0x00, 0x00);
  if(Serial.available())  {             // Data received from smartphone
   delay(5);
   cmd[0] =  Serial.read();
   if(cmd[0] == STX)  {
     i=1;
     while(Serial.available() && ((cmd[i]=Serial.read()) != ETX)) {
       if(i>3)  break;
       i++;
 if(i==2)    setLED(cmd[1]);
 if(i==3)    setBlinkM(cmd[1], cmd[2]);
 delay(5);
void setBlinkM(int hue, int bright)    {
 hue = map(hue, 10, 110, 0, 255);
 bright = map(bright, 10, 110, 0, 255);
 bright = constrain(bright, 7, 255);
 if(DEBUG)    { Serial.print(hue);  Serial.print(", ");  Serial.println(bright); }  // ** DEBUG **
 BlinkM_fadeToHSB(blinkm_addr, hue, 255, bright);    // set blinkM hue & brightness
 delay(20);
void setLED(int LEDstatus)  {
 switch (LEDstatus) {
   case '1':
     if(DEBUG)    Serial.println("Button: ON");    // ** DEBUG **
     digitalWrite(ledPin, HIGH);
     BlinkM_setRGB( blinkm_addr, 0xff, 0xff, 0xff);
   case '2':
     if(DEBUG)    Serial.println("Button: OFF");    // ** DEBUG **
     digitalWrite(ledPin, LOW);
     BlinkM_setRGB( blinkm_addr, 0x00, 0x00, 0x00);
loop() code is identical as the pan/tilt project shown in the Robotic Section
More info for blinkM here
kas
#3
Aug 03, 2013, 07:58 am Last Edit: Aug 03, 2013, 08:04 am by kas Reason: 1
Joystick Bluetooth Commander Version 2.5 here
kas
Arduino sketch needs to be modified for Joystick Bluetooth Commander V3.X
(modified communication protocol)
More details here
kas
Joystick Bluetooth Commander is now Version 5.1
Code should be updated with new communication protocol
More info here and here
