Topic: Shield circuit from noise (Read 824 times) previous topic - next topic
Yaro
I want to ask you if small holes for leds, connections or unshilded cables that go outside the shield box may compromise its function and how much.
Thank you.
CrossRoads
Depends on the frequency of what's switching inside. Low frequencies have long wavelengths and need big holes, high frequencies have short wavelengths and get out small holes.
Are you trying to keep noise out? Or keep it from getting out?
Yaro
Keeping the noise out. I need to sample signals, but i also need an indicator(led), buttons and an external device powered and connected(with 1 digital pin) to arduino inside the box.
polymorph
You will need to be more specific about what kind of signals you are sampling, and in what environment.
I'd worry more about wires coming in from outside than I would a 5mm hole for an LED.
As for how much - how long is a piece of string?
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
Yaro
Load cell, and the string is long about 1 or 2 cm.
