Topic: LM358 module - how to connect? (Read 6279 times) previous topic - next topic
Sand_HK
Jul 21, 2013, 09:26 am Last Edit: Jul 21, 2013, 09:34 am by Sand_HK Reason: 1
can anybody help me connect a condenser mic to a LM358 module to the Arduino.
I have a LM358 module like the one at
http://www.wayengineer.com/index.php?main_page=product_info&products_id=2981
I have the VCC and GND connected and the power led comes on but no matter how I connect the IN and OUT connectors I do not get a proper signal to the Arduino.
At the moment:
I have the mic connected to IN and GND (GND on the mic to GND) (I have tried the other way as well).
I have the OUT connected to pin A2 on the Arduino
I get a reading of around 500 (the value fluctuates between about 490 and 520). Changing the onboard pot does not effect the value.
EDIT - just found out I get the same reading when the mic is not connected.
I have contacted the company I purchased it from and they don't know. Even though they sell it as Arduino compatible.
runaway_pancake
Provide a schematic of what you've done.
Doing this stuff verbally, and with all that back-and-forth, is a waste of time.
Draw a picture of your circuit, take a decent picture of that and upload it as an attachment.
A condenser (electret) mic requires power.
It's not like a crystal mic.
In my dwg, attached, there are some biasing resistors and coupling caps.
"+V" should not be greater than 3V.
If you don't like it, google for others.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
DVDdoug
Quote
That's sort-of a good thing...   With no signal the Arduino ADC should by biased at 2.5V (half of the full-scale 1023 reading with the default 5V reference).    ...I didn't see anything in the amplifier modual discription saying that.
Now, you just have to get a signal from your mic to the amp, and the readings shoul jump-around, centered around approximately 512.
AmbiLobe
Get a "dynamic microphone".
The condensor mic needs up to 48 volts to provide static electricity. Or maybe 5 volts... Read this...
http://en.wikipedia.org/wiki/Phantom_power
Sand_HK
#4
Jul 22, 2013, 02:54 pm Last Edit: Jul 22, 2013, 02:59 pm by Sand_HK Reason: 1
here's the circuit:
Here's the sketch I am using to test:
Code: [Select]
int micPin = 1;
int micVal = 0;
int oldMicVal = 0;
int micMax = -9;
int micMin = 9999;
int ledPin = 13;
 while (!Serial)   {  ; // wait for serial port to connect. Needed for Leonardo only
 pinMode(ledPin, OUTPUT);
 micVal =  analogRead(micPin);
 if (micVal >560)            {  digitalWrite(ledPin, HIGH);  delay(100);   digitalWrite(ledPin, LOW);    }
 if (micVal > micMax )     {  micMax = micVal;  }
 if (micVal < micMin )      {  micMin = micVal;   }
 Serial.print("\nmicVal = ");Serial.println(micVal);
 Serial.print("micMax = ");Serial.println(micMax);
 Serial.print("micMin = ");Serial.println(micMin);
 delay(10);
and here is the output I am getting:
Code: [Select]
micVal = 515
micMax = 529
micMin = 502
micVal = 514
micMax = 529
micMin = 502
micVal = 527
micMax = 529
micMin = 502
micVal = 511
micMax = 529
micMin = 502
micVal = 513
micMax = 529
micMin = 502
micVal = 513
micMax = 529
micMin = 502
micVal = 508
micMax = 529
micMin = 502
I get the same values when I remove the mic.
janost
#5
Jul 22, 2013, 10:05 pm Last Edit: Jul 22, 2013, 10:15 pm by janost Reason: 1
WTF!
http://www.epanorama.net/circuits/microphone_powering.html
Don't post if you don't know anything!
