Topic: Arduino pro mini supply (Read 2311 times) previous topic - next topic
Yaro
I want to supply arduino pro mini 5v with a 9v battery. I'll use it to sample an analog signal. Do i need to use some filters or anything else? I would like that the sampling will be accurate.
Thank you.
CrossRoads
Nope. Battery is like a big capacitor, smooths voltage pretty good by itself.
cmiyc
Yes, you'll want some small cap values to filter out high frequency stuff.  Like 1uF, 0.1uF ceramics.
No batteries are like very bad capacitors, not big capacitors.  They are very very slow to respond to signal changes.  You still want something small in front of them to help with ripple.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
CrossRoads
Well, he's got the onboard regulator and its capacitors and the other caps that go with the uC.
fungus
True.
The power will go through a regulator on the Pro's PCB. Adding decoupling before the regulator won't do very much.
Advanced Arduino
Yaro
0.1 tantalium between + and - of battery is enough?
cmiyc
No, you wouldn't want to use a Tantalum, even if you could find one that was only 0.1uF.
As the others point out, the pro mini has its own decoupling solution.
jack wp
Well, now I am all confused. LOL
How accurate of a reading do you need?
What voltage range are you reading?
Are any other devices being run from this battery?
What kind of battery, and how long do you think it will last?
xl97
#8
Aug 02, 2013, 04:51 pm Last Edit: Aug 02, 2013, 05:18 pm by xl97 Reason: 1
* not in conjunction with the pro-mini project....but a more general question
but why would one not want to use a 'tant' polarized cap for the decoupling on the power rails?
(curious to learn is all... is it because of the argument that it may 'blow' in a shorted position?)
thanks!
also..
SMD TANT CAPS:
0.1uF
http://www.digikey.com/product-detail/en/TAJR104K020RNJ/478-3286-1-ND/930078
1.0uF
http://www.digikey.com/product-detail/en/298D105X0016M2T/718-1157-1-ND/1559651
10uF
http://www.digikey.com/product-detail/en/TCM0J106M8R/511-1494-1-ND/1209671
22uF
http://www.digikey.com/product-detail/en/F980J226MMA/493-2876-1-ND/1129165
jack wp
If the only thing this 9V battery is powering is the pro mini, then there is no need for any other caps.
But we don't know yet, because the OP has not answered that question (or others ask of them) yet. Maybe today.
