Topic: RFID, SD card and real time clock door lock (Read 13958 times) previous topic - next topic
Grumpy_Mike
If I were doing this I would start off by defining the tags as variables
Code: [Select]
  // char tag[12] = {'3', '6', '0', '0', '7', '8', '9', '9', '8', '7'}; //tag 1
   // char tag2[12] = {'3', '6', '0', '0', '7', '8', '9', 'B', 'B', '5'}; //tag 2
long long  tags[] = { 0x3600789987, 0x3600789BB5 }; // define an array with two tags in it
char* names[] = { "my first name", "my second name"} // define an array of names
See http://arduino.cc/en/Reference/String
Then the main loop would look something like this:-
Code: [Select]
void loop(){
tag = checkInput()
if (tag != 0) {
    idNumber = validate(tag);
        if (idNumber != -1) {  // -1 indicates no access
          accessGrant(idNumber); // open door and print out name on LCD
          logAccess(idNumber);
          inviteLogin(); // set display to invite new login
else {
    accessDenied(idNumber);
This is called top down design. I have used functions I have yet to write but should show the clear logic of the operation. When you are satisfied with how it is supposed to work then go and implement those functions. Those functions may well call other functions like time stamp and so on.
ColeH
What if, instead of this for each tag that that is accepted,
Code: [Select]
if(strcmp(code, tag) == 0) {
         accessgranted();
         lcd.print("Jonnyblanch  ");
         digitalWrite(ledPin,HIGH);
Serial.print("Tag matches: ");
Serial.println(code);
         //digitalWrite(ledPin,HIGH);
         digitalWrite(rfidPin, HIGH);
         myFile = SD.open("log.txt", FILE_WRITE);
         // if the file opened okay, write to it:
         if (myFile) {
           Serial.print("Writing to log.txt...");
           myFile.print("Jonnyblanch");
           timestamp();
           // close the file:
           myFile.close();
           delay(2000);      // wait for a second or two
           return;                   //Go to the top, skip the bottom
I had just one.  I was thinking instead of, if(strcmp(code, tag) == 0), I were to have something like, if(strcmp(code, tag || tag2) == 0).  Then for each spot in which it displays information for each specific card, it then somehow were to print the info. for the card that was actually swiped.  The only way that I can think of to do that would be to have more if statements within this one, which would defeat the purpose of this whole idea.  I looked around online but I couldn't ind anything to help.
ColeH
Oh, and I forgot to mention having the strings for each id tag and name like you mentioned in your last post.
Grumpy_Mike
I don't think you are taking on board my suggestions of not using string compares for the token matching. If the token is put into a numeric variable then you can just use the normal ==.
You might get some ideas from the code of this project:-
http://www.thebox.myzen.co.uk/Hardware/RFID_Sequencer.html
I know there is a lot of stuff you don't need but it covers enrolling a token, storing it into EEPROM and matching a found token with a stored one.
ColeH
I kinda get what you are saying, in theory, but I still can't really put it into my code just yet.  What I don't really get in what you are telling me I should do is, for each tag that is allowed access, do I need to copy what you had in the loop again?  Also, I don't quite understand how it know "idnumber" relates to the name of the person too.  Would it make sense to take as much of the loop as possible, and put it into different functions(as long as its not specific to a certain id code/person)?
By the way, that was a very cool project you made.
Grumpy_Mike
Quote
No the point in coding is that you let the data drive the code, so if you want more of any data you don't have more code. There should be a fixed amount of code that could handle anything from one to a very large number.
Quote
Basically these are unrelated pieces of data. You make them related by having them in the same place in two lists ( or arrays ) So the third tag ID in the tag ID list will correspond to the third name in the name list.
You will want to store these lists in a none volatile way, that is you need the data to persist through power cycles. That is why you think you need to include literal names in the actual code. However if the tag IDs and names are stored in EEPROM then there is no need to include these in the actual hard code. This of course means more code to store and retrieve data from EEPROM.
Programming is all about abstracting data out of the code and into variables.
It's a long haul but if you know what you are aiming at I think it helps.
ColeH
Okay, I totally get what you are trying to get me to do now, but when I run my code I am left with multiple errors and a few questions.
Code: [Select]
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
//Begin RTC
    #include <Wire.h>
    #include "RTClib.h"
    RTC_DS1307 RTC;
//End RTC
//Begin RFID
    #include <LiquidCrystal.h>
    LiquidCrystal lcd(7, 8, 9, 10, 11, 12); // initialize the library with the numbers of the interface pins
    #define TAG_LEN 12
    //char tag[12] = {'3', '6', '0', '0', '7', '8', '9', '9', '8', '7'}; //tag 1
    //char tag2[12] = {'3', '6', '0', '0', '7', '8', '9', 'B', 'B', '5'}; //tag 2
    char* names[] = { "my first name", "my second name"}; // define an array of names
    char code[12];
    int bytesread = 0;
    //Connections to be made:
    int ledPin = 13; // Connect LED to pin 13
    int rfidPin = 2; // RFID enable pin connected to digital pin 2
    //Connect SOUT Pin to pin 0, does not need to be defined because 0 is the default RX pin
    int val=0;
//End RFID
//Begin SD
    #include <SD.h>
    File myFile;
//End SD
void setup () {
    Serial.begin(2400);
    Wire.begin();
    RTC.begin();
  if (! RTC.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    // uncomment it & upload to set the time, date and start run the RTC!
    //RTC.adjust(DateTime(__DATE__, __TIME__));
  pinMode(10, OUTPUT);
void loop () {
  //Begin RFID
digitalWrite(ledPin,LOW); //LED off
digitalWrite(rfidPin, LOW); // Activate the RFID reader
lcd.clear(); //Clears LCD
lcd.setCursor(0, 0);
lcd.print("  Please Swipe");
lcd.setCursor(0, 1);
lcd.print("   Your Card");
if(Serial.available() > 0) {     // if data available from reader
   if((val = Serial.read()) == 10) {   // check for header
     bytesread = 0;
     while(bytesread<10) {   // read 10 digit code
     if( Serial.available() > 0) {
    val = Serial.read();
    if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
break;      // stop reading
    code[bytesread] = val;    // add the digit
    bytesread++; // ready to read next digit
digitalWrite(rfidPin, HIGH); //Turns off RFID reader, THIS IS IMPORTANT so it doesn't double read the card
//End RFID
if(bytesread >= 10) {   // if 10 digit read is complete
    if(strcmp(code, tags) == 0) {
         idNumber = validate(tags);
         accessgranted();
         lcd.print(idNumber);
         if (myFile) {
           myFile.print(idNumber);
           timestamp();
           // close the file:
           myFile.close();
      }  else {
lcd.clear();
lcd.print("Access Denied");
lcd.println(code);
   Serial.print(code);
   Serial.println(" does not match");
  bytesread = 0;
void timestamp()
  DateTime now = RTC.now();
  myFile.print(now.month(), DEC);
  myFile.print('/');
  myFile.print(now.day(), DEC);
  myFile.print(' ');
  myFile.print(now.hour(), DEC);
  myFile.print(':');
  myFile.print(now.minute(), DEC);
  myFile.print(':');
  myFile.print(now.second(), DEC);
  myFile.println();
void accessgranted()
lcd.clear();
lcd.print(" Access Granted");
lcd.println(code);
delay (1500);
The first of the errors says this, integer constant is too large for 'long' type.  The question that I now have is, in your quick example code using the strings, how do you setup a function like this?  "accessGrant(idNumber); // open door and print out name on LCD"  I did some research but I can't be sure how to set up a function that way, especially the for accessGranted part.  MY only guess would be something like this
Code: [Select]
void accessgranted(idNumber)
  if (myFile) {
    timestamp();
    // close the file:
    myFile.close();
Is that correct?
Grumpy_Mike
Ok the problem with the tags is I forgot to put ll on the end of the constants so that line becomes:-
Code: [Select]
long long tags[] = { 0x3600789987ll, 0x3600789BB5ll }; // define an array with two tags in it
As I wrote that top level code the grant access function takes in not the tag number but the place in the list where the match was found:-
so you get something like this:-
Code: [Select]
  lcd.print(names[idNumber]+" access granted");
// proceed to log it
ColeH
I really get what I should do now, but when I ran my code, I still get errors.
Code: [Select]
//Begin RTC
    #include <Wire.h>
    #include "RTClib.h"
    RTC_DS1307 RTC;
//End RTC
//Begin RFID
    #define TAG_LEN 12
    char code[12];
    int bytesread = 0;
    int val=0;
//End RFID
//Begin SD
    #include <SD.h>
    File myFile;
//End SD
void setup () {
    Serial.begin(2400);
    Wire.begin();
    RTC.begin();
void loop () {
  //Begin RFID
     bytesread = 0;
//End RFID
   accessgranted();
  bytesread = 0;
void timestamp()
  myFile.print('/');
  myFile.print(' ');
  myFile.print(':');
  myFile.print(':');
  myFile.println();
   lcd.clear();
   lcd.print(names[idNumber]+"access");
   if (myFile) {
       myFile.print(names[idNumber]);
       timestamp();
       // close the file:
       myFile.close();
      }  else {
lcd.clear();
lcd.println(code);
   Serial.print(code);
Did I not set it up properly?
Grumpy_Mike
What errors?
Can you give links to the libaries you use.
ColeH
this page has the libraries I am using.
http://learn.adafruit.com/adafruit-data-logger-shield/downloads
There are 10 or so errors.
Grumpy_Mike
Thanks for the link
you use
Code: [Select]
   accessgranted();
  bytesread = 0;
but you do not pass any number into the function accessgranted, yet in the function declaration you have a number you pass in. You also need to say what type of number this is. You want to pass the token just read into this.
You can't use isrunning with the library it is not implemented.
Next you have
Code: [Select]
Now you have defined tags as a long long so you can't do a string compare. This is the place where you search through your list of tags and see if it matches the one you have just read.
Next line says
Quote
There is no validate function in the code.
Anyway I stopped there.
Grumpy_Mike
Quote
Well no I didn't however I stopped when I found out that the RTClib that you linked to is so out of date it won't compile on my machine.
This is as far as I got. Note you need to put the read token into a long long token to pass it to the function. See comments.
Code: [Select]
//Begin RTC
    #include <Wire.h>
    #include <RTClib.h>
    #include <SD.h>
    RTC_DS1307 RTC;
//End RTC
//Begin RFID
    #define TAG_LEN 12
    char* names[] = {"fred","mike"};
    int maxTags = 2; // maximum number of tags - each name needds a tag
    char code[12];
    int bytesread = 0;
    int val=0;
//End RFID
//Begin SD
    File myFile;
//End SD
void setup () {
    Serial.begin(2400);
    Wire.begin();
    RTC.begin();
/* -- this calss has no member isrunning
  //Begin RFID
     bytesread = 0;
//End RFID
    accessgranted(0x123LL); // YOU NEED TO PASS THE VALUE OF THE TOKEN YOU JUST READ HERE
  bytesread = 0;
void timestamp()
  myFile.print('/');
  myFile.print(' ');
  myFile.print(':');
  myFile.print(':');
  myFile.println();
void accessgranted(long long tag)
  int idNumber = validate(tag);
if(idNumber != -1) { // no match returns -1 otherwise
   lcd.clear();
   lcd.print(names[idNumber]);
   if (myFile) {
       timestamp();
       // close the file:
       myFile.close();
      }  else {
lcd.clear();
lcd.println(code);
   Serial.print(code);
int validate(long long newRead){
  int place = -1;
    for(int i=0; i<maxTags; i++){
      if(newRead == tags[i]) place = i;
   return place;
ColeH
Do you personally think that this version of the code would work?
Code: [Select]
//Begin RTC
    #include <Wire.h>
    #include "RTClib.h"
    RTC_DS1307 RTC;
//End RTC
//Begin RFID
    #define TAG_LEN 12
    char code[12];
    int bytesread = 0;
    int val=0;
//End RFID
//Begin SD
    #include <SD.h>
    File myFile;
//End SD
void setup () {
    Wire.begin();
    RTC.begin();
void loop () {
  //Begin RFID
bytesread = 0;
//End RFID
         accessgranted();
         if (myFile) {
           timestamp();
           // close the file:
           myFile.close();
      }  else {
lcd.clear();
lcd.println(code);
   Serial.print(code);
  bytesread = 0;
void timestamp()
              myFile.print('/');
              myFile.print(' ');
              myFile.print(':');
              myFile.print(':');
              myFile.println();
  lcd.clear();
lcd.println(code);
delay (1500);
I know that you have will most likely have no way to test it, but what do you think?
Grumpy_Mike
Are we not back to the old problem of needing more code for every tag that has access?
