Topic: Prototype PCB board soldering tips needed (Read 5522 times) previous topic - next topic
oliver88
#15
Sep 26, 2013, 07:58 pm Last Edit: Feb 09, 2016, 12:09 am by oliver88
@yarash--I know soldering the IC requires the very good soldering skills and there are chances of the short circuit while soldering the IC. The best thing you can do I just solder the corner pins of the IC because it helps to make the IC stable and the rest of the pins you can easily solder without holding the IC. The other thing you can do is just use the maximum flux as we know flux is used to prevent the oxidization of soldering joints but I also observed that it prevents the spreading of the solder and concentrate the flux that helps us to finish with smooth connection with less chances of short circuiting.
montaje superficial
