Topic: malfunzionamento display lcd (Read 16118 times) previous topic - next topic
Tia38
No nessuno errore di compilazione, solo in fase di esecuzione, lo sketch è questo
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
#include <WString.h>
#include <LiquidCrystal.h>
#include <Wire.h>
#include <RTClib.h>
LiquidCrystal lcd(9, 7, 5, 4, 3, 2);
#define LA3 440
const short buzzer=3;
RTC_DS1307 RTC;
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0E, 0xB2, 0x27 }; // MAC address
EthernetClient client;
  Wire.begin();
  RTC.begin();
  lcd.begin (16,2);
  lcd.clear();
     Wire.begin();
     RTC.begin();
     RTC.sqw(1);
          if (! RTC.isrunning()) {
          RTC.adjust(DateTime(__DATE__, __TIME__));
  if(Ethernet.begin(mac) == 0)
    Serial.println("Errore nel configurare Ethernet usando DHCP");
    while(true)
  Serial.print("Indirizzo IP: ");
  IPAddress myIPAddress = Ethernet.localIP();
  Serial.println(myIPAddress);
void loop () {
byte i = 0;
byte val = 0;
byte code[6];
byte checksum = 0;
byte bytesread = 0;
byte tempbyte = 0;
char aaa[2];
if(Serial.available() > 0) {
   if((val = Serial.read()) == 2) {
     bytesread = 0;
     while (bytesread < 12) {
       if( Serial.available() > 0) {
         val = Serial.read();
         if((val == 0x0D)||(val == 0x0A)||(val == 0x03)||(val == 0x02)) {
         if ((val >= '0') && (val <= '9')) {
           val = val - '0';
         } else if ((val >= 'A') && (val <= 'F')) {
           val = 10 + val - 'A';
         if (bytesread & 1 == 1) {
           code[bytesread >> 1] = (val | (tempbyte << 4));
           if (bytesread >> 1 != 5) {
             checksum ^= code[bytesread >> 1];
           tempbyte = val;
         bytesread++;
     if (bytesread == 12) {
       String pippo ="";
       Serial.print("5-byte code: ");
       for (i=0; i<5; i++) {
         if (code[i] < 16) Serial.print("0");
         Serial.print(code[i], HEX);
         sprintf(aaa, "%02X" , code[i]);
         pippo = pippo + aaa;
          {tone(buzzer, LA3);
  delay(300); //Suona il la per 300 millisecondi
  noTone(buzzer);
       lcd.clear();
       Serial.println("Pippo:" + pippo);
       Serial.print("Checksum: ");
       Serial.print(code[5], HEX);
       Serial.println(code[5] == checksum ? " -- passed." : " -- error.");
       google_send(pippo);
     bytesread = 0;
void google_send(String tagcode){
  char c;
  char buffer[10];
  int i;
  String submit = "&submit=Submit";
  String data = "tagcode=";
  IPAddress ip(192,168,2,50);
  unsigned int u;
  u=80;
  if (client.connect(ip, u)) {
    data = "tagcode=" + tagcode;
    Serial.print ("--");
    Serial.print (data);
    client.println("POST /arduino/read.aspx HTTP/1.1");
    Serial.println("POST /arduino/read.aspx HTTP/1.1");
    client.println("Host: 192.168.2.50");
    Serial.println("Host: 192.168.2.50");
    client.println("Content-Type: application/x-www-form-urlencoded");
    Serial.println("Content-Type: application/x-www-form-urlencoded");
    client.println("Connection: close");
    Serial.println("Connection: close");
    client.println("User-Agent: Arduino/1.0");
    Serial.println("User-Agent: Arduino/1.0");
    client.print("Content-Length: ");
    Serial.print("Content-Length: ");
    client.println(data.length());
    Serial.println(data.length());
    client.println();
    client.println(data);
    Serial.println(data);
     String risposta = "";
     String RESULT = "";
     String TAGID = "";
     String FULLNAME = "";
     String TIMESTAMP = "";
     for (i=0; i<2000; i++) {
         char c = client.read();
         int abc= (int)c;
         if (abc == -1)
         risposta = risposta + c;
         Serial.print(risposta);
         Serial.println ("");
         int index = risposta.indexOf('>');
         risposta = risposta.substring(index + 1);
         RESULT = risposta.substring(0, risposta.indexOf('<'));
         TAGID = risposta.substring(0, risposta.indexOf ('<'));
         FULLNAME = risposta.substring (0, risposta.indexOf ('<'));
         TIMESTAMP = risposta.substring (0, risposta.indexOf ('<'));
         Serial.println("Result = " + RESULT);
         Serial.println("Tagid = " + TAGID);
         Serial.println ("Fullname = " + FULLNAME);
         Serial.println ("Timestamp = " + TIMESTAMP);
             DateTime now = RTC.now();
                lcd.clear();
                sprintf(buffer,  "%02d/%02d/%d", now.day(), now.month(), now.year());
                lcd.setCursor(0,1);
                lcd.print( buffer );
                Serial.println ( buffer );
                char buffer[10] = "";
                sprintf(buffer,  "%02d:%02d:%02d", now.hour(), now.minute(), now.second());
                lcd.setCursor(11,1);
  //                                Serial.print("Ram: ");
  //                                Serial.println(freeRam());
         const int ledPin =  6;
         const int ledPin1 =  8;
         pinMode(ledPin, OUTPUT);
         pinMode(ledPin1, OUTPUT);
           if (RESULT == "OK")
              digitalWrite(ledPin, LOW);
              digitalWrite(ledPin1, HIGH);
              delay (500);
              digitalWrite(ledPin1, LOW);
              delay (200);
              delay (200);
              delay (200);
              delay (20);
              digitalWrite(ledPin1,LOW);
            lcd.setCursor (0,0);
//            lcd.print ("N: ");
            lcd.print (FULLNAME);
         //   lcd.setCursor (0,1);
//            lcd.print ("T: ");
         //   lcd.print (TIMESTAMP);
              digitalWrite(ledPin, HIGH);
              delay (500);
              delay (200);
              delay (200);
              delay (200);
              delay (200);
              digitalWrite(ledPin,LOW);
    Serial.println("connection failed");
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print ("Scheda assente");
  delay(100);
  client.stop();
PaoloP
A me lo sketch sembra a posto.
Non ho le componenti necessarie per poterlo testare in esecuzione quindi trovo moto difficile aiutarti.  :smiley-sweat:
Tia38
Eh infatti é quello che mi sembra molto strano, anche a me sembra ok, grazie mille comunque:)
