Topic: Means of actively searching for water (Read 13483 times) previous topic - next topic
Etcetera
I'm a bit new here but I do have some decent experience with programming in C# and at lower end BEAM robotics.
Anyways...
I know the idea of how the regular water sensors work on the arduino but is there some way of making an arduino robot actively search for water ( because this one runs on a battery that requires a regular supply of water ). I can use an old processor like the i4 or i5 if the arduino doesn't have the capability to process the data whether it'd be video, image or something else.
zoomkat
Quote
You might either torture it, or ply it with liquor and women.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
Grumpy_Mike
If you do manage to find a sensor that will remotely detect the direction of water then rush out a patent application you are on to something big.
robtillaart
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Grumpy_Mike
How do the Mars rovers do it?
Basically they don't, they look for signs of water in rock formation. Bylooking at the minrilisation you can conclude that they had to form in water. You can get a remote detection of the elements that make up water by spectral analysis of the reflected sunlight but you have to be looking straight at it. Then it is not water you see but the spectral components of water and as has been proven a few times this is not the same thing.
You can test if something is water once you have found something but to seek it implies a signal you can lock onto some sort of signal. Short of water devining I am not sure how you do this.
joemcder
Baby sea turtles after hatching immediate head for open water even if they cannot see it.  They apparently detect polarized light reflecting off the water.  Of course your Arduino robot may not be as smart as a baby turtle.
robtillaart
Quote
Maybe they just hear the noise or follow the slope of the beach (I'm just guessing, no biologist)
Rob Tillaart
Etcetera
So I'm putting my best assumption that it hasn't been done on the arduino, right?
Grumpy_Mike
Well I would say at all not only just on an arduino. However a bit more information about what you actually mean would not go amiss.
joemcder
Quote
They cross dunes that block the view and are just as adept when the ocean is quite.  Note that crossing a dune means going uphill first. A team of biologists equipped some turtle babies with goggles that block polarization. They became disoriented.  Plain glass goggles had no such effect.
How would we detect polarization with an Arduino.  Perhaps a servo, a piece of polarized film and a light sensor?
robtillaart
Quote
Thanks for explaining how it worked, learned again something today :)
Quote
Think that should work, servo only needs to rotate 90o, and it would be cool to use a colour sensor !  different wavelengths => different polarization(?)
Rob Tillaart
Grumpy_Mike
The turtles are using the polarization of light bouncing off the water reflected in the sky. So unless the water is open, outside and in sight of a clear sky, it is a non starter.
AWOL
Couldn't you do that thing with hazel twigs?
Divining?
:D
Grumpy_Mike
It actually worked for me with two metal coat hangers when I was a kid. Since I know it can't be done it won't work for me anymore.
Anyway strapping a person to a robot is not going to win any prizes.
aarondc
GPS --> get current location
[Body of water / river] database stored on SD card or similar. (eg: http://water.epa.gov/scitech/datait/tools/waters/data/downloads.cfm)
Calculate shortest path.
Profit.
Assuming your robot is looking for naturally occurring water, and not just looking for a tap.
